    [Plugin] Components manager plugin
    156 Posts 15 Posters 71.6k Views 15 Watching
    • G
      glro
      I tried the last version
      it works fine
      but i get an error message in the ruby console when i use my plugin mult_dim_tool
      "Error: #<NoMethodError: undefined method entities' for #<Sketchup::ComponentInstance:0x95a0a9c>> C:/Archivos de programa/Google/Google SketchUp 8/Plugins/BGSketchup/Composants/Rb/Composants_Main.rb:764:in onElementAdded'"
      Actually, i get the same message when i use any plugin
      Any idea?
      • inteloideI
        inteloide
        Hello JQL,
        Problem solved : another old bug (entities of a component instance, which doesn't work on SU 2013).
        Just post version 1.9.1, which make the plugins close from final release !!
        Actually it was post officially in pluginstore a little bit too early.
        I will also change pluginstore to reflect this version.
        By now, I won't add new features until bugs are completely close. I will also verify that it works on Mac computers (with greatoe).
        Version 1.9.1 :**
        Corrected : Bug in options for "auto-select in list",
        Corrected : The component selected on model is now clearly shown in the list
        Corrected : Observers error onElementAdded, thanks to JQL
        Corrected : If you don't want to check file existance, when clicking on a item in the list, the file was checked. Not anymore !
        Corrected : Options file was kept opened after reading option, this produced troubles when saving new options. Now solved.
        Optimized : Ruby consol only shown on my computer, as I forget sometime to hide it when I release verions ;o)
        Humanity will do a huge step when the IT professionals will understand that computers are tools...
        • JQLJ
          JQL
          Ahh then that's why I kept having to close ruby console... Going to keep testing this!
          JQL
          www.casca.pt
          Visit us on facebook!
          • inteloideI
            inteloide
            @jql said:
            4 - Would it be possible to creat filters on the list that would only show updated components or outdated or components that were associated with a file or whatever other options you have. Tick on a box and you only see green icons, tick other box and you only see blue, click on both and you see both icons on the list.
            Except this one, which is a quite bit complex, all your requests are done ! πŸ˜‰
            As I just spend more than 4 hours to correct a tinny bug (to show the component in the list when cliking on the model), I will have some rest now.
            I will use this plugins at work now and may make another updates if bugs are found for next week-end.
            I have to think about other plugins to develop :
            • 6 axis robot manager, which calculate axis angles ! (90% done actually)
            • But also tiny plugins, like a plugin that optimize loading big models (like for my robot (> 50 Mb !) by replacing big component by simply box and load the big component by a right click...
            But that's for other topics !
            Thank you JQL for all bugs you have found by now ! I hope this plugins will be use by other and they will give me their feedback !
            • JQLJ
              JQL
              LOL Inteloide I gave you a bad time and it seems I'm going to pester you a little longer so I know what you might be thinking of me right now... πŸ‘Š
              But here it goes: you know this select feature request that made you fight with a bug for hours, in what seemed to be a battle of epic proportions? There is a thing that I suspect isn't behaving as it should! πŸ˜•
              If you have a component in model that is inside a group, in a model with several nested groups and you select it, if it's inside the first group in the list, everything is ok and it is shown in the list. However if the component's parent is not in the first branch of the list, the component is only selected if the whole list is expanded.
              Take a look at picture for better understanding of the question.
              Other thing I noticed is that when I save a component I have to be careful to always write the extension. Save as "Yellow" isn't enough, as the path gets saved as "c:\blablabla\Yellow" and your plugin only accepts "c:\blablabla\Yellow.skp".
              Another thing that works is if I use context menu and use "save as", as the path gets correctly saved.
              Final question for now is how is the version level management working? I think it's indeed an excellent idea. It's beautiful for backup or version comparison... Very well thought! However, I can't get it to auto name versions when saving...
              EDIT: I changed options but didn't restart Sketchup. Is it needed? I'll try again.
              This is getting an incredible plugin! Congratulations!
              JQL
              www.casca.pt
              • inteloideI
                inteloide
                Hello JQL,
                Could you send me your file, please ?
                It will be easier for me to correct bugs.
                Thank you
                • JQLJ
                  JQL
                  Of course! It's been modified on some more experiments, but still has the same structure.
                  component manager.skp
                  Thanks,
                  JQL
                  www.casca.pt
                  • inteloideI
                    inteloide
                    Hello JQL,
                    Just post a new version that correct all bugs you had.
                    Updates are :
                    Corrected : When clicking on model to component within groups, component was not shown
                    Corrected : When selecting multiple item in the list make all the list outlined
                    Corrected : Components without extension are now managed ok.
                    Optimized : Click on a group in the model then group is also outlined in list.
                    Optimized : Reduce Javascript code in HTML page
                    Added : Link to forum page in about screen
                    Could you please check that files without extension ("c:/tatata/toto") are working properly ?
                    About revision management, this is how it work.
                    Imagine a model (A.skp) with component ("toto") saved on hard drive or wherever.
                    Imagine that each time you make a modification to the component, you want to keep history of the file, so you save it with a revision level (for example "rev...")
                    So in your folder, you may have files like :
                    • toto.skp
                    • toto rev 1.skp
                    • toto rev 2.skp
                    • toto rev3.skp
                    • toto rev4.skp
                    And when you open your model (A.skp), you want to upload the latest revision of "toto" component, so "toto rev4.skp".
                    Then, you just have to choose option "Use revision level system" and the plugin will upload only the last revision !
                    When saving (by right-cliking on the component in the list...not using save all components...sorry, I have to add this function too), it asks you if you want to create a new revision, ie "toto rev5.skp".
                    The text to define revision level can be choosen in options menus.
                    Pay attention to a following rules :
                    1. spaces are important : if revision text is " rev" (with a space before), "totorev1.skp" is not the revision 1...
                    2. revision level can be float number, but better to use rounded number (because "rev 1.3" will new newer than "rev 1.11", as 1.3>1.11)
                    3. nothing after revision : "rev 1 (super)" won't works.
                    4. on file, if you put letter instead of figure ("rev A") it may crash...
                    • JQLJ
                      JQL
                      It seems super, this week will be a hard one to keep up with you, but I'll try as soon as possible...
                      I'll check what you asked for right now.
                      Thanks again,
                      JQL
                      www.casca.pt
                      • JQLJ
                        JQL
                        Hi Inteloide,
                        1 - Component manager is now able to save without extension but it's still unable to find a reference that was saved that way.
                        2 - I understood the concept of versions level but I'm unable to make the plugin save a new version by itself. It ask wether I'd like to save as new version level or not, but never saves a new version either I press yes or no.
                        3 - Selecting from either list or model is now working perfectly, just like outliner.
                        4 - There is a feature that is not working as I would expect too. If one refreshes the list by whatever reason it collapses (some commands also refresh it). You loose the context on the list you were on. Of course it's easy now to choose from model so this is just a minor question.
                        Best regards. I hope this helps,
                        JQL
                        www.casca.pt
                        • OxerO
                          Oxer
                          On Mac when Sketchup runs it appears a Ruby Console Error:
                          %(#FF0000)[Error al cargar archivo /Users/Oxer/Library/Application Support/SketchUp 2013/SketchUp/Plugins/BGSketchup/Composants/Rb/Composants_Main.rb
                          Permission denied - /Users/Oxer\BGSketchup_Composants.ini
                          Error al cargar archivo BGSketchup_Composants.rb
                          Permission denied - /Users/Oxer\BGSketchup_Composants.ini]
                          The BGSketchup_Composants.ini file doesn't exist in that path, i have complete privilegies for Plugins folder.
                          • OxerO
                            Oxer
                            I have added the spanish language to Localization.rb file.
                            Spanish Language added
                            • inteloideI
                              inteloide
                              Hello,
                              As every day, just post an update, with following corrections :
                              Corrected : When clicking on component in model, the information were not displayed.
                              Corrected : Revision system now working
                              Corrected : Bug when clicking on a group in the model (doesn't block user)
                              Corrected : Attempt to solve Mac file issue
                              Added : Spanish language, thanks to Oxer
                              JQL, this solve points 2 and 3. For your point 1, note that Sketchup force the file to be a ".skp" when saving component...No way to solve this...
                              About point 4 : it could be complex...I will try (I stack this with the filters for the list ;o)
                              Oxer : thank yoiu for translation !
                              About your issue on Mac, I make a correction that may solve your issue. I saw that the "/" and "" were different on your message. as windows reconize both, I force the string to be with "/". I guess it solve the problem...Please keep me informed !
                              Note also that I release the first help file (at least !!!). Hope you will love it !!! πŸ˜‰
                              bye !
                              • OxerO
                                Oxer
                                Thanks for the update but it appears the same message in Ruby Console:
                                • inteloideI
                                  inteloide
                                  Hello Oxer,
                                  could you please post the complete error message ? To which line produce this bug ?
                                  thank you !
                                    The answer is in the text πŸ˜’
                                    /Users/Oxer****\****BGSketchup_Composants.ini
                                    The backslash \ will only work as a file separator character on PCs, NOT MACs !
                                    A / works on both platforms.
                                    You should use File.join(directorypath, filename) to avoid this issue.
                                    Also you can use .tr!("\\","/") to fix it.
                                    [Conversely, on PC if you ever want to pass a path to say a "cmd" use .tr!("/","\\") as DOS always expects \ !]
                                    On PC AND on MAC this will work:
                                    /Users/Oxer****/****BGSketchup_Composants.ini
                                    Change the code from:
                                    file_name=BGSketchup_my_documents_dir()+"\\BGSketchup_Composants.ini"
                                    to
                                    file_name=Fiile.join(BGSketchup_my_documents_dir(), "BGSketchup_Composants.ini")
                                    which avoids the \...
                                    Incidentally don't set def methods with uppercase first letter:
                                    BGSketchup_my_documents_dir() NO 😞
                                    bgSketchup_my_documents_dir() YES πŸ˜„
                                    Although a method named ' getTempFolder()' would be more logical*** ??
                                    ***Writing this ini file to that user-location is also somewhat ill-advised ?
                                    Why not put it into a 'Temp folder' - this varies between PC and MAC...
                                    ENV['TEMP'] || ENV['TMPDIR']
                                    if !(mac) ... return path.strip.gsub("\000","") else #On Mac return File.expand_path "~" end
                                    could simply be:
                                    return ENV['TEMP'] || ENV['TMPDIR']
                                    On PC it gives:
                                    C:\Users\UserName\AppData\Local\Temp
                                    OR perhaps on PC [ruby:3kd2xg63]ENV['APPDATA'][/ruby:3kd2xg63] giving:
                                    [ruby:3kd2xg63]C:\Users\UserName\AppData\Roaming[/ruby:3kd2xg63]
                                    On MAC it's the user's hidden ..../T[emp] folder
                                    Keeping it 'out of the way', and avoiding all of the '.so' rigmarole and odd locations for the .ini file...
                                    πŸ€“
                                    • OxerO
                                      Oxer
                                      How TIG says, the answer is in the text, all red text is the Error Message.
                                      Thanks TIG for the explanation, i don't know the ruby code. πŸ‘
                                      • inteloideI
                                        inteloide
                                        Hello,
                                        Thank you TIG for your help.
                                        Your code is so much simple than mine...I changed to yours.
                                        New version (1.9.4) solve only this error.
                                        • inteloideI
                                          inteloide
                                          Version 1.9.5 :
                                          Corrected : When saving all definitions, it asks now to save also file without link.
                                          Optimzed : Now, for revision management, file with letter after revision level and accepted "toto rev 3 (super").skp"
                                          Oxer, any feedback as a MAC user ?
                                          I will officially post this version tomorrow if no bugs are found.
                                          In parrallel I will look for JQL request but won't post new version (I think too much version make confusion...)
                                          • OxerO
                                            Oxer
                                            Image 4
                                            Image 5
                                            • 3 / 8
