    [Plugin] Components manager plugin
    156 Posts 15 Posters 63.1k Views 15 Watching
      The answer is in the text πŸ˜’
      /Users/Oxer****\****BGSketchup_Composants.ini
      The backslash \ will only work as a file separator character on PCs, NOT MACs !
      A / works on both platforms.
      You should use File.join(directorypath, filename) to avoid this issue.
      Also you can use .tr!("\\","/") to fix it.
      [Conversely, on PC if you ever want to pass a path to say a "cmd" use .tr!("/","\\") as DOS always expects \ !]
      On PC AND on MAC this will work:
      /Users/Oxer****/****BGSketchup_Composants.ini
      Change the code from:
      file_name=BGSketchup_my_documents_dir()+"\\BGSketchup_Composants.ini"
      to
      file_name=Fiile.join(BGSketchup_my_documents_dir(), "BGSketchup_Composants.ini")
      which avoids the \...
      Incidentally don't set def methods with uppercase first letter:
      BGSketchup_my_documents_dir() NO 😞
      bgSketchup_my_documents_dir() YES πŸ˜„
      Although a method named ' getTempFolder()' would be more logical*** ??
      ***Writing this ini file to that user-location is also somewhat ill-advised ?
      Why not put it into a 'Temp folder' - this varies between PC and MAC...
      ENV['TEMP'] || ENV['TMPDIR']
      if !(mac) ... return path.strip.gsub("\000","") else #On Mac return File.expand_path "~" end
      could simply be:
      return ENV['TEMP'] || ENV['TMPDIR']
      On PC it gives:
      C:\Users\UserName\AppData\Local\Temp
      OR perhaps on PC [ruby:3kd2xg63]ENV['APPDATA'][/ruby:3kd2xg63] giving:
      [ruby:3kd2xg63]C:\Users\UserName\AppData\Roaming[/ruby:3kd2xg63]
      On MAC it's the user's hidden ..../T[emp] folder
      Keeping it 'out of the way', and avoiding all of the '.so' rigmarole and odd locations for the .ini file...
      πŸ€“
      • OxerO Offline
        Oxer
        How TIG says, the answer is in the text, all red text is the Error Message.
        Thanks TIG for the explanation, i don't know the ruby code. πŸ‘
        • inteloideI Offline
          inteloide
          Hello,
          Thank you TIG for your help.
          Your code is so much simple than mine...I changed to yours.
          New version (1.9.4) solve only this error.
          Humanity will do a huge step when the IT professionals will understand that computers are tools...
            inteloide
            Version 1.9.5 :
            Corrected : When saving all definitions, it asks now to save also file without link.
            Optimzed : Now, for revision management, file with letter after revision level and accepted "toto rev 3 (super").skp"
            Oxer, any feedback as a MAC user ?
            I will officially post this version tomorrow if no bugs are found.
            In parrallel I will look for JQL request but won't post new version (I think too much version make confusion...)
            • OxerO Offline
              Oxer
              Image 4
              Image 5
              • OxerO Offline
                Oxer
                Now, there isn't Console Error when you open Sketchup, the settings window appears, the plugin generates the BGSketchup_Composants.ini file in Temporal folder, the translation works but the there are some problems:
                1. The list is empty, when you push Update List button, nothing happens, no error in Ruby Console.
                2. If you push Reload All Components button, it appears an error in Ruby Console, see the image 2.
                3. If you push Save All Components button, it appears a first pop up window (image 3), i push Yes button and it appears a second empty pop up window (image 4), i push yes and it appears a Ruby Console Error (image 5).
                Image 2
                Image 3
                  That ' nil' error points to code at line #494 of the script Composants_Main.rb - which reads:
                  UI.messagebox @strNbEnregistementDefinitions+" ("+compteur_ok.to_s+"/"+compteur.to_s+")"
                  So presumably a part of it is actually ' nil' ?
                  @strNbEnregistementDefinitions is set elsewhere in the script Localization.rb.
                  This is set from a series of ' if/elsif' tests, BUT ill-advisedly there is no 'fall-back' ' else' when nothing matches the other tests - so then it can return ' nil', and thereby cause the error - because a ' nil' object can't be used as part of a text string!
                  Perhaps change the code to read...
                  @strNbEnregistementDefinitions='?' unless @strNbEnregistementDefinitions UI.messagebox(@strNbEnregistementDefinitions+" ("+compteur_ok.to_s+"/"+compteur.to_s+")")
                  OR have a proper ' else' fall-back in the Localization.rb tests section...
                  The other two methods used in compiling the remainder of the string should always safely return a string as they start off as 0 - giving '... (1/2)' etc...
                    inteloide
                    This could be due to a missing tranlsation in string (a string not defined in one language). Therefore, I change the way of working on Localisation.rb :
                    1-I load all strings in English
                    2-I load the strings in the wanted language.
                    This means that if a string is not translated, the string will be defined with English value.
                    The key thing, for me, is to always have strings defined in English, at minimal.
                      inteloide
                      @oxer said:
                      1. If you push Reload All Components button, it appears an error in Ruby Console, see the image 2.
                      Please try version 1.9.6 below, which should solve this issue.
                      That's strange...maybe a javascript error...let's try with version 1.9.6, it may solve the issue.
                      Version 1.9.6
                      • OxerO Offline
                        Oxer
                        Ok, i'll test it.
                        • OxerO Offline
                          Oxer
                          The list continues empty 😞
                          I'll test the other functions
                          • OxerO Offline
                            Oxer
                            • Modify file's path -->works
                            • Save selected component -->works
                            • Save all components -->works
                            • Save with new revision level -->works
                            • Reload selected component -- > doesn't work, when you select the component it appears "Saved file is newer!" message but when i push Reload selected component button nothing happens, see the image below.
                              inteloide
                              Could be due to the browser I use which is IE.
                              Please try to open attached file by placing it in plugins folder, in HTML subfolder. And tells me what happen.
                              It's just a simplifyed list to see any error that your brownser may show.
                              If you see something like a list, try to open directly the treeview.html file.
                              Please report me any error...because without list...it's just not so useful... πŸ˜‰
                              I maybe need an html/javascript specialist...
                              The test file
                              • OxerO Offline
                                Oxer
                                I placed the test.html file in /Users/Oxer/Library/Application Support/SketchUp 2013/SketchUp/Plugins/BGSketchup/Composants/Html/ then I run Sketchup but when I call the plugin, the list is empty again. I have tried open tree.html in Safari browser and it appears a message:
                                Safari can't open "sip:get_data@charger_tires" because OSX doesn't recognize the address of internet that begin with "skp:".
                                When i open test.html in Safari the file shows like this:
                                  inteloide
                                  Hello,
                                  Just post new version, with following updates :
                                  1.9.8: Corrected : Delete all debugging messages, now works on MAC ! Thanks to Oxer !
                                  1.9.7:	Corrected :	Some javascript standard respect
                                  	Added :		Show a message to update the list if the wasn't.
                                  		Added :		Option not to start component mangement on SU start up to avoid adding attribute to model or slow down due to Observers
                                  1.9.6:	Corrected :	For localisation, in cas of error, the English language is chosen, also, english tranlsation always preload in case translation is missing
                                  	Corrected :	Change function in BGSketchup.rb functions into unic name function to avoid problem with other plugins
                                    inteloide
                                    New version update (v 1.10.0) :
                                    Added : Toolbar with icon to show the plugin window
                                    Added : Help file is now in plugin sub folders, with a link from the "about" window. It was updated with last options explainations
                                    Optimzed : "About" window in HTML format for better rendering and to allow links to help file and forum.
                                    Optimzed : Component list shows scrollbar only is required.
                                    Optimzed : On MAC, use plugin window is now always on top.
                                    Corrected : Only one instance of the window can be shown.
                                    Corrected : Added, some missing translations in Spanish language.
                                      inteloide
                                      Hello,
                                      Some updates today !
                                      JQL, one of your request is complete (filters) !
                                      1.11.0:
                                      Added : New option to show list without a tree-style
                                      Added : New button and window to filter item shown on list in case of non tree-style list
                                      Corrected : Component with relative path were shown as "not updated", now shown in grey
                                      Corrected : Tiny bug when showing components without dates
                                      Corrected : Add filter in remove observer to avoid errors
                                      Corrected : When clicking on component in model, all instances were selected if option Auto-select component in model was chosen
                                      Optimzed : Purge only the definitions reloaded, to avoid any trouble with other definition
                                      1.10.0:
                                      I hope lots of you feel this plugins useful...
                                      3D printer progress...only 1 euro by now... 😒
                                      • OxerO Offline
                                        Oxer
                                        Thanks for the update!! πŸ‘
                                        Some questions in OSX:
                                        1. If you select Yes in "Show list in tree-style" Option it doesn't appear like tree-style but if you select No then it appears the list in tree-style, is it the option upside down?
                                        2. In Filters window the option "Component has no defined date" has a blue color but in Component Manager window it appears in black, is it an error?
                                        PS. The tooltips in Component Manager window don't translate to Spanish.
                                        EDIT: I had not understood the functionality, it works correctly but if you push Filter button when you have selected YES in option "Show list in tree-style", it appears a pop-up window with this message "You must choose option Show list in tree-style.", I think that it should say --> "You must choose NO in option Show list in tree-style." because with YES it isn't appear the Filters window.
                                          inteloide
                                          Hello Oxer,
                                          Just post new version 1.11.1 that solve your issues:
                                          Corrected : New filter for components which were not checked (option "Auto-check file paths")
                                          Optimized : Improve warning message for filter window
                                          Optimized : Component without modification date are shown in blue
                                          Optimized : Message shown if filter make the list empty
                                          Optimized : Allow more translations
                                          • OxerO Offline
                                            Oxer
                                            Hi again,
                                            I'll test it. πŸ‘
                                            • 4 / 8
