    [Plugin] Components manager plugin
    156 Posts 15 Posters 71.6k Views 15 Watching
    • JQLJ
      JQL
      LOL Inteloide I gave you a bad time and it seems I'm going to pester you a little longer so I know what you might be thinking of me right now... πŸ‘Š
      But here it goes: you know this select feature request that made you fight with a bug for hours, in what seemed to be a battle of epic proportions? There is a thing that I suspect isn't behaving as it should! πŸ˜•
      If you have a component in model that is inside a group, in a model with several nested groups and you select it, if it's inside the first group in the list, everything is ok and it is shown in the list. However if the component's parent is not in the first branch of the list, the component is only selected if the whole list is expanded.
      Take a look at picture for better understanding of the question.
      Other thing I noticed is that when I save a component I have to be careful to always write the extension. Save as "Yellow" isn't enough, as the path gets saved as "c:\blablabla\Yellow" and your plugin only accepts "c:\blablabla\Yellow.skp".
      Another thing that works is if I use context menu and use "save as", as the path gets correctly saved.
      Final question for now is how is the version level management working? I think it's indeed an excellent idea. It's beautiful for backup or version comparison... Very well thought! However, I can't get it to auto name versions when saving...
      EDIT: I changed options but didn't restart Sketchup. Is it needed? I'll try again.
      This is getting an incredible plugin! Congratulations!
      JQL
      www.casca.pt
      Visit us on facebook!
      • inteloideI
        inteloide
        Hello JQL,
        Could you send me your file, please ?
        It will be easier for me to correct bugs.
        Thank you
        Humanity will do a huge step when the IT professionals will understand that computers are tools...
        • JQLJ
          JQL
          Of course! It's been modified on some more experiments, but still has the same structure.
          component manager.skp
          Thanks,
          JQL
          www.casca.pt
          • inteloideI
            inteloide
            Hello JQL,
            Just post a new version that correct all bugs you had.
            Updates are :
            Corrected : When clicking on model to component within groups, component was not shown
            Corrected : When selecting multiple item in the list make all the list outlined
            Corrected : Components without extension are now managed ok.
            Optimized : Click on a group in the model then group is also outlined in list.
            Optimized : Reduce Javascript code in HTML page
            Added : Link to forum page in about screen
            Could you please check that files without extension ("c:/tatata/toto") are working properly ?
            About revision management, this is how it work.
            Imagine a model (A.skp) with component ("toto") saved on hard drive or wherever.
            Imagine that each time you make a modification to the component, you want to keep history of the file, so you save it with a revision level (for example "rev...")
            So in your folder, you may have files like :
            • toto.skp
            • toto rev 1.skp
            • toto rev 2.skp
            • toto rev3.skp
            • toto rev4.skp
            And when you open your model (A.skp), you want to upload the latest revision of "toto" component, so "toto rev4.skp".
            Then, you just have to choose option "Use revision level system" and the plugin will upload only the last revision !
            When saving (by right-cliking on the component in the list...not using save all components...sorry, I have to add this function too), it asks you if you want to create a new revision, ie "toto rev5.skp".
            The text to define revision level can be choosen in options menus.
            Pay attention to a following rules :
            1. spaces are important : if revision text is " rev" (with a space before), "totorev1.skp" is not the revision 1...
            2. revision level can be float number, but better to use rounded number (because "rev 1.3" will new newer than "rev 1.11", as 1.3>1.11)
            3. nothing after revision : "rev 1 (super)" won't works.
            4. on file, if you put letter instead of figure ("rev A") it may crash...
            • JQLJ
              JQL
              It seems super, this week will be a hard one to keep up with you, but I'll try as soon as possible...
              I'll check what you asked for right now.
              Thanks again,
              JQL
              www.casca.pt
              • JQLJ
                JQL
                Hi Inteloide,
                1 - Component manager is now able to save without extension but it's still unable to find a reference that was saved that way.
                2 - I understood the concept of versions level but I'm unable to make the plugin save a new version by itself. It ask wether I'd like to save as new version level or not, but never saves a new version either I press yes or no.
                3 - Selecting from either list or model is now working perfectly, just like outliner.
                4 - There is a feature that is not working as I would expect too. If one refreshes the list by whatever reason it collapses (some commands also refresh it). You loose the context on the list you were on. Of course it's easy now to choose from model so this is just a minor question.
                Best regards. I hope this helps,
                JQL
                www.casca.pt
                • OxerO
                  Oxer
                  On Mac when Sketchup runs it appears a Ruby Console Error:
                  %(#FF0000)[Error al cargar archivo /Users/Oxer/Library/Application Support/SketchUp 2013/SketchUp/Plugins/BGSketchup/Composants/Rb/Composants_Main.rb
                  Permission denied - /Users/Oxer\BGSketchup_Composants.ini
                  Error al cargar archivo BGSketchup_Composants.rb
                  Permission denied - /Users/Oxer\BGSketchup_Composants.ini]
                  The BGSketchup_Composants.ini file doesn't exist in that path, i have complete privilegies for Plugins folder.
                  • OxerO
                    Oxer
                    I have added the spanish language to Localization.rb file.
                    Spanish Language added
                    • inteloideI
                      inteloide
                      Hello,
                      As every day, just post an update, with following corrections :
                      Corrected : When clicking on component in model, the information were not displayed.
                      Corrected : Revision system now working
                      Corrected : Bug when clicking on a group in the model (doesn't block user)
                      Corrected : Attempt to solve Mac file issue
                      Added : Spanish language, thanks to Oxer
                      JQL, this solve points 2 and 3. For your point 1, note that Sketchup force the file to be a ".skp" when saving component...No way to solve this...
                      About point 4 : it could be complex...I will try (I stack this with the filters for the list ;o)
                      Oxer : thank yoiu for translation !
                      About your issue on Mac, I make a correction that may solve your issue. I saw that the "/" and "" were different on your message. as windows reconize both, I force the string to be with "/". I guess it solve the problem...Please keep me informed !
                      Note also that I release the first help file (at least !!!). Hope you will love it !!! πŸ˜‰
                      bye !
                      • OxerO
                        Oxer
                        Thanks for the update but it appears the same message in Ruby Console:
                        • inteloideI
                          inteloide
                          Hello Oxer,
                          could you please post the complete error message ? To which line produce this bug ?
                          thank you !
                            The answer is in the text πŸ˜’
                            /Users/Oxer****\****BGSketchup_Composants.ini
                            The backslash \ will only work as a file separator character on PCs, NOT MACs !
                            A / works on both platforms.
                            You should use File.join(directorypath, filename) to avoid this issue.
                            Also you can use .tr!("\\","/") to fix it.
                            [Conversely, on PC if you ever want to pass a path to say a "cmd" use .tr!("/","\\") as DOS always expects \ !]
                            On PC AND on MAC this will work:
                            /Users/Oxer****/****BGSketchup_Composants.ini
                            Change the code from:
                            file_name=BGSketchup_my_documents_dir()+"\\BGSketchup_Composants.ini"
                            to
                            file_name=Fiile.join(BGSketchup_my_documents_dir(), "BGSketchup_Composants.ini")
                            which avoids the \...
                            Incidentally don't set def methods with uppercase first letter:
                            BGSketchup_my_documents_dir() NO 😞
                            bgSketchup_my_documents_dir() YES πŸ˜„
                            Although a method named ' getTempFolder()' would be more logical*** ??
                            ***Writing this ini file to that user-location is also somewhat ill-advised ?
                            Why not put it into a 'Temp folder' - this varies between PC and MAC...
                            ENV['TEMP'] || ENV['TMPDIR']
                            if !(mac) ... return path.strip.gsub("\000","") else #On Mac return File.expand_path "~" end
                            could simply be:
                            return ENV['TEMP'] || ENV['TMPDIR']
                            On PC it gives:
                            C:\Users\UserName\AppData\Local\Temp
                            OR perhaps on PC [ruby:3kd2xg63]ENV['APPDATA'][/ruby:3kd2xg63] giving:
                            [ruby:3kd2xg63]C:\Users\UserName\AppData\Roaming[/ruby:3kd2xg63]
                            On MAC it's the user's hidden ..../T[emp] folder
                            Keeping it 'out of the way', and avoiding all of the '.so' rigmarole and odd locations for the .ini file...
                            πŸ€“
                            • OxerO
                              Oxer
                              How TIG says, the answer is in the text, all red text is the Error Message.
                              Thanks TIG for the explanation, i don't know the ruby code. πŸ‘
                              • inteloideI
                                inteloide
                                Hello,
                                Thank you TIG for your help.
                                Your code is so much simple than mine...I changed to yours.
                                New version (1.9.4) solve only this error.
                                • inteloideI
                                  inteloide
                                  Version 1.9.5 :
                                  Corrected : When saving all definitions, it asks now to save also file without link.
                                  Optimzed : Now, for revision management, file with letter after revision level and accepted "toto rev 3 (super").skp"
                                  Oxer, any feedback as a MAC user ?
                                  I will officially post this version tomorrow if no bugs are found.
                                  In parrallel I will look for JQL request but won't post new version (I think too much version make confusion...)
                                  • OxerO
                                    Oxer
                                    Image 4
                                    Image 5
                                    • OxerO
                                      Oxer
                                      Now, there isn't Console Error when you open Sketchup, the settings window appears, the plugin generates the BGSketchup_Composants.ini file in Temporal folder, the translation works but the there are some problems:
                                      1. The list is empty, when you push Update List button, nothing happens, no error in Ruby Console.
                                      2. If you push Reload All Components button, it appears an error in Ruby Console, see the image 2.
                                      3. If you push Save All Components button, it appears a first pop up window (image 3), i push Yes button and it appears a second empty pop up window (image 4), i push yes and it appears a Ruby Console Error (image 5).
                                      Image 2
                                      Image 3
                                        That ' nil' error points to code at line #494 of the script Composants_Main.rb - which reads:
                                        UI.messagebox @strNbEnregistementDefinitions+" ("+compteur_ok.to_s+"/"+compteur.to_s+")"
                                        So presumably a part of it is actually ' nil' ?
                                        @strNbEnregistementDefinitions is set elsewhere in the script Localization.rb.
                                        This is set from a series of ' if/elsif' tests, BUT ill-advisedly there is no 'fall-back' ' else' when nothing matches the other tests - so then it can return ' nil', and thereby cause the error - because a ' nil' object can't be used as part of a text string!
                                        Perhaps change the code to read...
                                        @strNbEnregistementDefinitions='?' unless @strNbEnregistementDefinitions UI.messagebox(@strNbEnregistementDefinitions+" ("+compteur_ok.to_s+"/"+compteur.to_s+")")
                                        OR have a proper ' else' fall-back in the Localization.rb tests section...
                                        The other two methods used in compiling the remainder of the string should always safely return a string as they start off as 0 - giving '... (1/2)' etc...
                                        • inteloideI
                                          inteloide
                                          This could be due to a missing tranlsation in string (a string not defined in one language). Therefore, I change the way of working on Localisation.rb :
                                          1-I load all strings in English
                                          2-I load the strings in the wanted language.
                                          This means that if a string is not translated, the string will be defined with English value.
                                          The key thing, for me, is to always have strings defined in English, at minimal.
                                          • inteloideI
                                            inteloide
                                            @oxer said:
                                            1. If you push Reload All Components button, it appears an error in Ruby Console, see the image 2.
                                            Please try version 1.9.6 below, which should solve this issue.
                                            That's strange...maybe a javascript error...let's try with version 1.9.6, it may solve the issue.
                                            Version 1.9.6
                                            • 4 / 8
