    [Plugin] Components manager plugin
    156 Posts 15 Posters 68.0k Views 15 Watching
    • inteloideI
      inteloide
      @tig said:
      This is set from a series of ' if/elsif' tests, BUT ill-advisedly there is no 'fall-back' ' else' when nothing matches the other tests - so then it can return ' nil', and thereby cause the error - because a ' nil' object can't be used as part of a text string!
      This could be due to a missing tranlsation in string (a string not defined in one language). Therefore, I change the way of working on Localisation.rb :
      1-I load all strings in English
      2-I load the strings in the wanted language.
      This means that if a string is not translated, the string will be defined with English value.
      The key thing, for me, is to always have strings defined in English, at minimal.
      Humanity will do a huge step when the IT professionals will understand that computers are tools...
      • inteloideI
        inteloide
        @oxer said:
        1. If you push Reload All Components button, it appears an error in Ruby Console, see the image 2.
        Please try version 1.9.6 below, which should solve this issue.
        @oxer said:
        1. The list is empty, when you push Update List button, nothing happens, no error in Ruby Console.
        That's strange...maybe a javascript error...let's try with version 1.9.6, it may solve the issue.
        Version 1.9.6
        • OxerO
          Oxer
          Ok, i'll test it.
          • OxerO
            Oxer
            The list continues empty 😞
            I'll test the other functions
            • OxerO
              Oxer
              • Modify file's path -->works
              • Save selected component -->works
              • Save all components -->works
              • Save with new revision level -->works
              • Reload selected component -- > doesn't work, when you select the component it appears "Saved file is newer!" message but when i push Reload selected component button nothing happens, see the image below.
              • inteloideI
                inteloide
                Could be due to the browser I use which is IE.
                Please try to open attached file by placing it in plugins folder, in HTML subfolder. And tells me what happen.
                It's just a simplifyed list to see any error that your brownser may show.
                If you see something like a list, try to open directly the treeview.html file.
                Please report me any error...because without list...it's just not so useful... πŸ˜‰
                I maybe need an html/javascript specialist...
                The test file
                • OxerO
                  Oxer
                  I placed the test.html file in /Users/Oxer/Library/Application Support/SketchUp 2013/SketchUp/Plugins/BGSketchup/Composants/Html/ then I run Sketchup but when I call the plugin, the list is empty again. I have tried open tree.html in Safari browser and it appears a message:
                  Safari can't open "sip:get_data@charger_tires" because OSX doesn't recognize the address of internet that begin with "skp:".
                  When i open test.html in Safari the file shows like this:
                  • inteloideI
                    inteloide
                    Hello,
                    Just post new version, with following updates :
                    1.9.8: Corrected : Delete all debugging messages, now works on MAC ! Thanks to Oxer !
                    1.9.7:	Corrected :	Some javascript standard respect
                    	Added :		Show a message to update the list if the wasn't.
                    		Added :		Option not to start component mangement on SU start up to avoid adding attribute to model or slow down due to Observers
                    1.9.6:	Corrected :	For localisation, in cas of error, the English language is chosen, also, english tranlsation always preload in case translation is missing
                    	Corrected :	Change function in BGSketchup.rb functions into unic name function to avoid problem with other plugins
                    • inteloideI
                      inteloide
                      New version update (v 1.10.0) :
                      Added : Toolbar with icon to show the plugin window
                      Added : Help file is now in plugin sub folders, with a link from the "about" window. It was updated with last options explainations
                      Optimzed : "About" window in HTML format for better rendering and to allow links to help file and forum.
                      Optimzed : Component list shows scrollbar only is required.
                      Optimzed : On MAC, use plugin window is now always on top.
                      Corrected : Only one instance of the window can be shown.
                      Corrected : Added, some missing translations in Spanish language.
                      • inteloideI
                        inteloide
                        Hello,
                        Some updates today !
                        JQL, one of your request is complete (filters) !
                        1.11.0:
                        Added : New option to show list without a tree-style
                        Added : New button and window to filter item shown on list in case of non tree-style list
                        Corrected : Component with relative path were shown as "not updated", now shown in grey
                        Corrected : Tiny bug when showing components without dates
                        Corrected : Add filter in remove observer to avoid errors
                        Corrected : When clicking on component in model, all instances were selected if option Auto-select component in model was chosen
                        Optimzed : Purge only the definitions reloaded, to avoid any trouble with other definition
                        1.10.0:
                        I hope lots of you feel this plugins useful...
                        3D printer progress...only 1 euro by now... 😒
                        • OxerO
                          Oxer
                          Thanks for the update!! πŸ‘
                          Some questions in OSX:
                          1. If you select Yes in "Show list in tree-style" Option it doesn't appear like tree-style but if you select No then it appears the list in tree-style, is it the option upside down?
                          2. In Filters window the option "Component has no defined date" has a blue color but in Component Manager window it appears in black, is it an error?
                          PS. The tooltips in Component Manager window don't translate to Spanish.
                          EDIT: I had not understood the functionality, it works correctly but if you push Filter button when you have selected YES in option "Show list in tree-style", it appears a pop-up window with this message "You must choose option Show list in tree-style.", I think that it should say --> "You must choose NO in option Show list in tree-style." because with YES it isn't appear the Filters window.
                          • inteloideI
                            inteloide
                            Hello Oxer,
                            Just post new version 1.11.1 that solve your issues:
                            Corrected : New filter for components which were not checked (option "Auto-check file paths")
                            Optimized : Improve warning message for filter window
                            Optimized : Component without modification date are shown in blue
                            Optimized : Message shown if filter make the list empty
                            Optimized : Allow more translations
                            • OxerO
                              Oxer
                              Hi again,
                              I'll test it. πŸ‘
                              • JQLJ
                                JQL
                                @inteloide said:
                                Hello,
                                Unbelieaveble!
                                I have not had the time to work with your plugin recently, but this week I will try it for sure. Thanks for all the recent excellent updates, this is growing strong.
                                JQL
                                www.casca.pt
                                Visit us on facebook!
                                • OxerO
                                  Oxer
                                  There are yet some problems:
                                  1. To work fine the Filter function you must to change the line#50 in Localization.rb file
                                  Of @strTreeListOptionToBeSelected="You must set option '"+@strOptionVerifierChemin+"' to '"+@strNon+"'."
                                  to @strTreeListOptionToBeSelected="You must set option '"+@strAfficherArbre+"' to '"+@strNon+"'."
                                  2. The Filter only works the first time, then when you push Filter again all items are unselected, and if you select one or various items and push Apply button nothing happens in the List window, it appears only the message "Nothing to show due to filters". The Ruby Console is empty.
                                  PS. The tooltips continue without translation in Component Manager window. I send you a new spanish language by PM.
                                  • inteloideI
                                    inteloide
                                    Thank to Oxer a big bug is corrected in version 1.11.2.
                                    Everybody should download this version to avoid problem using the plugin.
                                    Updates :
                                    1.11.2:
                                    Corrected : Major error while linking component to file of reloading component
                                    Corrected : In non tree style, numbers of instances of components filtered still appeared
                                    Corrected : A bug appear in consol when leaving the plugin due to observers still working
                                    Corrected : Change context menu javascript position which may imply some Safari problems
                                    Optimized : Add translation for component updating while opening new sketchup instance.
                                    Oxer, we keep in touch for your button title issue.
                                    • OxerO
                                      Oxer
                                      I'm testing the last version on Mac and the Filters doesn't work. 😞
                                      • inteloideI
                                        inteloide
                                        Hello Oxer,
                                        Could you tell me what's goes wrong ?
                                        • OxerO
                                          Oxer
                                          When I push the Filter button the first time it appear the Filters window with all items selected, I unselect for example "Group" and "File path doesn't exist" and I push Apply button, then the Filters window disappears and it appears this message in the Component Manager window "Nothing to show due to filters".
                                          I had groups, component linked and component unlinked in the model. I suppose that the Filters function works showing only the items selected in Filter windows but it isn't so.
                                          If I open the Filters window a second time, all items are unselected.
                                          Mac OSX 10.9.1 and SU2013
                                          • inteloideI
                                            inteloide
                                            Hello Gents,
                                            Please download last version of the plugins which solve the 2 issues you raised me :
                                            Version 1.11.3:
                                            Optimized : The modification of components don't add lots of undo/redo action in Edit menu.
                                            Corrected : Bug when changing filters
                                            Oxer, could you tell me also if the last version solve your issue about button title translation in main window ?
                                            JQL, thx for chasing me on the undo/redo action, actually it was just simple as reading the sketchup rubi api...
                                            Just one thing : for example if you delete an edge linked to a face, so edge and face are deleted, when undo the action, the component manager will tells you that your component has been modified (even if it actually reverse back to original design).
                                            It's not a big bug, but I'll keep thinking about a solution.
                                            Inteloide
                                            • 4 / 8
