    How to create blurry and clear mirror material use an iMAGE?
    renderpluginsextensions
    6 Posts 3 Posters 2.6k Views 3 Watching
      sketchuh
      Hi you all, i think if it's possible to use a a image/alpha mask that create blurry and clear mirror effect. can someone show me how to do it step by step?
      attached an image to give you a better idea what im talkin about.
      i tired to use vector file from adobe illustrator then the pattern which was curve became straight lines.
      i want to have the flower pattern to be blurry and the rest to be normal mirror.
        sketchuh
        i wonder how to maintain curve when i imported curves from illustrator.
        the vector file imported from a.i. become straight lines.
        • andybotA
          andybot
          I would export your pattern as a "png" image file. You should also make a black and white version, which you can then use as a mask in your vray material.
          Step 1. Generate a tiling (repeats in a consistent way) pattern from your illustrator file. (If you don't know how, I'm sure you can find a tutorial on Google.)
          Step 2. Export a colored image version (in png format) to use as a pattern in Sketchup. (Make a new material in your Sketchup material editor)
          Step 3. Export a b&w version to use as a mask in vray. (Make the frosted part pure black, and the brown background a pure white.)
          Step 4. apply the material to your mirror surface, open the vray material editor.
          step 5. add a reflection layer in vray, change the filter color to the background brown color.
          step 6. edit your "reflection" material (the blue "M") and in the "perpendicular" material (little "m" in white box) add in your mask material (choose "TexBitmap", the select your image file.)
          Step 7. add a second reflection layer to your material. Change the "Glossiness" value for Hilight and Reflection to 0.6, change your subdivs to 16
          Step 8. Check you material preview - if the pattern is inverted, you can edit the "Perpendicular" material mask by selecting the "invert" option.
          Let me know if any of these steps are not clear β˜€
            sketchuh
            hey andobot!! i owe you a lot!!! it worked!!!! after following your step by step instruction, i finally successfully did it. Thank you thank you thank you!!!
            my thoughts:
            1.i didn't set the blurry reflection to 0.6 though, it's too much it kills the reflection. i set it about 0.85. i guess it depends.
            2. think texture map = photoshop mask. that helps me understand the concept in this situation.
            again thank you andybot! really appreciated!
            failed attempt
            this second one give me the impression that texture map is like photoshop mask! but with many more distracting, scary options that makes me feel lost. lol
            then this one whoohoo!
            • andybotA
              andybot
              my thoughts:
              πŸ‘ You're very welcome!
              Glad you were able to adjust everything to your needs (there are indeed many many options πŸ€“ )
              • V
                valerostudio
                Sweet material and sweet tutorial Andy.
