    [Plugin] Components manager plugin
    156 Posts 15 Posters 54.1k Views 15 Watching
    • JQLJ Offline
      JQL
      No problem,
      With those kind of features it's really going to be one of the most essential plugins in my workflow.
      I think you're right, freezing the first window is bad has there might be things you need to copy as references for editing in the other window. I think the other plugin I mentioned would close the 2nd window when saving the model, wich is also bad as you might want to save progress, but not yet update original model with xref.
      I think the best procedure would be only to automate opening a new window and not any other process as you can simply save and reload.
      What might happen is that when you open second window, a dialog could show on the first window asking:
      You're editing file ".../component.skp" Do you want to reload it now?
      then you could have 3 buttons on the dialog:
      1 - OK - reloads when you press it.
      2 - Cancel - the window goes away and you can keep working in both SU sessions reloading whenever you wish or simply overwriting file again at any time.
      3 - Not now! - This might pop up a reminder from time to time, telling you that you have a component being edited in another window. This is useful for when you edit the window but forget to reload it in the main model.
      This reminder could be the same as above that would show up from time to time if you keep pressing Not now! button. You could be able to configure options for the time that would take for this popup to show or if it would be turned off, as it may interfere in some users workflow.
      I'm sorry, for so much requests, but as you keep implementing ideas, I keep having them... so it's a nonstop procedure.
      Thanks again,
      JQL
      www.casca.pt
      Visit us on facebook!
        @Inteloide
        Your plugin is now in the PluginStore
        You are added to the Plugin Author group so you can see this forum...
        http://sketchucation.com/forums/viewforum.php?f=382
        You can also see this....
        (sketchucation.com)
        • inteloideI Offline
          inteloide
          @rich o brien said:
          @Inteloide
          (sketchucation.com)
          Thank you very much !
          Humanity will do a huge step when the IT professionals will understand that computers are tools...
            inteloide
            Hello !
            Last modifications :
            1.9.0:
            Added : Right-click menu to do different actions
            Added : Rename function in the right-click menu
            Added : Adding function to open new SU instance to modify a component + message when coming back to previous SU instance
            Added : Auto-select in the list selected component in the model
            Added : Now it asks to create a new revision level when saving definition (and option is activated).
            Corrected : Bug when upload a component with a revision level
            Corrected : Bug with bright and dark red icon color
            Corrected : Some translation were missing
            1.8.3:	Corrected : Implement string conversion to Java when upload text titles in Html page
            1.8.2:	Non official version...deleted
              glro
              I tried the last version
              it works fine
              but i get an error message in the ruby console when i use my plugin mult_dim_tool
              "Error: #<NoMethodError: undefined method entities' for #<Sketchup::ComponentInstance:0x95a0a9c>> C:/Archivos de programa/Google/Google SketchUp 8/Plugins/BGSketchup/Composants/Rb/Composants_Main.rb:764:in onElementAdded'"
              Actually, i get the same message when i use any plugin
              Any idea?
                inteloide
                Hello JQL,
                Problem solved : another old bug (entities of a component instance, which doesn't work on SU 2013).
                Just post version 1.9.1, which make the plugins close from final release !!
                Actually it was post officially in pluginstore a little bit too early.
                I will also change pluginstore to reflect this version.
                By now, I won't add new features until bugs are completely close. I will also verify that it works on Mac computers (with greatoe).
                Version 1.9.1 :**
                Corrected : Bug in options for "auto-select in list",
                Corrected : The component selected on model is now clearly shown in the list
                Corrected : Observers error onElementAdded, thanks to JQL
                Corrected : If you don't want to check file existance, when clicking on a item in the list, the file was checked. Not anymore !
                Corrected : Options file was kept opened after reading option, this produced troubles when saving new options. Now solved.
                Optimized : Ruby consol only shown on my computer, as I forget sometime to hide it when I release verions ;o)
                • JQLJ Offline
                  JQL
                  Ahh then that's why I kept having to close ruby console... Going to keep testing this!
                  JQL
                  www.casca.pt
                    inteloide
                    @jql said:
                    4 - Would it be possible to creat filters on the list that would only show updated components or outdated or components that were associated with a file or whatever other options you have. Tick on a box and you only see green icons, tick other box and you only see blue, click on both and you see both icons on the list.
                    Except this one, which is a quite bit complex, all your requests are done ! ๐Ÿ˜‰
                    As I just spend more than 4 hours to correct a tinny bug (to show the component in the list when cliking on the model), I will have some rest now.
                    I will use this plugins at work now and may make another updates if bugs are found for next week-end.
                    I have to think about other plugins to develop :
                    • 6 axis robot manager, which calculate axis angles ! (90% done actually)
                    • But also tiny plugins, like a plugin that optimize loading big models (like for my robot (> 50 Mb !) by replacing big component by simply box and load the big component by a right click...
                    But that's for other topics !
                    Thank you JQL for all bugs you have found by now ! I hope this plugins will be use by other and they will give me their feedback !
                    • JQLJ Offline
                      JQL
                      LOL Inteloide I gave you a bad time and it seems I'm going to pester you a little longer so I know what you might be thinking of me right now... ๐Ÿ‘Š
                      But here it goes: you know this select feature request that made you fight with a bug for hours, in what seemed to be a battle of epic proportions? There is a thing that I suspect isn't behaving as it should! ๐Ÿ˜•
                      If you have a component in model that is inside a group, in a model with several nested groups and you select it, if it's inside the first group in the list, everything is ok and it is shown in the list. However if the component's parent is not in the first branch of the list, the component is only selected if the whole list is expanded.
                      Take a look at picture for better understanding of the question.
                      Other thing I noticed is that when I save a component I have to be careful to always write the extension. Save as "Yellow" isn't enough, as the path gets saved as "c:\blablabla\Yellow" and your plugin only accepts "c:\blablabla\Yellow.skp".
                      Another thing that works is if I use context menu and use "save as", as the path gets correctly saved.
                      Final question for now is how is the version level management working? I think it's indeed an excellent idea. It's beautiful for backup or version comparison... Very well thought! However, I can't get it to auto name versions when saving...
                      EDIT: I changed options but didn't restart Sketchup. Is it needed? I'll try again.
                      This is getting an incredible plugin! Congratulations!
                      JQL
                      www.casca.pt
                        inteloide
                        Hello JQL,
                        Could you send me your file, please ?
                        It will be easier for me to correct bugs.
                        Thank you
                        • JQLJ Offline
                          JQL
                          Of course! It's been modified on some more experiments, but still has the same structure.
                          component manager.skp
                          Thanks,
                          JQL
                          www.casca.pt
                            inteloide
                            Hello JQL,
                            Just post a new version that correct all bugs you had.
                            Updates are :
                            Corrected : When clicking on model to component within groups, component was not shown
                            Corrected : When selecting multiple item in the list make all the list outlined
                            Corrected : Components without extension are now managed ok.
                            Optimized : Click on a group in the model then group is also outlined in list.
                            Optimized : Reduce Javascript code in HTML page
                            Added : Link to forum page in about screen
                            Could you please check that files without extension ("c:/tatata/toto") are working properly ?
                            About revision management, this is how it work.
                            Imagine a model (A.skp) with component ("toto") saved on hard drive or wherever.
                            Imagine that each time you make a modification to the component, you want to keep history of the file, so you save it with a revision level (for example "rev...")
                            So in your folder, you may have files like :
                            • toto.skp
                            • toto rev 1.skp
                            • toto rev 2.skp
                            • toto rev3.skp
                            • toto rev4.skp
                            And when you open your model (A.skp), you want to upload the latest revision of "toto" component, so "toto rev4.skp".
                            Then, you just have to choose option "Use revision level system" and the plugin will upload only the last revision !
                            When saving (by right-cliking on the component in the list...not using save all components...sorry, I have to add this function too), it asks you if you want to create a new revision, ie "toto rev5.skp".
                            The text to define revision level can be choosen in options menus.
                            Pay attention to a following rules :
                            1. spaces are important : if revision text is " rev" (with a space before), "totorev1.skp" is not the revision 1...
                            2. revision level can be float number, but better to use rounded number (because "rev 1.3" will new newer than "rev 1.11", as 1.3>1.11)
                            3. nothing after revision : "rev 1 (super)" won't works.
                            4. on file, if you put letter instead of figure ("rev A") it may crash...
                            • JQLJ Offline
                              JQL
                              It seems super, this week will be a hard one to keep up with you, but I'll try as soon as possible...
                              I'll check what you asked for right now.
                              Thanks again,
                              JQL
                              www.casca.pt
                              • JQLJ Offline
                                JQL
                                Hi Inteloide,
                                1 - Component manager is now able to save without extension but it's still unable to find a reference that was saved that way.
                                2 - I understood the concept of versions level but I'm unable to make the plugin save a new version by itself. It ask wether I'd like to save as new version level or not, but never saves a new version either I press yes or no.
                                3 - Selecting from either list or model is now working perfectly, just like outliner.
                                4 - There is a feature that is not working as I would expect too. If one refreshes the list by whatever reason it collapses (some commands also refresh it). You loose the context on the list you were on. Of course it's easy now to choose from model so this is just a minor question.
                                Best regards. I hope this helps,
                                JQL
                                www.casca.pt
                                • OxerO Offline
                                  Oxer
                                  On Mac when Sketchup runs it appears a Ruby Console Error:
                                  %(#FF0000)[Error al cargar archivo /Users/Oxer/Library/Application Support/SketchUp 2013/SketchUp/Plugins/BGSketchup/Composants/Rb/Composants_Main.rb
                                  Permission denied - /Users/Oxer\BGSketchup_Composants.ini
                                  Error al cargar archivo BGSketchup_Composants.rb
                                  Permission denied - /Users/Oxer\BGSketchup_Composants.ini]
                                  The BGSketchup_Composants.ini file doesn't exist in that path, i have complete privilegies for Plugins folder.
                                  • OxerO Offline
                                    Oxer
                                    I have added the spanish language to Localization.rb file.
                                    Spanish Language added
                                      inteloide
                                      Hello,
                                      As every day, just post an update, with following corrections :
                                      Corrected : When clicking on component in model, the information were not displayed.
                                      Corrected : Revision system now working
                                      Corrected : Bug when clicking on a group in the model (doesn't block user)
                                      Corrected : Attempt to solve Mac file issue
                                      Added : Spanish language, thanks to Oxer
                                      JQL, this solve points 2 and 3. For your point 1, note that Sketchup force the file to be a ".skp" when saving component...No way to solve this...
                                      About point 4 : it could be complex...I will try (I stack this with the filters for the list ;o)
                                      Oxer : thank yoiu for translation !
                                      About your issue on Mac, I make a correction that may solve your issue. I saw that the "/" and "" were different on your message. as windows reconize both, I force the string to be with "/". I guess it solve the problem...Please keep me informed !
                                      Note also that I release the first help file (at least !!!). Hope you will love it !!! ๐Ÿ˜‰
                                      bye !
                                      • OxerO Offline
                                        Oxer
                                        Thanks for the update but it appears the same message in Ruby Console:
                                          inteloide
                                          Hello Oxer,
                                          could you please post the complete error message ? To which line produce this bug ?
                                          thank you !
                                            The answer is in the text ๐Ÿ˜’
                                            /Users/Oxer****\****BGSketchup_Composants.ini
                                            The backslash \ will only work as a file separator character on PCs, NOT MACs !
                                            A / works on both platforms.
                                            You should use File.join(directorypath, filename) to avoid this issue.
                                            Also you can use .tr!("\\","/") to fix it.
                                            [Conversely, on PC if you ever want to pass a path to say a "cmd" use .tr!("/","\\") as DOS always expects \ !]
                                            On PC AND on MAC this will work:
                                            /Users/Oxer****/****BGSketchup_Composants.ini
                                            Change the code from:
                                            file_name=BGSketchup_my_documents_dir()+"\\BGSketchup_Composants.ini"
                                            to
                                            file_name=Fiile.join(BGSketchup_my_documents_dir(), "BGSketchup_Composants.ini")
                                            which avoids the \...
                                            Incidentally don't set def methods with uppercase first letter:
                                            BGSketchup_my_documents_dir() NO ๐Ÿ˜ž
                                            bgSketchup_my_documents_dir() YES ๐Ÿ˜„
                                            Although a method named ' getTempFolder()' would be more logical*** ??
                                            ***Writing this ini file to that user-location is also somewhat ill-advised ?
                                            Why not put it into a 'Temp folder' - this varies between PC and MAC...
                                            ENV['TEMP'] || ENV['TMPDIR']
                                            if !(mac) ... return path.strip.gsub("\000","") else #On Mac return File.expand_path "~" end
                                            could simply be:
                                            return ENV['TEMP'] || ENV['TMPDIR']
                                            On PC it gives:
                                            C:\Users\UserName\AppData\Local\Temp
                                            OR perhaps on PC [ruby:3kd2xg63]ENV['APPDATA'][/ruby:3kd2xg63] giving:
                                            [ruby:3kd2xg63]C:\Users\UserName\AppData\Roaming[/ruby:3kd2xg63]
                                            On MAC it's the user's hidden ..../T[emp] folder
                                            Keeping it 'out of the way', and avoiding all of the '.so' rigmarole and odd locations for the .ini file...
                                            ๐Ÿค“
                                            • 3 / 8
