    Rough edges
    15 Posts 5 Posters 956 Views 5 Watching
      You could try subdividing but your textures will get messed up.
      • mrsofaM
        mrsofa
        how do i do that?
        Also I dont care about the texture because I have like 3 on it πŸ˜›
        [color=#FFBF00:1ync0juf]G[/color:1ync0juf][color=#FFB312:1ync0juf]o[/color:1ync0juf][color=#FFA724:1ync0juf]l[/color:1ync0juf][color=#FF9B37:1ync0juf]d[/color:1ync0juf] [color=#FF835B:1ync0juf]i[/color:1ync0juf][color=#FF766D:1ync0juf]n[/color:1ync0juf] [color=#FF5E92:1ync0juf]t[/color:1ync0juf][color=#FF52A4:1ync0juf]h[/color:1ync0juf][color=#FF46B6:1ync0juf]e[/color:1ync0juf] [color=#FF49A4:1ync0juf]s[/color:1ync0juf][color=#FF4F92:1ync0juf]p[/color:1ync0juf][color=#FF557F:1ync0juf]r[/color:1ync0juf][color=#FF5B6D:1ync0juf]i[/color:1ync0juf][color=#FF625B:1ync0juf]n[/color:1ync0juf][color=#FF6849:1ync0juf]g[/color:1ync0juf] [color=#FF7424:1ync0juf]a[/color:1ync0juf][color=#FF7A12:1ync0juf]n[/color:1ync0juf][color=#FF8000:1ync0juf]d[/color:1ync0juf] [color=#FF7400:1ync0juf]d[/color:1ync0juf][color=#FF6E00:1ync0juf]i[/color:1ync0juf][color=#FF6800:1ync0juf]a[/color:1ync0juf][color=#FF6200:1ync0juf]m[/color:1ync0juf][color=#FF5B00:1ync0juf]o[/color:1ync0juf][color=#FF5500:1ync0juf]n[/color:1ync0juf][color=#FF4F00:1ync0juf]d[/color:1ync0juf] [color=#FF4300:1ync0juf]o[/color:1ync0juf][color=#FF4900:1ync0juf]n[/color:1ync0juf] [color=#FF6D00:1ync0juf]t[/color:1ync0juf][color=#FF8000:1ync0juf]h[/color:1ync0juf][color=#FF9200:1ync0juf]e[/color:1ync0juf] [color=#FFB600:1ync0juf]f[/color:1ync0juf][color=#FFC800:1ync0juf]a[/color:1ync0juf][color=#FFDB00:1ync0juf]l[/color:1ync0juf][color=#FFED00:1ync0juf]l[/color:1ync0juf][color=#FFFF00:1ync0juf].[/color:1ync0juf]
          There are several plugins that you could use. Artisan is one.
          • mrsofaM
            mrsofa
            Tried this:
            http://www.guitar-list.com/download-software/sketchup-loop-subdivision-smooth-plugin
            Crashes :S
            Artisan I used up the trial...and actually never used it :S
            • N
              numerobis
              It's not possible in SU in a proper way... i would say for this type of model better choose a subD modeler...
              • mrsofaM
                mrsofa
                Yea I use cinema 4d in school, and it works, but makes it a bit messy and hard to fix... :S
                  "Crashes" isn't much to go on to help you sort out the problem with the plugin. We'll assume you just gave up on it.
                  Buy Artisan. It works.
                  Maybe you'd just be better off starting over and drawing smoother curves to begin with instead of trying to repair the mess you have.
                  • mrsofaM
                    mrsofa
                    i selected the wheel, used then subdivide, sketchup crashed.
                    It doesnt crash in simple objects as boxes...
                      Not having used that specific plugin and not being able to see your model, it's hard to say what's happening exactly. So you don't get any message when it crashes?
                      If you're planning to use SketchUp for modeling cars and other complex shapes like that, you would probably find it well worth the investment to buy Artisan. Also look at Vertex Tools. That one would also be an excellent addition for your use.
                      • mrsofaM
                        mrsofa
                        Yea it works now...Had too much other programs running...
                        Ok the results are not really good, I probably need artisan.
                        I have vertex tools. And you just made an idea with wertex tools πŸ˜‰ tnx
                          And you also need to be able to determine when you need to start over. Sometimes trying to repair a model is a black hole of wasted time. I guess you'll need to figure that one out on your own, though.
                          • BurkhardB
                            Burkhard
                            With a lot of crashes you can try to copy the wheel in a new Sketchup instance by using paste in place.
                            Work in there without the whole model and copy it back. ( delete the old one )
                            Maybe you can reduce the crashes...works a lot better. Just a try
                            http://www.ia-plus.de
