    When i want to install rbz plugin sketch up 2013 Is closed
    5 Posts 3 Posters 440 Views 3 Watching
      littleche
      When i want to install rbz plugin sketch up 2013 Is closed . 😳
      I tried several times ؛ But I did not succeed.
      I reinstall sketch up ... but After installing Several extensions، The same problem arose again ...
      What is the solution? ❓
      • TIGT Online
        Do you have FULL read/write security permissions set for everyone listed in users/groups under
        Plugins folder > Properties > Security > Edit...
        Is SketchUp.exe set to 'Run as administrator' under Properties > Compatibility ?
        How are you "installing" these RBZ files ?
        Using the Preferences > Extensions > Install... button ??
        What plugins do you have installed ?
        How much RAM do you have ?
        If you close all other unneeded programs them launch SketchUp.exe is it any better ?
        We need more info.........
          littleche
          HI TIG ...
          TNX FOR YOUR HELP ...
          1- I run with 'Run as administrator'
          2 - installing by Preferences > Extensions > Install and I try by "tt_simple_installer" plugin .
          3 - clean up . extrode tools . fredo tools . fredo scale . curviloft . shape bender . sketchucation plugin store . joint pull & push . tools on surfase . artisan . weld . 1001 bit .
          4 - ram 8 gig 2400 . gpu 2x580 .cpu 4770
          5 - I several times unstall & reinstall sketche up ... and start to install plugin again ... but Every time I encountered this problem in different Points !
          One time I just installed a 3 plugin and was a problem !
          Is this problem happening to other users?
          What I do? 😳
            Running as administrator doesn't automatically mean you have permissions to install files in the Plugins folder. You must explicitly set those permissions.
            Generally problems related to plugins in SketchUp are caused by one or more common issue. None of them are bugs with SketchUp.
            Lack of sufficient permissions/privileges.
            Incorrect installation.
            Installation of plugins that are known to cause conflicts
            Why don't you try this in this order and see what happens.
            -Edit the permissions for the Plugins folder so all users have full access.
            -Delete any plugins you may have installed or tried to install in the Plugins folder. Leave the native ones there.
            -Download and install the Sketchucation Plugin Store plugin. It downloads with the extension .rbz and installs with Install Extension... under Preferences>Extensions.
            Close SketchUp and reopen it.
            -Activate the Sketchucation toolbar under View>Toolbars. Click on the red icon, search for the desired plugins and let the tool install them for you automatically.
              littleche
              The problem was resolved by installing su 2014. 😍
              Thank you for your support ... 👍
