    Adding slopes to non-perpendicular arcs and objects
    26 Posts 6 Posters 3.5k Views 6 Watching
    • bikerchrisB Offline
      bikerchris
      @techdave02 said:
      sorry oops
      No problem - I upload the wrong files all the time.
      That is PERFECT!!!! Would you be able to give a hint about your method? Thanks so much for taking your time mate, really is appreciated.
        TECHDAVE02
        TRY TRY AGAIN
        fredo scale plug in
        example2-connecting-a-2D-curve-to-lower-or-upper-Z 2AA.skp
          TECHDAVE02
          http://sketchucation.com/forums/viewtopic.php?p=144180#p144180
            bikerchris
            Thanks Dave, much appreciated! I've installed it now, can you give me another hint about which tool you used? Pretty please πŸ˜„
              You could look at Fredo's Curvishear plugin. Maybe it'll do what you want.
                TECHDAVE02
                  TECHDAVE02
                  sent you a PM of my latest project
                    mac1
                    bickerchris;
                    What is the ultimate application of your model? Does it need to meet road intersection / interchage design? If it does then there are a number of other criteria that may impact what you are trying to do??
                      dtrarch
                      bikerchris
                      Tak2hata's Draw_Slope_Normals will work too.
                      http://www.youtube.com/watch?v=c9qzsLg1ii0%26amp;feature=share%26amp;list=UU7HM1vF707x5nSWuhhxZedg
                      dtr
                        bikerchris
                        Hi TechDave and Dave,
                        Again, thank you both for your massive amounts of help.
                        Dave R, I went down the route of Curvishear and it was perfect, what a find and definitely a donation going towards Fredo6 as he's incredibly worthy of it.
                        Mac1 - the application of the model is for proposals for new development, what helps less is the severe amount of different levels around the site, one of which is a ramped curved access road into a lower part of the site. The combination of the Fredo Curvishear and Curviloft skinning is the perfect solution to make the mapping data into 3D, when things aren't just straight lines.
                        TechDave, I'm still really grateful for all of your help, please don't take offence at me going to Dave R's solution, yours was great, but too complicated for my brain πŸ˜„
                        dtrarch, thanks for your suggestion, I'll keep a note!
                        You're all great people and I'm so grateful for your help!
                          bikerchris
                          TechDave, I'm still really grateful for all of your help, please don't take offense at me going to Dave R's solution, yours was great, but too complicated for my brain πŸ˜„
                            TECHDAVE02
                            All good; Happy New Year!!
                              bikerchris
                              Hi All, thought I would return to this topic, as it seems that my prayers weren't 100% answered - pretty damn close though! Curvishear works perfectly when curves only are in use. Unfortunately the entity I wanted to extrude to different heights is a combination of straight and curved components...typical!
                              Anyway, just thought I'd update ye' olde thread. πŸ˜„
                                Divide the straight line segments into a number of short ones and then weld them back together. Divide by right clicking on the line and choosing Divide. Use TIG-Weld to weld the line segments together.
                                  bikerchris
                                  You are so clever it's frightening Dave, sounds like a great solution, I'll give it a go. Thank you for thinking about it!
                                    Just wait until I really get going! 🀣 🀣
                                    Please report your results. I want to know if it works for you. πŸ˜‰
                                    • BoxB Offline
                                      Just to add to that, By welding several straights and/or curves together you create a curve, so don't feel you need to divide the straights to begin with. You only need to divide and re weld if the straights are individual.
                                        Good point, Box. I should have added that you could weld the straight section to an existing curve which would just extend the curve.
                                        • BoxB Offline
                                          Which just goes to show, if you are frighteningly clever I must be terrifying.
                                            bikerchris
                                            Hehe, I think you've already got going...and then stoppped πŸ˜‰ Cheers matey, I'll let you know how I get on πŸ˜‰
                                            Thanks for your contribution Box, I regret you're not terrifying, 'shockingly' is next...takes a lot of effort to be terrifying...few have achieved it.
