    [Plugin] FullScreen v5.1.3 (25 April 2024)
    285 Posts 79 Posters 402.7k Views 80 Watching
      Anton_S
      @feodos said:
      In the new dialog window there is no toolbar Containers
      What do you mean there is not toolbar containers, there is! I removed an option where you could show/hide current toolbar container because not much users use these options anyways. They just show/hide them all at once.
      @feodos said:
      the button of the menu isn't active
      The menubar can be shown/hidden only when SketchUp is fullscreen! Set SU fullscreen, and then you'll be able to show/hide menubar. Hover the cursor over the menu item, and the description will be displayed in the status bar. It clearly states that the option works with main window set fullscreen only!
        Anton_S
        New update 3.0.3
        • Minor dialog and menu optimizations.
        • Added the set/remove menubar option back. Press the ALT key to set/remove menu bar.
        • Requires AMS Library 1.0.2 or later
        • Rich O BrienR Online
          Nice one Anton.
          • CadFatherC Offline
            CadFather
            Thank you for the update Anton - this plugin is fantastic.
            but...could the ALT be optional (or assignable)? on my machine it conflicts with some native keyboard shortcuts (move, or follow me tool + alt) - of course also other custom ones.
              Anton_S
              I will add customizing shortcuts soon.
              Sorry about the ALT thing πŸ˜†
                Anton_S
                Perhaps for now, you can change the shortcut yourself:
                1. Open ams_WindowsSettings/main.rb
                2. Scroll down to line 434
                3. Change 'menu' to 'f12' or whatever key you prefer.
                4. Save, and restart SU.
                  CadFather
                  Thank You, Master Anton! πŸ˜„ β˜€
                    Anton_S
                    3.5.0 Dec 15, 2013
                    • Added customizable shortcuts, thanks to CadFather.
                    • Added drag, clip, snap dialog.
                    • Added dialog clear borders option.
                    • Changed default set/remove menu shortcut key from ALT to F12.
                      laudhi
                      sketchup always freeze when i make a rectangle and select the face,right click and press R
                      I tried without any other plugin.......
                      (sketchup make,windows 7 x64)
                      btw,thanxz for the plugin..... πŸ˜„
                        Anton_S
                        Thank you for the report laudhi.
                        I found and fixed it. Download the latest version of AMS Library.
                          laudhi
                          thanks Anton_S,now everything is running smoothly without any problems with other plugins 😍
                          i love the floating window....
                            Anton_S
                            3.6.0 Jan 29, 2014
                            • Figured out a way to keep all shortcuts working while the menu bar is removed. The fancy shortcuts sections and the show/hide menu bar option were removed. They are no longer required! πŸ˜„
                            • Fixed the get screen resolution function in AMS library. Now, it will return the size of all monitors combined. This fixes an issue where the dialog could not be moved to another screen.
                            • Simplified and improved stuff.
                              CadFather
                              Master Anton strikes again - thanks!
                              • U Offline
                                unearthed
                                Thanks for this plugin Anton, it's arguably the number 1 plugin for me as it enables me to quickly clear my screen for online client presentations. The only thing is could the floating black dialog be made smaller?
                                Growplan - People ∩ Plants ∩ Place
                                windows 7 64b, 4GB RAM, SU 8.0.16846
                                Gimp, QGIS, Vectorworks 12, Bricscad 11
                                  Anton_S
                                  Thank you, CadFather!
                                  I'm glad you like it. πŸ˜„ I've been thinking about making another collapsible on top, that would collapse/uncollapse all other collapsibles. Perhaps this feature could be available in the next release. Thanks for suggestion!
                                  • V Offline
                                    vicxp0518
                                    @unclex said:
                                    and i can not dare try the Menu Option, if i close it, how reopen it ??
                                    Yes i'm encountering with the problem 😞 It's bad to me, 'cos I've already hidden everything in the window include the menu bar, then, how can I bring it back again?? I've got nothing to do with my Sketchup now even if I reinstalled both SU and this plugin. Please tell me.
                                      Anton_S
                                      Didn't you download the latest version? Use F12 to toggle the menubar and it would be a good idea to assign more shortcuts, as well. For example, SHIFT-S could be used to toggle statusbar, SHIFT-D could be used to toggle toolbar containers, and F11 could be assigned to toggle fullscreen. The latest version automatically assigns F12 shortctut at the begging of use.
                                      If you don't have any shortcuts, and made it so all elements hide at start, do the following:
                                      1. run regedit.exe
                                      2. If using SU6-SU8, locate to HKEY_CURRENTUSER/Software/Google/Sketchup[n]/, otherwise locate HKEY_CURRENTUSER/Software/SketchUp/SketchUp[n]/
                                      3. Delete the Plugins_ams folder. This will reset all plugin data.
                                      Next time, have assign shortcut to reset.
                                        Anton_S
                                        @vicxp0518, I updated the plugin so the menubar remains visible on start, under certain conditions. Download the latest version 3.7.3 and your good to go.
                                        • H Offline
                                          HirokaMatsuiko
                                          this is wonderful plugin
                                          my shortcut is almost full
                                          request if can future updates
                                          add Full Screen Button toggle on / off for toolbar
                                          thank you again
                                            Anton_S
                                            Added!. πŸ‘
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 11 / 15
