    [Plugin] FullScreen v5.1.3 (25 April 2024)
    285 Posts 79 Posters 463.1k Views 80 Watching
    • CadFatherC
      CadFather
      Thank You, Master Anton! πŸ˜„ β˜€
        Anton_S
        3.5.0 Dec 15, 2013
        • Added customizable shortcuts, thanks to CadFather.
        • Added drag, clip, snap dialog.
        • Added dialog clear borders option.
        • Changed default set/remove menu shortcut key from ALT to F12.
        • L
          laudhi
          sketchup always freeze when i make a rectangle and select the face,right click and press R
          I tried without any other plugin.......
          (sketchup make,windows 7 x64)
          btw,thanxz for the plugin..... πŸ˜„
            Anton_S
            Thank you for the report laudhi.
            I found and fixed it. Download the latest version of AMS Library.
            • L
              laudhi
              thanks Anton_S,now everything is running smoothly without any problems with other plugins 😍
              i love the floating window....
                Anton_S
                3.6.0 Jan 29, 2014
                • Figured out a way to keep all shortcuts working while the menu bar is removed. The fancy shortcuts sections and the show/hide menu bar option were removed. They are no longer required! πŸ˜„
                • Fixed the get screen resolution function in AMS library. Now, it will return the size of all monitors combined. This fixes an issue where the dialog could not be moved to another screen.
                • Simplified and improved stuff.
                • CadFatherC
                  CadFather
                  Master Anton strikes again - thanks!
                  • U
                    unearthed
                    Thanks for this plugin Anton, it's arguably the number 1 plugin for me as it enables me to quickly clear my screen for online client presentations. The only thing is could the floating black dialog be made smaller?
                    Growplan - People ∩ Plants ∩ Place
                    windows 7 64b, 4GB RAM, SU 8.0.16846
                    Gimp, QGIS, Vectorworks 12, Bricscad 11
                      Anton_S
                      Thank you, CadFather!
                      I'm glad you like it. πŸ˜„ I've been thinking about making another collapsible on top, that would collapse/uncollapse all other collapsibles. Perhaps this feature could be available in the next release. Thanks for suggestion!
                      • V
                        vicxp0518
                        @unclex said:
                        and i can not dare try the Menu Option, if i close it, how reopen it ??
                        Yes i'm encountering with the problem 😞 It's bad to me, 'cos I've already hidden everything in the window include the menu bar, then, how can I bring it back again?? I've got nothing to do with my Sketchup now even if I reinstalled both SU and this plugin. Please tell me.
                          Anton_S
                          Didn't you download the latest version? Use F12 to toggle the menubar and it would be a good idea to assign more shortcuts, as well. For example, SHIFT-S could be used to toggle statusbar, SHIFT-D could be used to toggle toolbar containers, and F11 could be assigned to toggle fullscreen. The latest version automatically assigns F12 shortctut at the begging of use.
                          If you don't have any shortcuts, and made it so all elements hide at start, do the following:
                          1. run regedit.exe
                          2. If using SU6-SU8, locate to HKEY_CURRENTUSER/Software/Google/Sketchup[n]/, otherwise locate HKEY_CURRENTUSER/Software/SketchUp/SketchUp[n]/
                          3. Delete the Plugins_ams folder. This will reset all plugin data.
                          Next time, have assign shortcut to reset.
                            Anton_S
                            @vicxp0518, I updated the plugin so the menubar remains visible on start, under certain conditions. Download the latest version 3.7.3 and your good to go.
                            • H
                              HirokaMatsuiko
                              this is wonderful plugin
                              my shortcut is almost full
                              request if can future updates
                              add Full Screen Button toggle on / off for toolbar
                              thank you again
                                Anton_S
                                Added!. πŸ‘
                                  Jim
                                  Really nice plugin, Anton. Thank you.
                                  • W
                                    whiteanne
                                    I have a proble when running this plugin(latest version) on sketchup pro 2014,it shows like the photo below. Can anyone tell me what should I do to fix it??? it would helps,thats really a useful plugin.
                                      Anton_S
                                      It seems Sketchup.register_extension is undefined. Scroll down to line 33 and add :: in from of the word Sketchup, save, and test.
                                      It should look like this:
                                      ::Sketchup.register_extension @extension, true
                                      If it doesn't work then your SU was modified, or some files were deleted. Try re-installing SketchUp and see what happens.
                                      • ArchieAA
                                        ArchieA
                                        Windows 8, SU 2014. There's no Plugins folder to unzip ams_Lib_1.0.8.zip so I extracted the files to the folder Tools.
                                        Fullscreen still doesn't work.
                                        How to I get rid of the annoying popup stating, Download ams_Lib? Or remove the plugin?
                                        Thanks in advance.
                                          Anton_S
                                          @archieA The plugins folder is located in %appdata%\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
                                          This plugin is not a standalone plugin. It requires AMS Library. Here is the link: http://sketchucation.com/forums/viewtopic.php?t=55067#p499835 Extract AMS Library in the plugins folder as well.
                                          • ArchieAA
                                            ArchieA
                                            Thank you. I got it working on SU 2014 on Windows 8. Easy enough when it's clear. I've started using it using F12 to toggle. Great plugin!
                                            • 14
                                            • 15
                                            • 7 / 15
