    [Plugin] Axo + Iso View v1.2 20101117
    84 Posts 34 Posters 228.1k Views 34 Watching
    • O
      omarkhamis123
      hellooo i made a copy for the folder in plugins but it doesnt appear on sketchup
      p.s: i made a srestart for sketchup and it doesnt appear too ๐Ÿ˜› ://
      • massimoM
        massimo Moderator
        Hi, as stated in the very first post, first line, you have to put the .rb file (and not a folder) directly in the plugins folder and then restart SU.
        • N
          nordicventures
          Hey I'm new to sketchup and have been trying to get this 'axo' plug in to work. But no luck. I keep getting this from the ruby console:
          Error: #<NameError: undefined local variable or method `axo3060' for main:Object>
          (eval)
          What is the deal I followed the directions to a -T I think?
          Please help.
            If you have correctly installed the .rb file into your Plugins folder you will get the commands available to you in the Ruby Console: you type axo3060 + <enter> and it runs...
            So this error message suggests that you have not installed it correctly ๐Ÿ˜•
            To find your Plugins folder type [or copy+paste] this line + <enter> in the Ruby Console:
            Sketchup.fins_support_file('Plugins')
            This returns the path to the folder that ought to contain your plugin files.
            It may be hidden and you'll then need to set your MAC to let you see Library folder-paths.
            If it is the HD Lib path [most likely on v8] then you may need to reset its Security Permissions to Full Read & Read, so you have unlimited access to add files etc...
            So, now put the .rb file in there...
            OR if you get the .RBZ archived version of the script from the PluginsStore page then you can AutoInstall that using the Preferences > Extensions > Install... button...
            OR if you install the 'SketchUcation Plugin Store' toolset you can search/browse through 800+ Plugins [including this one] and then AutoInstall any selected plugin from within SketchUp itself...
              Automation
              Hello Everybody,
              actual I have the requirement, to create a "cavalier" perspective.
              http://upload.wikimedia.org/wikipedia/commons/thumb/8/83/Cavalier_perspective_45.svg/480px-Cavalier_perspective_45.svg.png
              I hope that someone can tell me, how to create this view in SU.
              Many thanks!
              Automation
                dmatho
                Yes and Cabinet Oblique Projection too ๐Ÿ˜„
                For ref. see here: https://en.wikipedia.org/wiki/Graphical_projection
                Cheers,
                . DIEGO .
                  Automation
                  Hello *,
                  it would be very nice to get some information concerning my request to create the ""cavalier" perspective.
                  • Is it impossible to create this view with SU?
                  • Or would it be possible to extend the existing AXO-ISO Plugin from TIG?
                  • Or did I ask the question in the wrong section of this forum?
                  • Or are there any other ideas to create this special perspective?
                  I would appreciate any comments
                  Best Regards
                  Automation
                    @automation said:
                    Hello *,
                    Best Regards
                    Automation
                    I don't think that a Cavalier type of view is possible in SketchUp - at least not as a camera setting.
                    It needs to have distorted geometry, which then would only work from one vantage point...
                    My Plugin is therefore NOT extensible...
                    You can ask a question in a related plugin's thread; however, if you want wider public awareness consider starting a new thread in Plugins with a Request for something - but nothing is going to appear instantly ๐Ÿ˜ž ...
                    But if it's a "how-do-I-do-this-by-hand" then post a message in the General forum - some skilled users might not frequent the Plugins side... Someone might have a brilliant workaround that I can't envisage... ๐Ÿ˜ฎ
                      Automation
                      Hi TIG!
                      many thanks for your answer. So I have to find another solution.
                      Best Regards
                      Automation
                        magdales
                        Hi all !
                        Thanks for your axoiso.rb plugin. I had a similarly need for my own video game, so i add some new functions of my own, to get the 8 isometric views from a single model.
                        In order to get my code functional :
                        1ยฐ/ first import one single model and select it.
                        2ยฐ/ then open ruby console. (menu > windows > ruby console)
                        3ยฐ/ write "middle" (to center the object to the axis origin)
                        4ยฐ/ then write "aff" to get all view done with correct distance & angle
                        5-6-7..ยฐ/ then write i1, or i2, or i3 ... or i8 and snapshot the image, to get all 8 classical isometric direction for video game.
                        I'm sure anyone can do better than me on this forum. This was my first contact with Ruby language.
                        I hope this will help someone else ... as much as the axoiso.rb had helped me.
                        Have a nice day !
                        Kรฉkรฉ from Magdales
                        Magdales isometric function
                        • N
                          nicmask
                          It is magic! Thank you so much!!
                            duchaoren
                            If I want iso4545,how can I do it?
                            • OxerO
                              Oxer
                              Great plugin for my exercises about Dihedral System in the High School (I'm a Drawing Teacher), I added a menu via Camera Menu for a quick access.
                              Axo + Iso with menu via Camera Menu
                              • E
                                edoaber
                                Hello TIG,
                                first of all, I want to say this plugin is just great! I am using it every chance I get!
                                I just came across a bit of a problem thought, and I am asking you for help.
                                For my work, I often have the necessity to produce axonometric drawings with shadows.
                                This time I am asked to draw an axonometry from the bottom. So I thought: easy enough! I just need to rotate the model, export in 2D, rotate the canvas again, and voilร !
                                The problem is, my committant wants the shadows too!
                                However, sketchup only allows the shadows to come from the top (which is only logical), so if I rotate the model, and rotate the 2d view again, I would find my self with a picture showing shadows coming from the bottom (which is quite odd).
                                So, my question is, is there a way I can see my axonometry 30-60 from the bottom without having to rotate the model?
                                I tried using ruby console to set the view, but I really don't know what I'm doing...
                                Update: if I open the axo+iso.rb file with notepad I see the parameters "eye" "target" "up" for the three different options (30/60; 60/30; 45/45), how did you calculate those parameter? Is there a way a can calculate mine to put myself in the view I need?
                                  @edoaber
                                  I guess you simply want a negative Z for the eye, so it's then below the ground ?
                                  So you could edit using Notepad++ the eye's Z values thus...
                                  e.g. in line#51
                                  eye=Geom::Point3d.new(-25.3259,-5.00502,463.851)becomes
                                  eye=Geom::Point3d.new(-25.3259,-5.00502,**-**463.851)
                                  Test it and see if that's what's expected...
                                  PS:
                                  The attached RB is a WIP update to v2.0.
                                  Note how the usage has changed to TIG.axo3060 for viewing as usual from above, and TIG.axo3060**(-1)** for from viewing from below.
                                  This applies to all axo/iso view changing operations.
                                  Put the RB file into the Plugins folder to replace the original...
                                  Restart SketchUp...
                                  If it does what you want, then please confirm, and then I might update the PluginStore entry accordingly...
                                  axo+iso.rb
                                  • john2J
                                    john2
                                    Thanks for this awesome plugin! Is there any toolbar version available? I'm used to clicking the huts in the native sketchup toolbar for ISO, Front or Top views. A toolbar will be super awesome. ๐Ÿ‘ ๐Ÿ˜„
                                    Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 โ€“ 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                                    • majidM
                                      majid
                                      Dear TIG,
                                      Thanks for sharing your gems, I was searching exactly the same thing .. but it does not work for me and each time I receive the same error message:
                                      ISO3030
                                      Error: #<NameError: uninitialized constant ISO3030>
                                      <main>:in <main>' SketchUp:1:in eval'
                                        @Majid
                                        This is a very very very old plugin, and could benefit from some modernization and rewriting, but it should still work.
                                        The error appears to come about because you are typing in capital letters ??
                                        Use
                                        iso3030
                                        NOT
                                        ISO3030
                                        • majidM
                                          majid
                                          So tricky, yes it now works! ๐Ÿ˜„ ๐Ÿ˜„ ๐Ÿ˜„
                                            martinhong Newcomers
                                            Dear TIG, bringing this forum back to life a bit, but I downloaded the extension and imported it through my sketchup extension manager. However I don't see the extension anywhere and have re-started my sketchup. Is there a different way I need to import it for it to work?
                                            Thanks!!
                                            • 4 / 5
