    [Plugin] Axo + Iso View v1.2 20101117
    84 Posts 34 Posters 223.1k Views 34 Watching
      Automation
      Hello Everybody,
      actual I have the requirement, to create a "cavalier" perspective.
      http://upload.wikimedia.org/wikipedia/commons/thumb/8/83/Cavalier_perspective_45.svg/480px-Cavalier_perspective_45.svg.png
      I hope that someone can tell me, how to create this view in SU.
      Many thanks!
      Automation
        dmatho
        Yes and Cabinet Oblique Projection too ๐Ÿ˜„
        For ref. see here: https://en.wikipedia.org/wiki/Graphical_projection
        Cheers,
        . DIEGO .
          Automation
          Hello *,
          it would be very nice to get some information concerning my request to create the ""cavalier" perspective.
          • Is it impossible to create this view with SU?
          • Or would it be possible to extend the existing AXO-ISO Plugin from TIG?
          • Or did I ask the question in the wrong section of this forum?
          • Or are there any other ideas to create this special perspective?
          I would appreciate any comments
          Best Regards
          Automation
            @automation said:
            Hello *,
            Best Regards
            Automation
            I don't think that a Cavalier type of view is possible in SketchUp - at least not as a camera setting.
            It needs to have distorted geometry, which then would only work from one vantage point...
            My Plugin is therefore NOT extensible...
            You can ask a question in a related plugin's thread; however, if you want wider public awareness consider starting a new thread in Plugins with a Request for something - but nothing is going to appear instantly ๐Ÿ˜ž ...
            But if it's a "how-do-I-do-this-by-hand" then post a message in the General forum - some skilled users might not frequent the Plugins side... Someone might have a brilliant workaround that I can't envisage... ๐Ÿ˜ฎ
              Automation
              Hi TIG!
              many thanks for your answer. So I have to find another solution.
              Best Regards
              Automation
                magdales
                Hi all !
                Thanks for your axoiso.rb plugin. I had a similarly need for my own video game, so i add some new functions of my own, to get the 8 isometric views from a single model.
                In order to get my code functional :
                1ยฐ/ first import one single model and select it.
                2ยฐ/ then open ruby console. (menu > windows > ruby console)
                3ยฐ/ write "middle" (to center the object to the axis origin)
                4ยฐ/ then write "aff" to get all view done with correct distance & angle
                5-6-7..ยฐ/ then write i1, or i2, or i3 ... or i8 and snapshot the image, to get all 8 classical isometric direction for video game.
                I'm sure anyone can do better than me on this forum. This was my first contact with Ruby language.
                I hope this will help someone else ... as much as the axoiso.rb had helped me.
                Have a nice day !
                Kรฉkรฉ from Magdales
                Magdales isometric function
                • N Offline
                  nicmask
                  It is magic! Thank you so much!!
                    duchaoren
                    If I want iso4545,how can I do it?
                    • OxerO Offline
                      Oxer
                      Great plugin for my exercises about Dihedral System in the High School (I'm a Drawing Teacher), I added a menu via Camera Menu for a quick access.
                      Axo + Iso with menu via Camera Menu
                      • E Offline
                        edoaber
                        Hello TIG,
                        first of all, I want to say this plugin is just great! I am using it every chance I get!
                        I just came across a bit of a problem thought, and I am asking you for help.
                        For my work, I often have the necessity to produce axonometric drawings with shadows.
                        This time I am asked to draw an axonometry from the bottom. So I thought: easy enough! I just need to rotate the model, export in 2D, rotate the canvas again, and voilร !
                        The problem is, my committant wants the shadows too!
                        However, sketchup only allows the shadows to come from the top (which is only logical), so if I rotate the model, and rotate the 2d view again, I would find my self with a picture showing shadows coming from the bottom (which is quite odd).
                        So, my question is, is there a way I can see my axonometry 30-60 from the bottom without having to rotate the model?
                        I tried using ruby console to set the view, but I really don't know what I'm doing...
                        Update: if I open the axo+iso.rb file with notepad I see the parameters "eye" "target" "up" for the three different options (30/60; 60/30; 45/45), how did you calculate those parameter? Is there a way a can calculate mine to put myself in the view I need?
                          @edoaber
                          I guess you simply want a negative Z for the eye, so it's then below the ground ?
                          So you could edit using Notepad++ the eye's Z values thus...
                          e.g. in line#51
                          eye=Geom::Point3d.new(-25.3259,-5.00502,463.851)becomes
                          eye=Geom::Point3d.new(-25.3259,-5.00502,**-**463.851)
                          Test it and see if that's what's expected...
                          PS:
                          The attached RB is a WIP update to v2.0.
                          Note how the usage has changed to TIG.axo3060 for viewing as usual from above, and TIG.axo3060**(-1)** for from viewing from below.
                          This applies to all axo/iso view changing operations.
                          Put the RB file into the Plugins folder to replace the original...
                          Restart SketchUp...
                          If it does what you want, then please confirm, and then I might update the PluginStore entry accordingly...
                          axo+iso.rb
                          • john2J Offline
                            john2
                            Thanks for this awesome plugin! Is there any toolbar version available? I'm used to clicking the huts in the native sketchup toolbar for ISO, Front or Top views. A toolbar will be super awesome. ๐Ÿ‘ ๐Ÿ˜„
                            Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 โ€“ 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                            • majidM Offline
                              majid
                              Dear TIG,
                              Thanks for sharing your gems, I was searching exactly the same thing .. but it does not work for me and each time I receive the same error message:
                              ISO3030
                              Error: #<NameError: uninitialized constant ISO3030>
                              <main>:in <main>' SketchUp:1:in eval'
                                @Majid
                                This is a very very very old plugin, and could benefit from some modernization and rewriting, but it should still work.
                                The error appears to come about because you are typing in capital letters ??
                                Use
                                iso3030
                                NOT
                                ISO3030
                                • majidM Offline
                                  majid
                                  So tricky, yes it now works! ๐Ÿ˜„ ๐Ÿ˜„ ๐Ÿ˜„
                                    martinhong Newcomers
                                    Dear TIG, bringing this forum back to life a bit, but I downloaded the extension and imported it through my sketchup extension manager. However I don't see the extension anywhere and have re-started my sketchup. Is there a different way I need to import it for it to work?
                                    Thanks!!
                                      Usage; type the desired option in Ruby Console xxxxxxx + <enter> ***
                                      Available options are;
                                      axo3060 which sets the camera to a 30/60 axonometric view and zooms extents
                                      axo6030 which sets the camera to a 60/30 axonometric view and zooms extents
                                      axo4545 which sets the camera to a 45/45 axonometric view and zooms extents
                                      iso3030 which sets the camera to a 30/30 isometric view and zooms extents
                                      https://i.imgur.com/1PfdFUh.png
                                      Ruby-Console > axo3060 || axo6030 || axo4545 || iso3030
                                      [See 'More Info...' about adding a menu/toolbar]
                                      If you use Sketchucation Tools then if you search for axo and click the down chevron it will reveal additional info
                                        As an example...
                                        https://i.imgur.com/4na6UuF.png
                                        • 4 / 5
