    [Plugin] Boolean--OSCoolean (Dec 2013) for SU 8 up free ver
    301 Posts 123 Posters 290.3k Views 123 Watching
      Pherim
      Yes, I did.
      • sicksickisckS Offline
        sicksickisck
        don't work! as usual ..if sombody look for good boolens -> http://www.smustard.com/script/BoolTools
        • BoxB Offline
          Works perfectly for me.
            Pherim
            Same here!
              joergber
              I do have a problem with this plugin ...
              Pls. have a look at the attached file!
              I would like to subtract "sub_1" and in a second step "sub_2" from "main".
              But unfortunately it does not work ...
              Many thanks in advance!!!!
              JΓΆrg
              aufnahme_001.skp
                The problem isn't with the plugin, it's with your model.
                It is very small and has hundreds of tiny segments/facets.
                SketchUp's tolerance can't cope with making geometry <~1/1000th"...
                Two points defining the ends of a tiny line can be deemed to be coincident and then no line gets created, and then its face can't exist etc...
                If you scale everything up x1000... it will then 'subtract' OK.
                Afterwards scale down 0.1 and 0.01 [two steps] so it's back to it's original size... OR use the tapemeasure tool and pick two points you know should be 10mm apart and then immediately type 10mm and reply Yes to scaling etc... to rescale back...
                Tiny geometry can exist [like after scaling down] but it can't be made initially.
                  joergber
                  1000 thx!
                  • OscarLokO Offline
                    OscarLok
                    Hello TIG
                    I would like to know that is the SketchUp's tolerance matter be solved if I scale everything up x1000, then do the boolean lastly scale everything down in the OSCoolean for every cases, please?
                    [b:dhgwcjdo][color=#0080BF:dhgwcjdo]JAYA Design & Renovation Sdn. Bhd.[/color:dhgwcjdo][/b:dhgwcjdo] [b:dhgwcjdo][color=#00BF40:dhgwcjdo]T[/color:dhgwcjdo][color=#00BC42:dhgwcjdo]h[/color:dhgwcjdo][color=#00B843:dhgwcjdo]e[/color:dhgwcjdo] [color=#00B247:dhgwcjdo]e[/color:dhgwcjdo][color=#00AE48:dhgwcjdo]x[/color:dhgwcjdo][color=#00AB4A:dhgwcjdo]p[/color:dhgwcjdo][color=#00A84C:dhgwcjdo]e[/color:dhgwcjdo][color=#00A44D:dhgwcjdo]r[/color:dhgwcjdo][color=#00A14F:dhgwcjdo]t[/color:dhgwcjdo] [color=#009A53:dhgwcjdo]i[/color:dhgwcjdo][color=#009754:dhgwcjdo]n[/color:dhgwcjdo] [color=#009058:dhgwcjdo]c[/color:dhgwcjdo][color=#008D59:dhgwcjdo]u[/color:dhgwcjdo][color=#008A5B:dhgwcjdo]s[/color:dhgwcjdo][color=#00865D:dhgwcjdo]t[/color:dhgwcjdo][color=#00835E:dhgwcjdo]o[/color:dhgwcjdo][color=#008060:dhgwcjdo]m[/color:dhgwcjdo][color=#007C62:dhgwcjdo]i[/color:dhgwcjdo][color=#007963:dhgwcjdo]z[/color:dhgwcjdo][color=#007565:dhgwcjdo]e[/color:dhgwcjdo][color=#007267:dhgwcjdo]d[/color:dhgwcjdo] [color=#006B6A:dhgwcjdo]o[/color:dhgwcjdo][color=#00686C:dhgwcjdo]f[/color:dhgwcjdo][color=#00656D:dhgwcjdo]f[/color:dhgwcjdo][color=#00616F:dhgwcjdo]i[/color:dhgwcjdo][color=#005E71:dhgwcjdo]c[/color:dhgwcjdo][color=#005B73:dhgwcjdo]e[/color:dhgwcjdo] [color=#005476:dhgwcjdo]s[/color:dhgwcjdo][color=#005178:dhgwcjdo]y[/color:dhgwcjdo][color=#004D79:dhgwcjdo]s[/color:dhgwcjdo][color=#004A7B:dhgwcjdo]t[/color:dhgwcjdo][color=#00477D:dhgwcjdo]e[/color:dhgwcjdo][color=#00437E:dhgwcjdo]m[/color:dhgwcjdo][color=#004080:dhgwcjdo].[/color:dhgwcjdo][/b:dhgwcjdo]
                    • jolranJ Offline
                      jolran
                      I wonder too.
                      But is it not possible to bump vertices position out of Sketchup's tolerance while scaling geometry ? That must affect intersections and such too, not only the factor of edges length.
                      Still trying to wrap my head around this..
                        @Oscar
                        It will usually work. πŸ˜•
                        BUT remember that SketchUp also has issues in the other direction - so both very tiny and very gigantic sizes can cause issues...
                        In my recent Pro only 'CutNfill' tool I used a scale-up/intersect/scale-down, but only if the processed object's bounds.diagonal are smaller that a specific size [of the top of my head I think it's 100.m].
                        That way I never make it so big that I get issues in the opposite direction from 'tiny'...
                        Because your tool is used on a wide variety of forms... perhaps you could have a scale factor of x1000 for very tiny objects, x100 for medium size, x10 for large and x1 for overly large... πŸ’­
                          togethearth
                          For me, it was working for SU8 but not 2013.
                          I removed some plugins from the SU2013 plugin folder and identified sketchyphysics as not compatible with OsCoolean.
                          It may happens with other plugins too because of badly named variables usually.
                            SketchyPhysics and some other 'rogue' plugins are know to cause issues, because they mess with native classes/methods ill-advisedly... sometimes messing with the way some Group methods work, others have Observers that can cause issues too...
                            Then an innocent third-party plugin can fail or even cause SketchUp to BugSplat [it's usually a 'rogue' observer that splats!].
                            There's a rogue / quarantine list...
                              So make some special Plugins folders with only sketchyphisics, Windowizer,... inside! πŸ˜‰
                              Just careful to not lost the original Plugins folder! πŸ€“
                              • kmlkrkK Offline
                                kmlkrk
                                Hi, does your extension work in SketchUp 2014? I have successfully installed it, added buttons to my toolbar but I can't use it in any way. I tried making my objects to be groups and components, I tried selecting them first and tried clicking on plugin's button first. Nothing ever happens.
                                What am I doing wrong?
                                I would greatly appreciate your help!
                                • kmlkrkK Offline
                                  kmlkrk
                                  In addition to my previous comment: in case that this plugin does not work with SketchUp 2014, does anybody know where can I download SketchUp 2013? It is no longer hosted on official downloads page
                                  • BoxB Offline
                                    All versions are available to download http://www.sketchup.com/download/all
                                      If you PM the author with some useful data, then he might be able to easily update his plugin to be v2014 compatible.
                                      Unfortunately you decided to give none of us any clue at all as to the errors you encountered.
                                      Naturally these might be helpful when formulating a fix...
                                      This particular plugin is encrypted as rbs, so we can't see what it's doing internally...
                                      But most Plugins can be easily updated and re-encrypted to suit all SketchUp versions...
                                      • kmlkrkK Offline
                                        kmlkrk
                                        Unfortunately that page does not have a link for SketchUp Make 2013. Only the pro version. However I already found a way to download 2013 version and I will be using it for now.
                                        However, it would be amazing if this great plugin worked for 2014 version. Many thanks to developer for his hard work!
                                        EDIT: Looks like I can't open model built in SketchUp 2014 in 2013 version 😞 I will wait and hope that the developer releases update to his plugin soon. Thanks
                                        • kmlkrkK Offline
                                          kmlkrk
                                          Hey Tig, sorry for not including any errors. I am newbie in SketchUp and I did not see any error messages. The tool just does nothing 😞 Is there a way to generate a log of errors? I will be more than happy to help get this working for 2014 version!
                                          EDIT: Nothing shows up in ruby console. No errors there. Not sure where else to look
                                          • BoxB Offline
                                            You can save as back to earlier versions.
                                            Open the file in 2014, go save as and select the earlier version in the drop down.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 13 / 16
