    [Plugin] Boolean--OSCoolean (Dec 2013) for SU 8 up free ver
    301 Posts 123 Posters 300.0k Views 123 Watching
    • OscarLokO
      OscarLok
      Hello,
      OSCoolean Dec 2013 version for both groups & components is uploaded in the first post - or as RBZ from the PluginStore...
      And it is still free to use.
      Hope this can help!
      Enjoy! 😍
      Regards
      Oscar
      [b:dhgwcjdo][color=#0080BF:dhgwcjdo]JAYA Design & Renovation Sdn. Bhd.[/color:dhgwcjdo][/b:dhgwcjdo] [b:dhgwcjdo][color=#00BF40:dhgwcjdo]T[/color:dhgwcjdo][color=#00BC42:dhgwcjdo]h[/color:dhgwcjdo][color=#00B843:dhgwcjdo]e[/color:dhgwcjdo] [color=#00B247:dhgwcjdo]e[/color:dhgwcjdo][color=#00AE48:dhgwcjdo]x[/color:dhgwcjdo][color=#00AB4A:dhgwcjdo]p[/color:dhgwcjdo][color=#00A84C:dhgwcjdo]e[/color:dhgwcjdo][color=#00A44D:dhgwcjdo]r[/color:dhgwcjdo][color=#00A14F:dhgwcjdo]t[/color:dhgwcjdo] [color=#009A53:dhgwcjdo]i[/color:dhgwcjdo][color=#009754:dhgwcjdo]n[/color:dhgwcjdo] [color=#009058:dhgwcjdo]c[/color:dhgwcjdo][color=#008D59:dhgwcjdo]u[/color:dhgwcjdo][color=#008A5B:dhgwcjdo]s[/color:dhgwcjdo][color=#00865D:dhgwcjdo]t[/color:dhgwcjdo][color=#00835E:dhgwcjdo]o[/color:dhgwcjdo][color=#008060:dhgwcjdo]m[/color:dhgwcjdo][color=#007C62:dhgwcjdo]i[/color:dhgwcjdo][color=#007963:dhgwcjdo]z[/color:dhgwcjdo][color=#007565:dhgwcjdo]e[/color:dhgwcjdo][color=#007267:dhgwcjdo]d[/color:dhgwcjdo] [color=#006B6A:dhgwcjdo]o[/color:dhgwcjdo][color=#00686C:dhgwcjdo]f[/color:dhgwcjdo][color=#00656D:dhgwcjdo]f[/color:dhgwcjdo][color=#00616F:dhgwcjdo]i[/color:dhgwcjdo][color=#005E71:dhgwcjdo]c[/color:dhgwcjdo][color=#005B73:dhgwcjdo]e[/color:dhgwcjdo] [color=#005476:dhgwcjdo]s[/color:dhgwcjdo][color=#005178:dhgwcjdo]y[/color:dhgwcjdo][color=#004D79:dhgwcjdo]s[/color:dhgwcjdo][color=#004A7B:dhgwcjdo]t[/color:dhgwcjdo][color=#00477D:dhgwcjdo]e[/color:dhgwcjdo][color=#00437E:dhgwcjdo]m[/color:dhgwcjdo][color=#004080:dhgwcjdo].[/color:dhgwcjdo][/b:dhgwcjdo]
      • gillesG
        gilles
        Happy christmas!
          Bravo! 😎
          • P
            Pherim
            Just wanted to say that this was not shown as an update in Plugin Store, I just saw it among the recent Plugins.
              It IS in the Recent list in the PluginStore.
              As a Windows user ensure you have IE Internet-options set to clear its cache on closing...
              If old data gets stuck in IE you can find that the dilaog entries are formed from cacahed data on your PC ?
              • P
                Pherim
                Yes it is in the recent list but it was not shown as an update in "My Plugins" and just wanted to report.
                  Did you download/install the previous version from the PluginStore ?
                  If so the Update should have been signaled... πŸ˜•
                  But if not 'we' have no way of knowing what you might have previously installed manually - so not notification would be expected... πŸ˜’
                  • P
                    Pherim
                    Yes, I did.
                    • sicksickisckS
                      sicksickisck
                      don't work! as usual ..if sombody look for good boolens -> http://www.smustard.com/script/BoolTools
                      • BoxB
                        Works perfectly for me.
                        • P
                          Pherim
                          Same here!
                            joergber
                            I do have a problem with this plugin ...
                            Pls. have a look at the attached file!
                            I would like to subtract "sub_1" and in a second step "sub_2" from "main".
                            But unfortunately it does not work ...
                            Many thanks in advance!!!!
                            JΓΆrg
                            aufnahme_001.skp
                              The problem isn't with the plugin, it's with your model.
                              It is very small and has hundreds of tiny segments/facets.
                              SketchUp's tolerance can't cope with making geometry <~1/1000th"...
                              Two points defining the ends of a tiny line can be deemed to be coincident and then no line gets created, and then its face can't exist etc...
                              If you scale everything up x1000... it will then 'subtract' OK.
                              Afterwards scale down 0.1 and 0.01 [two steps] so it's back to it's original size... OR use the tapemeasure tool and pick two points you know should be 10mm apart and then immediately type 10mm and reply Yes to scaling etc... to rescale back...
                              Tiny geometry can exist [like after scaling down] but it can't be made initially.
                                joergber
                                1000 thx!
                                • OscarLokO
                                  OscarLok
                                  Hello TIG
                                  I would like to know that is the SketchUp's tolerance matter be solved if I scale everything up x1000, then do the boolean lastly scale everything down in the OSCoolean for every cases, please?
                                  • jolranJ
                                    jolran
                                    I wonder too.
                                    But is it not possible to bump vertices position out of Sketchup's tolerance while scaling geometry ? That must affect intersections and such too, not only the factor of edges length.
                                    Still trying to wrap my head around this..
                                      @Oscar
                                      It will usually work. πŸ˜•
                                      BUT remember that SketchUp also has issues in the other direction - so both very tiny and very gigantic sizes can cause issues...
                                      In my recent Pro only 'CutNfill' tool I used a scale-up/intersect/scale-down, but only if the processed object's bounds.diagonal are smaller that a specific size [of the top of my head I think it's 100.m].
                                      That way I never make it so big that I get issues in the opposite direction from 'tiny'...
                                      Because your tool is used on a wide variety of forms... perhaps you could have a scale factor of x1000 for very tiny objects, x100 for medium size, x10 for large and x1 for overly large... πŸ’­
                                      • T
                                        togethearth
                                        For me, it was working for SU8 but not 2013.
                                        I removed some plugins from the SU2013 plugin folder and identified sketchyphysics as not compatible with OsCoolean.
                                        It may happens with other plugins too because of badly named variables usually.
                                          SketchyPhysics and some other 'rogue' plugins are know to cause issues, because they mess with native classes/methods ill-advisedly... sometimes messing with the way some Group methods work, others have Observers that can cause issues too...
                                          Then an innocent third-party plugin can fail or even cause SketchUp to BugSplat [it's usually a 'rogue' observer that splats!].
                                          There's a rogue / quarantine list...
                                            So make some special Plugins folders with only sketchyphisics, Windowizer,... inside! πŸ˜‰
                                            Just careful to not lost the original Plugins folder! πŸ€“
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 13 / 16
