    [Plugin] Super Drape
    192 Posts 54 Posters 356.2k Views 54 Watching
      AcesHigh
      well, it worked when first using normal DRAPE and then using SuperDrape. Cant you add the code from normal DRAPE to your plugin to perform the first operation, then your plugin only does the second operation (material transfer)???
        My 'SuperDrape' does a [supposedly better] version of 'Drape' before adding the materials...
        Clearly in your case it isn't πŸ˜’
          Here's v1.6 http://forums.sketchucation.com/viewtopic.php?p=358314#p358314
          It has improved methods for ensuring full intersection of the forms... as a result of AcesHigh's feedback issue with a draped road that was longer than the mesh below it failing to form proper edges...
            Luigi987
            Been trying this for a bit, works great in most cases, but when I tried to drape a road to a smooved group, this happened...
            http://puu.sh/7oge
            I'm using the latest revision as of 22/10.
            Thanks~! :3
              Can you post the SKP so that I can test it πŸ˜•
                Luigi987
                Right, here it is:
                test.skp
                  The faces are all backwards. [see enhanced rear-face material 'blue']Capture.PNG
                  I checked the size of the model for very small or very large dimensions.
                  The mesh is 10s of thousands of feet across!
                  I scaled the model to a more realistic size and re-SuperDraped, this time it's fine...Capture3.PNG
                    Luigi987
                    Alright, that fixed it for me too, thanks~!
                      shri
                      great plugin indeed.thanks a lot for sharing.
                      but.when i tried with text it did'nt worked.then
                      i exploded the text and make it group again and super draped it worked
                      on sphere it worked.and in case of cylinder the text didn't make plane.
                      please help..
                      super drape
                        Shri, can you share the test model?
                        What is the scale of the objects? Are they very small by any chance?
                          Very small and very large objects do sometimes have issues.
                          Please share the problem SKP so that I can check it out...
                            tulacong
                            oh yehh 😍 thank you
                              shri
                              hi TIG. i usually work in millimeters.i also tried it with increasing the
                              segments of the circle but again it did'nt worked.i also tried it with sketchyphics
                              installed and got extruded text over the cylinder but what i need is a coplaner text over
                              the cylinder.
                              here is the attachment of the test model.
                              thanks.
                              shri
                              's super drape test.skp
                                It's not the units you use but rather the physical size of the objects that can cause issues.
                                However, the SKP you supplied is a 'proper' size so it should cause those problems.
                                Your lettering faces are 'upside down' but again that shouldn't usually cause issues...
                                Some of your 'drapee' groups are colored by applying a material to the group [e.g. the golden cylinder] i.e. rather than having materials applied to its internal faces, so superdraping 'nil' materialed faces will only add an outline and the group's color will still be seen.
                                Some of your 'drapee' surfaces are 'upside down' although they do have materials applied to both faces [e.g. the green bumpy terrain] when they are superdraped the outlines appear but seem to have not taken the draper's color BUT the re-colored faces are underneath on the faces' fronts ! - reverse the faces in the mesh and redo.
                                There have been issues with 'lettering' containing curved shapes Draping or SuperDraping onto cylindrical forms successfully...
                                I'll investigate and see what I can tweak... πŸ˜•
                                  Here's v1.7 http://forums.sketchucation.com/viewtopic.php?p=358314#p358314
                                  The intersecting method is now much more robust, and several recently reported glitches should now be resolved.
                                    smb5823
                                    Sketchup 8 PRO seems to crash once Superdrape.rb is added to the Plugins folder. Was the same with V1.6 but earlier versions were fine.
                                      TIG, that worked perfectly for me. Thank you.
                                      • W Offline
                                        wyatt
                                        1.7 gets stuck calculating for me.
                                        WARNING: make_unique is a deprecated methodof Sketchup:Group
                                        Error: #<NameError: undefined local variable or method nsedges' for #<TIG::Superdrape:0x135cef64>> C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TIG-Superdrape.rb:303:in drape'
                                        C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TIG-Superdrape.rb:296:in each' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TIG-Superdrape.rb:296:in drape'
                                        C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TIG-Superdrape.rb:121:in `onLButtonDown'
                                          Here's v1.8 http://forums.sketchucation.com/viewtopic.php?p=358314#p358314
                                          [I hope] it fixes the daft typo that I made that could occasional trip it up...
                                          The new code should be much faster than before, and [now] more robust...
                                          πŸ˜•
                                          Feedback please...
                                          • W Offline
                                            wyatt
                                            Hey Tig. 1.8 works sometimes, sometimes not. When it fails, the plugin appears to draw the physical geometry that intersects with the terrain below, but does not delete the geometry or drape the colors. I assume those actions are normally run in the background, but somehow they're happening in the model. I get this error: Error: #<TypeError: reference to deleted Edge>. If I undo and try it again, it will sometimes work; sometimes I have to explode the draped group and regroup it before it will work.
                                            SuperDrapeFail.skp
                                            • 5 / 10
