    [Plugin] Super Drape
    192 Posts 54 Posters 368.9k Views 54 Watching
      Try it again with Hidden Geometry ON - or post the example SKP...
        AcesHigh
        tried with Hidden Geometry On, but problem persisted.
        I am attaching the file below...
        teste.rar
          Looked at it and I agree it's flaky...
          I can't see what the issue is immediately.
          I'll investigate 😕
            AcesHigh
            well, it worked when first using normal DRAPE and then using SuperDrape. Cant you add the code from normal DRAPE to your plugin to perform the first operation, then your plugin only does the second operation (material transfer)???
              My 'SuperDrape' does a [supposedly better] version of 'Drape' before adding the materials...
              Clearly in your case it isn't 😒
                Here's v1.6 http://forums.sketchucation.com/viewtopic.php?p=358314#p358314
                It has improved methods for ensuring full intersection of the forms... as a result of AcesHigh's feedback issue with a draped road that was longer than the mesh below it failing to form proper edges...
                  Luigi987
                  Been trying this for a bit, works great in most cases, but when I tried to drape a road to a smooved group, this happened...
                  http://puu.sh/7oge
                  I'm using the latest revision as of 22/10.
                  Thanks~! :3
                    Can you post the SKP so that I can test it 😕
                      Luigi987
                      Right, here it is:
                      test.skp
                        The faces are all backwards. [see enhanced rear-face material 'blue']Capture.PNG
                        I checked the size of the model for very small or very large dimensions.
                        The mesh is 10s of thousands of feet across!
                        I scaled the model to a more realistic size and re-SuperDraped, this time it's fine...Capture3.PNG
                          Luigi987
                          Alright, that fixed it for me too, thanks~!
                            shri
                            great plugin indeed.thanks a lot for sharing.
                            but.when i tried with text it did'nt worked.then
                            i exploded the text and make it group again and super draped it worked
                            on sphere it worked.and in case of cylinder the text didn't make plane.
                            please help..
                            super drape
                              Shri, can you share the test model?
                              What is the scale of the objects? Are they very small by any chance?
                                Very small and very large objects do sometimes have issues.
                                Please share the problem SKP so that I can check it out...
                                  tulacong
                                  oh yehh 😍 thank you
                                    shri
                                    hi TIG. i usually work in millimeters.i also tried it with increasing the
                                    segments of the circle but again it did'nt worked.i also tried it with sketchyphics
                                    installed and got extruded text over the cylinder but what i need is a coplaner text over
                                    the cylinder.
                                    here is the attachment of the test model.
                                    thanks.
                                    shri
                                    's super drape test.skp
                                      It's not the units you use but rather the physical size of the objects that can cause issues.
                                      However, the SKP you supplied is a 'proper' size so it should cause those problems.
                                      Your lettering faces are 'upside down' but again that shouldn't usually cause issues...
                                      Some of your 'drapee' groups are colored by applying a material to the group [e.g. the golden cylinder] i.e. rather than having materials applied to its internal faces, so superdraping 'nil' materialed faces will only add an outline and the group's color will still be seen.
                                      Some of your 'drapee' surfaces are 'upside down' although they do have materials applied to both faces [e.g. the green bumpy terrain] when they are superdraped the outlines appear but seem to have not taken the draper's color BUT the re-colored faces are underneath on the faces' fronts ! - reverse the faces in the mesh and redo.
                                      There have been issues with 'lettering' containing curved shapes Draping or SuperDraping onto cylindrical forms successfully...
                                      I'll investigate and see what I can tweak... 😕
                                        Here's v1.7 http://forums.sketchucation.com/viewtopic.php?p=358314#p358314
                                        The intersecting method is now much more robust, and several recently reported glitches should now be resolved.
                                          smb5823
                                          Sketchup 8 PRO seems to crash once Superdrape.rb is added to the Plugins folder. Was the same with V1.6 but earlier versions were fine.
                                            TIG, that worked perfectly for me. Thank you.
                                            • 5 / 10
