    Tutorial for Extrude Tools
    32 Posts 12 Posters 6.6k Views 12 Watching
    • simon le bonS Offline
      simon le bon
      "Come on" Arjun,
      My EEbRbF sudies are not so complicated if you take time to follow each step.( But May be are they a little confused. 😳 ) I had made them with the purpose to predict things. If you try by yourself you will be led to discover the same results. What I had done is just time saving for SU users who have not a lot of time 😉
      at least EEbRbF is not simple, and I guess TIG will make it evolute in time.
      I see you very active in SCF, I guess you will not be a novice for long 😉
      *simon
        Seems to me that each images of start TIG threads is sufficient and very well explained for anybody!
        And very well drawn ! ☀
        Where are you block?
          arjunmax09
          @simon le bon said:
          "Come on" Arjun,
          *simon
          yeah. .... i know..and video tutorials rock man!!! no can beat ever the video tutorials especially if it is something like extrude tools!!! take for example the sketchup basecamp seminar videos on youtube...!!! awesome x 10000000000.!!!! supercoool man....if anyone using sketchup hasn't seen them..i strongly recommend him/her to do so..
          when you fail at something....you haven't really failed...you've found one way the thing will not work out
            Migmat
            @arjunmax09 said:
            Does anyone know this plugin's video tutorial link?? or any pdf file giving tutorials in this plugin??. I"m new to this plugin and finding to work efficiently with it a bit complicated...
            Yust I wrote a tutorial for this excelent plugin of TIG. I am doing the final details and I will post the link to download the full tutorial.
            I hope that I can do in a couple of days as long.
            Bye.
              Migmat
              Soon as I espect, I can present you the TUTORIAL
              This is the link in Uploaded To.
              http://ul.to/tkzqyvkv
              This other link is the tutorial in miniatures for initial review.
              http://ul.to/iycf9dzj
              I hope that help to everybody to use more easily this excelent plugin of TIG.
                Migmat
                I am trying to downolad my own file with the previous links and is no so easy as I thougth.
                When I open the link and push on "Normal Dowload" the Explorer open a new window (Advertise) and start a 30 second countdown to download. Hen finish a pop-up window ask me for save the file.
                Sometimes, UploadedTo open two advertises windows previous the download, and only permit one download per hour.
                I am no very happy with that, because I feel tha is not very clean process, but for the moment is that I have. Sorry.
                  @Miguel
                  Thanks for making the tutorials...
                  However, you are making your life more complicated that it needs to be.
                  Your jpg could be added directly to a post as it is small enough.
                  The PDF is too large to attach...
                  Limit is ~4Mb... could you reduce its quality so it's just small enough...
                  But a 'movie' could be hosted on YouTube - then you could add a link in a post - so then it'd be viewable within SketchUcation...
                  It seems a pity to make access to your hard work so difficult...
                    Migmat
                    @tig said:
                    @Miguel
                    Thanks for the advice. I'll try to upload the images of the Tutorial in several post.
                    I no ned to say that the resolution of the images in this case are notably lower, but in any case you can download the original tutorial in Hi-Res PDF with the previous link (more complex also).
                    TUTORIAL EXTRUDE TOOLS
                    First 5 pages
                    Page 1 Tutorial Extrude TOOLS
                    Page 2 Tutorial Extrude TOOLS
                    Page 3 Tutorial Extrude TOOLS
                    Page 4 Tutorial Extrude TOOLS
                    Page 5 Tutorial Extrude TOOLS
                      Migmat
                      EXTRUDE TOOLS TUTORIAL
                      The second part of the tutorial (5 pages )
                      NOTE: The first page is the page 0. There is 10 pages at all (0....9)
                      Page 6 EXTRUDE TOOLS TUTORIAL
                      Page 7 EXTRUDE TOOLS TUTORIAL
                      Page 8 EXTRUDE TOOLS TUTORIAL
                      Page 9 EXTRUDE TOOLS TUTORIAL
                      Page 10 EXTRUDE TOOLS TUTORIAL
                        Migmat
                        Well TIG, I did it as you say!
                        Now I would like to know your comments, because at last you are the creator of the plugin.
                        What Erase,Change or modify ?
                          Thanks, it is pretty good and comprehensive. 😄
                          One niggle... the toolbar is not the current one ?
                          The buttons are now reordered in the likelihood of most usage...
                            Migmat
                            The tool bar is that I have in my sketchup2013, but I'll try to get the toolbar that you say.
                              It might be... BUT the latest version of the toolset available from The SketchUcation Plugin Store has evolved... it has a reordered toolbar and several future-proofing tweaks - I recommend you get it asap...
                              The core usage and tools have not changed however so your tut' is 99.9% applicable - just update any toolbar images... 😄
                                Thanks for the tutorial. I like the title, "Extrusions of TIG". It has a nice ring to it.
                                • U Offline
                                  unearthed
                                  Thanks Migmat for exploring and showing us how to use this very useful tool.
                                  Growplan - People ∩ Plants ∩ Place
                                  windows 7 64b, 4GB RAM, SU 8.0.16846
                                  Gimp, QGIS, Vectorworks 12, Bricscad 11
                                    mwm5053
                                    Thanks Migmat for doing this, makes it easy to understand 👍
                                    2011 iMac
                                    SU 2015 Pro, 2017 Make
                                    V2 Twilight
                                    macOS Sierra 10.12.5
                                      Cool tutorials of a very vertsatile plugin! 😎
                                        Migmat
                                        Hello Again;
                                        I finish the Extrude Tools V2.2 Tutorial in English and Spanish versions.
                                        This time the PDF files is lower tan 4 Mb and can be uploaded to Skechucation.
                                        Also I include the JPG versión in next post of the English version.
                                        I hope you make useful.
                                        EXTRUDE TOOLS V2.2 TUTORIAL V14 ENGLISH
                                        EXTRUDE TOOLS V2.2 TUTORIAL V11 SPANISH
                                          Migmat
                                          Here I Wil try to include the versión JPG of the tutorial EXTRUDE TOOLS V2.2, but previously...
                                          Even knowin the titanic effort that supose to modify someting in a relatively old code,I would like to suggest to TIG three minor (or giant?) modifications that could make improve the plugin from perfect to universal.
                                          Posible modifications:
                                          1- In EXTRUDE EDGES BY LOFT, make posible to work with Closed Curves (like Curviloft)
                                          2- In EXTRUDE EDGES BY EDGES, make posible to select a Edge as path (not only a Curve)
                                          3- In EXTRUDE EDGES BY FACE, make posible to choose a profile in any plane (not limited to XY plane)
                                          Anyway, THANKS TIG for your excelent work.
                                          Now the JPG version
                                          Page 2 EXTRUDE TOOLS V2.2 TUTORIAL V14 ENGLISH
                                          Page 3 EXTRUDE TOOLS V2.2 TUTORIAL V14 ENGLISH
                                          Page 4 EXTRUDE TOOLS V2.2 TUTORIAL V14 ENGLISH
                                          Page 5 EXTRUDE TOOLS V2.2 TUTORIAL V14 ENGLISH
                                          Page 6 EXTRUDE TOOLS V2.2 TUTORIAL V14 ENGLISH
                                            Migmat
                                            The second part of EXTRUDE TOOLS V2.2 TUTORIAL V14 ENGLISH
                                            (Pages 7 to 12)
                                            Page 7 EXTRUDE TOOLS V2.2 TUTORIAL V14 ENGLISH
                                            Page 8 EXTRUDE TOOLS V2.2 TUTORIAL V14 ENGLISH
                                            Page 9 EXTRUDE TOOLS V2.2 TUTORIAL V14 ENGLISH
                                            Page 10 EXTRUDE TOOLS V2.2 TUTORIAL V14 ENGLISH
                                            Page 11 EXTRUDE TOOLS V2.2 TUTORIAL V14 ENGLISH
                                            Page 12 (end) EXTRUDE TOOLS V2.2 TUTORIAL V14 ENGLISH
                                            • 2 / 2
