    [Plugin] Boolean--OSCoolean (Dec 2013) for SU 8 up free ver
    301 Posts 123 Posters 306.8k Views 123 Watching
      Migmat
      Perfect work Oscar.
      I am asking me if your plugin do the same as the SU2013 Pro with solids.
      I feel your plugin more clear and clean.
      Would you think to export for the new SU 2013 versión?.
      Me and many people will like it.
      Anyway thanks for your fine work.
      • OscarLokO
        OscarLok
        Thanks for your support and encourage.
        I will review my script for SU 2013 at December since my schedule is busy now.
        Again, thanks for your support!
        [b:dhgwcjdo][color=#0080BF:dhgwcjdo]JAYA Design & Renovation Sdn. Bhd.[/color:dhgwcjdo][/b:dhgwcjdo] [b:dhgwcjdo][color=#00BF40:dhgwcjdo]T[/color:dhgwcjdo][color=#00BC42:dhgwcjdo]h[/color:dhgwcjdo][color=#00B843:dhgwcjdo]e[/color:dhgwcjdo] [color=#00B247:dhgwcjdo]e[/color:dhgwcjdo][color=#00AE48:dhgwcjdo]x[/color:dhgwcjdo][color=#00AB4A:dhgwcjdo]p[/color:dhgwcjdo][color=#00A84C:dhgwcjdo]e[/color:dhgwcjdo][color=#00A44D:dhgwcjdo]r[/color:dhgwcjdo][color=#00A14F:dhgwcjdo]t[/color:dhgwcjdo] [color=#009A53:dhgwcjdo]i[/color:dhgwcjdo][color=#009754:dhgwcjdo]n[/color:dhgwcjdo] [color=#009058:dhgwcjdo]c[/color:dhgwcjdo][color=#008D59:dhgwcjdo]u[/color:dhgwcjdo][color=#008A5B:dhgwcjdo]s[/color:dhgwcjdo][color=#00865D:dhgwcjdo]t[/color:dhgwcjdo][color=#00835E:dhgwcjdo]o[/color:dhgwcjdo][color=#008060:dhgwcjdo]m[/color:dhgwcjdo][color=#007C62:dhgwcjdo]i[/color:dhgwcjdo][color=#007963:dhgwcjdo]z[/color:dhgwcjdo][color=#007565:dhgwcjdo]e[/color:dhgwcjdo][color=#007267:dhgwcjdo]d[/color:dhgwcjdo] [color=#006B6A:dhgwcjdo]o[/color:dhgwcjdo][color=#00686C:dhgwcjdo]f[/color:dhgwcjdo][color=#00656D:dhgwcjdo]f[/color:dhgwcjdo][color=#00616F:dhgwcjdo]i[/color:dhgwcjdo][color=#005E71:dhgwcjdo]c[/color:dhgwcjdo][color=#005B73:dhgwcjdo]e[/color:dhgwcjdo] [color=#005476:dhgwcjdo]s[/color:dhgwcjdo][color=#005178:dhgwcjdo]y[/color:dhgwcjdo][color=#004D79:dhgwcjdo]s[/color:dhgwcjdo][color=#004A7B:dhgwcjdo]t[/color:dhgwcjdo][color=#00477D:dhgwcjdo]e[/color:dhgwcjdo][color=#00437E:dhgwcjdo]m[/color:dhgwcjdo][color=#004080:dhgwcjdo].[/color:dhgwcjdo][/b:dhgwcjdo]
          jx2013
          Does this OSCoolean even work with Sketchup 8.0.16846? I put the .rbs into plugin folder, restarted Sketchup, I don't see any new tools or in the rightclick menu. How do you install this?
            Renaissance Man
            Hi Jo,
            Your post implies that you have been able to get the OSCoolean plugin to work with SketchUp 2013. Is this correct? Good for you! I, along with the rest of the planet have been unable to use OSCoolean due to version checking code. What was your workaround? The only functionality missing from the free version of SketchUp that I need are the boolean solid features. Are you aware of any other versions that are available either as a download or for purchase?
            Best of luck
            Greg
              As far as I know it works in v8.
              But because the SketchUp version check is encrypted it isn't adjustable.
              I think what it's doing is comparing the version as a string and finding "13..." < "8..." [which it is] - the simple fix is to compare them as floats [to_f] then 13 > 8 !
              The author could issue a quick update so v2013 and later were supported ???
              • OscarLokO
                OscarLok
                Hello,
                OSCoolean Dec 2013 version for both groups & components is uploaded in the first post - or as RBZ from the PluginStore...
                And it is still free to use.
                Hope this can help!
                Enjoy! 😍
                Regards
                Oscar
                • gillesG
                  gilles
                  Happy christmas!
                    Bravo! 😎
                    • P
                      Pherim
                      Just wanted to say that this was not shown as an update in Plugin Store, I just saw it among the recent Plugins.
                        It IS in the Recent list in the PluginStore.
                        As a Windows user ensure you have IE Internet-options set to clear its cache on closing...
                        If old data gets stuck in IE you can find that the dilaog entries are formed from cacahed data on your PC ?
                        • P
                          Pherim
                          Yes it is in the recent list but it was not shown as an update in "My Plugins" and just wanted to report.
                            Did you download/install the previous version from the PluginStore ?
                            If so the Update should have been signaled... 😕
                            But if not 'we' have no way of knowing what you might have previously installed manually - so not notification would be expected... 😒
                            • P
                              Pherim
                              Yes, I did.
                              • sicksickisckS
                                sicksickisck
                                don't work! as usual ..if sombody look for good boolens -> http://www.smustard.com/script/BoolTools
                                • BoxB
                                  Works perfectly for me.
                                  • P
                                    Pherim
                                    Same here!
                                      joergber
                                      I do have a problem with this plugin ...
                                      Pls. have a look at the attached file!
                                      I would like to subtract "sub_1" and in a second step "sub_2" from "main".
                                      But unfortunately it does not work ...
                                      Many thanks in advance!!!!
                                      Jörg
                                      aufnahme_001.skp
                                        The problem isn't with the plugin, it's with your model.
                                        It is very small and has hundreds of tiny segments/facets.
                                        SketchUp's tolerance can't cope with making geometry <~1/1000th"...
                                        Two points defining the ends of a tiny line can be deemed to be coincident and then no line gets created, and then its face can't exist etc...
                                        If you scale everything up x1000... it will then 'subtract' OK.
                                        Afterwards scale down 0.1 and 0.01 [two steps] so it's back to it's original size... OR use the tapemeasure tool and pick two points you know should be 10mm apart and then immediately type 10mm and reply Yes to scaling etc... to rescale back...
                                        Tiny geometry can exist [like after scaling down] but it can't be made initially.
                                          joergber
                                          1000 thx!
                                          • OscarLokO
                                            OscarLok
                                            Hello TIG
                                            I would like to know that is the SketchUp's tolerance matter be solved if I scale everything up x1000, then do the boolean lastly scale everything down in the OSCoolean for every cases, please?
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 12 / 16
