    [Plugin] RichSection V0.5.8 UPDATED march 2015
    395 Posts 85 Posters 184.8k Views 85 Watching
      pgarmyn
      @mladen90 said:
      I haven't change my date on PC.
      I have resources folder, RichSection.rbs and RichSectionLicence.rb in folder you mentioned.
      I have had experienced similar thing with RealSection, but that was common problem ( It truly had expired and nobody continued to work on it). I guess RichSection doesn't use any of RealSections libs? Could this be the problem?
      Thanks for your quick reply.
      Strange, you are the first having this problem after 380 downloads!
      The RichSection plugin can't interfere with other plugins.
      When did you got this message. Directly after putting the first RichSection? .... When updating?
      Can you switch 'on' logging in the menu (plugins/RichSection/settings) and open the ruby console.
      What is printed in the Ruby console, when you place a RichSection... ❓
        mladen90
        Wow! Astonishing new video. Just what I imagined it cold be done with RichS.
        Considering expiration problem. I did enable logging.
        It happens when I try to make real section (via menu-bar or right click).
        Here is the log:
        ---------------------------onElemAdd : Sketchup::SectionPlane
        toolRScreate_part2 :
        toolRScreate_part2: createRS :
        Plugin: RichSection
        Copyright: 2013X, All rights reserved for RichSection plugin : Name, code and functionality are the intellectual property of the author. Distribution, reproduction or integration of code or functionality, even partly, is only permitted with the explicit permission of the author
        Version: V00.01-2013.11.17-18:00 DEMO_________________________
        proc createRichSection :
        licensefile found : C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/PiGa_RichSection/RichSectionLicense.rb
        licensed for computer: : any
        licensed for MAC-adress: : any
        licensed for version: : V00.01-2014.11.17-20:00 DEMO
        licensed until: : Sat Mar 01 00:00:00 UTC 2014
        license type: : DEMO, valid until 2014-03-01
        license to (name): : Everybody
        license to (mail): :
        key1: : SoftwarekeyForTheDemoLicenseUntil-2014-03-01
        key2: : fz1njmunn7pfa45t9o1bv0yatdvaln7wvrpl8oitml3301vizcszy0cjyepk1r14mkve
        Faces : 12
        Instances : 1
        Definitions : 1
        @modelcomplexity : 0
        thisRSversion = V00.01-2014.11.17-20:00 DEMO? : V00.01-2014.11.17-20:00 DEMO
        License VALID :
        I hope that this help.
          pomelo3d
          thank you very much for this fantastic plugin.
          On my computer, now shows the same error message, because the plugin expired.
          you can fix that? thank you very much
            ArCAD-UK
            I was about to check the models TIG worked with and got the same EXPIRED DEMO message.
              But sems at least 2 plugins "windowizer.rb" and "wxSU.rb" bugsplat it! πŸ˜‰
                pgarmyn
                As i said before, every method, variable in the RichSection plugin is declared in the RichSection namespace.
                As Windowizer ads a base method and extends SU classes, it interfears with ALL the SU plugins!
                I didn't look at the wxSU code.....
                • emerald15E Offline
                  emerald15
                  @pgarmyn said:
                  @emerald15 said:
                  I use RichSection to great effect. I really like all the additional optional colours, line types & infills.
                  May we see the result ❓ 😎
                  Here's the section part of the drawing. Having all the none visible objects shown in dashed lines really helped.
                  section example.pdf
                    pgarmyn
                    [highlight=#ffff00:e4viin5e]:bounce: UPDATED, but probably not yet on the plugin store. (Need time to find out if I can do this by myself... ) πŸŽ‰[/highlight:e4viin5e]
                      pgarmyn
                      @emerald15
                      Thanks for sharing your work.
                      You are the first using projected information ❗
                      Maybee you have to use a non white section-material ❓
                        @P
                        You need help updating store?
                          pgarmyn
                          @Rich
                          Thanks for the quick reply.
                          TIG gave me alreardy a very complete explanation on the Sketchucation-tools-page,
                          But I will need to find some time to work it out.... .
                          Where can I find the Authors' Guide.
                            @pgarmyn said:
                            @Rich
                            http://sketchucation.com/forums/viewforum.php?f=382
                            First sticky: http://sketchucation.com/forums/viewtopic.php?p=475671#p475671
                              ArCAD-UK
                              Had a play tonight. Just some thoughts:
                              1. I still maintain creating two scenes is unnecessary. If there are a lot of plans and sections then the screen soon becomes cluttered with tabs. It is easy and less confusing to click on the projecting scene and then "Display Section Planes" for editing.
                              2. I know why you create a Style for each section but allowing selection from [user] styles generated within SU may be easier to manage. I usually only have one or two cut styles and I note you have two for each section e.g. #001 AND #001P
                              3. There should be the option to use SU's default material rather than the default created by Rich Section
                              4. I'm not a fan of raster hatches, but they are easy enough to Purge. I don't know what other's feel but some may prefer to load them as an option?
                              5. Would an additional layer "__Profiles" which had just the outlines of the RS cut be possible so that they remain visible when turning off individual entity layers?
                                pgarmyn
                                @arcad-uk said:
                                Had a play tonight. Just some thoughts: 1 2 3....
                                1. Extending Sketchup with Ruby is not as
                                  "driving a car without a steering wheel"
                                  but some controls are missing ❗
                                  The SU ruby API has no (direct) method to create, activate, hide or show a sectionplan. some control is possible using a Scene or a Style. [highlight=#ffff00:2itt6uzf]Thus, I NEED THOSE TWO SCENES AND STYLES[/highlight:2itt6uzf], to save my settings, to switch things on/off... .
                                Many methods to control a 'scene' or a 'style' are missing. A workaround to create a style with the sectionplane activated is to load a style from a file, (a file created before with visibility and active sectionplan as needed) and update it with the active style-settings. What complicates the whole thing is that some methods (like loading a style from a file) can't be in the undo DB. Roughly, my plugin is 30% core code, 30% input & data management and 30% workaround.
                                2 see 1
                                3. The shortest workaround is that YOU save YOUR default material (white, red, hached or not), and select it as default in the RS-settings. You can also (at your ouwn risk) eliminate or replace the bitmaps in plugins/PiGa_RichSection/resources/mat. They are loaded at the creation of the first RS. But the plugin needs at least a #default.png (bitmaps applied with dim. 30x30cm). I plan to replace the bitmaps by a .skm library, but you keep me busy with ....
                                4. I have tons of ring and bels to install, but first I have to upload a working version to the plugin store.
                                  pgarmyn
                                  About the Converter tool: You are not authorised to download this attachment. (after login) ❓ πŸ˜• πŸ˜•
                                    Try again
                                      pgarmyn
                                      @Rich
                                      thanks,
                                      that wil be for Tomorrow.....
                                      (I'm now on my tablet)
                                      I need to be on a PC to save it.....
                                        ArCAD-UK
                                        [highlight=#ffff00:36m3noq6]Sorry. I thought you might be more receptive to end user / potential customer feedback.[/highlight:36m3noq6]
                                        Obviously I'm wasting my time testing the demo. πŸ˜•
                                          pgarmyn
                                          @rich o brien said:
                                          Try again
                                          GOT IT, Thanks πŸ‘
                                            pgarmyn
                                            RichSection is now in the 'SketchUcation Plugin Store' browser...
                                            • 19
                                            • 20
                                            • 5 / 20
