    [Plugin] Layers Panel 1.2.1
    672 Posts 109 Posters 202.9k Views 109 Watching
    • tt_suT Offline
      tt_su
      A couple known bugs:
      • "Add Group" doesn't work the first time you click it.
      • Unfolding the window doesn't work correct. Instead of unfolding it expands a little in the width.
      • Bob JamesB Offline
        Bob James
        After loading the latest version I still get this upon opening a model.
        • H Offline
          huckrorick
          Is there a way to tell within Sketchup which version I am using?
          • tt_suT Offline
            tt_su
            Any model_ Or a specific model?
            • jiminy-billy-bobJ Offline
              jiminy-billy-bob
              "Still", you mean you had this issue before 0.9 ?
              Does it happen everytime ? Only when opening a model, not when opening the dialog ?
              Window > Preferences > Extensions > click on Layers Panel. You'll get the version at the bottom.
                Bob James
                Any model
                Yes. And when I change the condition or existence of layers in SU Layers it does not "track" into Layers Panel.
                Yes. On two different computers: home and work (Win7)
                β€’It also pops up when using Ctrl-Z to restore a Ctrl-X.
                β€’It also still disrupts the layers associated with a scene: if I change the layer combination in a scene and the go back to a different scene the layers in that previous scene have been lost. When I disable Layers Panel the problem goes away (repeatable experience over many models and both machines)
                • tt_suT Offline
                  tt_su
                  What IE version do you have installed?
                    jiminy-billy-bob
                    Did you try to delete everything related to Layers Panel in your plugins folder, and perform a clean install ?
                    About the scene issue, did you check that the auto-update option is disabled ?
                      Bob James
                      Also the Ctrl-X/Ctrl-Z dialog box has a different Char:59 instead of 65
                      By the way: closing and opening Layer Panel gives the Char:59 version of the error.
                        Bob James
                        Yes, and the error pops up during the installation!
                        It was enabled. I disabled it, closed and reopened SU and the scenes are saved (hooray), but I get the Char:59 error each time I switch scenes. By the way, I have to click "Yes" and then the dialog box comes up again and I have to click "Yes" a second time.
                          jiminy-billy-bob
                          So, the error pops up even when the dialog is closed ?
                            Bob James
                            No. I have it set to open when SU starts. But it "errors" when I turn it off and then on again.
                            From previous post: Disabling the auto-update option seems counter-intuitive. What does "auto-update" do?
                              jiminy-billy-bob
                              It auto-updates the layer state of the current scene.
                              If you turn on or off a layer, it's saved in the scene.
                                jiminy-billy-bob
                                Can you try with all the other plugins disabled ?
                                • wind-borneW Offline
                                  wind-borne
                                  It's here guys ! πŸ˜„
                                  New version 0.9 beta !
                                  Changelog :
                                  • OSX support
                                  • Fixed clicking on layer's name not selecting it
                                  Download in the plugin store !
                                  A huge thanks to TT for the OSX support ! πŸ‘ πŸ‘
                                  It's the first OSX version, so it still has bugs. We need you to find them πŸ˜‰
                                  Glad to join in.
                                  Enjoying the ability to group, merge and rearrange β˜€
                                  Problem:
                                  The options panel doesn't work for me.
                                  None of the changes take effect.
                                  Shown, reopening options(right) after setting(left).
                                  Tried reinstalling and tested on 2013 also, same no go.
                                  Annoyance:
                                  Upon closing, Save dialog appears even if no changes made on file with this extension enabled.
                                  For those of us using shortcuts or main toolbar, having floating toolbar automatically load. Deleted that line for now.
                                  Suggestion:
                                  You might want to enlarge icon for use in main toolbar, barely discernible as shown on top shot.
                                  OSX 10.9, Safari 7.0, SU 8
                                  Good luck and thanks again...
                                  "To read between the lines was easier than to follow the text."OSX 10.11.6
                                  %(#BF80BF)[SU 8 pro
                                    jiminy-billy-bob
                                    Thanks for your feedback ! πŸ˜‰
                                    @wind-borne said:
                                    Annoyance:
                                    I have to initialize some stuff, so there is no real workaround for the save dialog.
                                    As for the toolbar, can't you just hide it in the toolbars options ?
                                      Bob James
                                      I have 188 rb files. I used SketchUcation Extensions Manager and was able to disable all the other extensions (that had no effect on the problem[s]). But SketchUcation Plugins Manager can only disable one plugin at a time. 😞 So disabling all of the rb files one at a time is not very desirable.
                                      What I will try is: disable my Plugins folder and make a dummy with just Layers Panel and whatever basic plugins are required.
                                      • TIGT Online
                                        @Bob
                                        The SketchUcation Plugins Manager [and its other siblings - Extensions Manager and Plugins Uninstaller] will allow you to select multiple items in either column - Loaded/Enabled or Disabled - clicking and holding the Ctrl for individual items added to the selection or Shift key to add all up/down from the last one you selected [like any Windows app]...
                                        Then click the red > button to disable as desired.
                                        IF you made a named 'Set' [blue button] of the current Plugins set up... BEFORE doing major change... then you can easily revert to that named 'Set' on a later occasion...
                                        The Managers are there to ease the pain... you just need to restart SketchUp to see the changes... πŸ˜„
                                          jiminy-billy-bob
                                          Well that's what I was thinking.
                                            jiminy-billy-bob
                                            @wind-borne said:
                                            Suggestion:
                                            Do you have a retina screen ?
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 33
                                            • 34
                                            • 22 / 34
