    [Plugin] SectionCutFace
    565 Posts 170 Posters 375.1k Views 169 Watching
    • atelierpaarA Offline
      atelierpaar
      Hello Tig,
      thanks for this great plugin. Its a tremendous advantage to glue the section plane. I noticed so, that its not possible to change colors or textures once they are applied. ThatΒ΄s to bad, since I usually differentiate my sections. Is there a workaround ?
      anyway`s, congratulation one more time
      Uli
        You don't need a work around. You need to change Lock from Yes to No before you make the face.
        Or unlock the locked group so you can open it for editing.
        • cottyC Offline
          cotty
          If it is glued, you cannot change the color, even if it's not locked.
          my SketchUp gallery
              If a SectionCutFace is not 'glued', then you can manually edit its properties, provide you 'unlock' it first.
              If a SectionCutFace is set to be 'glued' [or 'glue-on-demand'] you specify its fixed properties when it is created, including its color/material [chosen from a list of basic colors and any existing materials at that time] then later on, whenever it changes it will regenerate and reuse the color/material that was initially assigned to it [all of its settings are remembered as special 'attributes']. So you can't change its material manually by painting the faces in an edit - the act of painting and/or the exit from the edit is regarded as a valid change and it is regenerated using its stored attributes - including its saved color/material. BUT provided that a material is loaded into the model, then you can easily 'remake' the glued SectionCutFace by selecting the same section-plane again and then adding a SectionCutFace choosing another listed color/material [and also whatever other settings you wish to have***]. Each section-plane can only have ONE SectionCutFace, so this new SectionCutFace supersedes the previous one, and so it will now keep its new material etc as specified...
              ***This resetting also applies to all its properties, like hidden edges etc...
                Here's v3.9 http://sketchucation.com/resources/pluginstore?pln=SectionCutFace
                The removal of 'inner hole' faces has been improved again πŸ˜„
                  ArCAD-UK
                  😍 πŸŽ‰ πŸ˜„ THANK YOU! The master weaves his magic again...
                    Here's v4.0 http://sketchucation.com/resources/pluginstore?pln=SectionCutFace
                    Further improvements in inner hole face removal algorithms. πŸ˜„
                      Here's v4.1 http://sketchucation.com/resources/pluginstore?pln=SectionCutFace
                      Convoluted transformations of nested objects no longer affects algorithms.
                      πŸ˜„
                        Here's v4.2 http%3A%2F%2Fsketchucation.com%2Fresources%2Fpluginstore%3Fpln%3DSectionCutFace
                        Remaining convoluted mirrored transformations trapped.
                        πŸ€“
                        • V Offline
                          vame9
                          there is a problem when using that plugin it makes a delay in a navegational function but not in clean new files - in crowded file (note that when i remove that plugin Only things go back normal)
                          what happens is when i click the roller to switch to Orbit it takes like a second or so to switch
                            That is why it is recommended NOT to use SectionCutFaces that 'Glue' while you model [unless it's a very simple model].
                            At every change to the model [or section-plane] the 'Glued' section-planes are updated, taking time to reprocess.
                            So it's much better to use the 'On-Demand' format and recreate a SectionCutFace after making geometry changes.
                            If you SectionCutFace is a standard type [not Glued or update-able] then these delays are avoided and you simply delete then recreate the section's face once you have made changes...
                            I am considering making this more obvious in the tool - watch for developments...
                            • JQLJ Offline
                              JQL
                              TIG.
                              A minor suggestion: would you consider renaming "Glued" to "Auto-Update"? I know you mean it stays glued to the section plane, but I find it more intuitive for new users and probably makes them think better before using. Maybe a simple thing could be written like "Auto-Update (slows model)"
                              www.casca.pt
                              Visit us on facebook!
                                I'll consider the implications πŸ˜•
                                  srknytgn
                                  thanks for this great plugin. but i had some trouble after upgrade to Skethup Make. When I try to pan or edit groups the model was getting slow and unresponsive. I tried to find which plugin was problem, by deleting SectionCutFace it was resolved.
                                  http://sketchucation.com/forums/viewtopic.php?f=15%26amp;t=52754#wrap
                                    Don't 'Glue' SectionCutFaces in your more complex models.
                                    This has already been discussed at length πŸ˜’
                                    Choose 'On-Demand' and update the SectionCutFace when desired...
                                    Otherwise at every change to the model it will try to update the SectionCutFace...
                                    πŸ˜’
                                      srknytgn
                                      it is not about using the plugin. the installation of it is enough to make it slow.
                                        That is odd...
                                        It has an observer that looks for tool changes.
                                        I am looking at ways of minimizing its impact - perhaps that's it when you have zillions of objects to consider... I'll see if I can get its activities minimized πŸ˜•
                                          srknytgn
                                          well, we upgraded our sketchups from 8 to Make and the plugin set was the same in all of our 40 pcs. tested that by deleting plugins one by one, close&open SU and found this result. by the way thank you for developing these plugins so responsively.
                                            A new version is now available from the PluginStore.
                                            It renames 'Glue' as 'Auto-Update'.
                                            The observers used for 'Auto-Update' SectionCutFaces are re-honed and optimized to minimize 'lag' during regenerations.
                                            If there are no 'Auto-Update' SectionCutFaces in the model then any lag should be imperceptible.
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 28
                                            • 29
                                            • 18 / 29
