    [Plugin] SectionCutFace
    569 Posts 171 Posters 505.9k Views 170 Watching
    • cottyC Offline
      cotty
      Indigo Renderer supports section cuts directly (see here).
      my SketchUp gallery
      • Z Offline
        z3325206
        @cotty said:
        I think the renderer must support section cuts and it isn't a problem of the plugin. If so, you can save a copy of your model and use the "Slice Model at Section" option from Zorro2 (?) to delete the rest of the model for the render.
        Thank you Cotty and Tig, It works fine with zorro2 in sku8.
          JAD JM
          Hi TIG, Does this plugin work for Mac?
            It works just fine on Mac.
            • danchoD Offline
              dancho
              Hi Tig,
              thanks for a recent help. Now I have one interesting problem.
              After reinstalling a sketchup 2013, put on several plugins only.
              SketchuUV ; AdditionalPluginFolder ; Sketchucation loader and your plugin SectionCut Face.
              Using this plugin in small scene cca 30Mb interior I have strange delay when I need to
              orbit a scene. My sketchup slow down on a strange way. After that I was trying with other files 20-120Mb sizes but the same.
              After removing a plugin everything is fine.
              Do you know some solution for this?
              Sketchup 2013, Windows 7 Home P. x64,
              Daniel
              • TIGT Online
                On large models gluing a section-cut to a section-plane can slow things down noticeably, because at each change to the model it has to decide if the section-cut is modified by that...
                Therefore using the alternative glue-on-demand mode is recommend, or even no-gluing_remake if the section-plane or model being cut by it changes...
                • atelierpaarA Offline
                  atelierpaar
                  Hello Tig,
                  thanks for this great plugin. Its a tremendous advantage to glue the section plane. I noticed so, that its not possible to change colors or textures once they are applied. Thatยดs to bad, since I usually differentiate my sections. Is there a workaround ?
                  anyway`s, congratulation one more time
                  Uli
                    You don't need a work around. You need to change Lock from Yes to No before you make the face.
                    Or unlock the locked group so you can open it for editing.
                    • cottyC Offline
                      cotty
                      If it is glued, you cannot change the color, even if it's not locked.
                      my SketchUp gallery
                        • TIGT Online
                          If a SectionCutFace is not 'glued', then you can manually edit its properties, provide you 'unlock' it first.
                          If a SectionCutFace is set to be 'glued' [or 'glue-on-demand'] you specify its fixed properties when it is created, including its color/material [chosen from a list of basic colors and any existing materials at that time] then later on, whenever it changes it will regenerate and reuse the color/material that was initially assigned to it [all of its settings are remembered as special 'attributes']. So you can't change its material manually by painting the faces in an edit - the act of painting and/or the exit from the edit is regarded as a valid change and it is regenerated using its stored attributes - including its saved color/material. BUT provided that a material is loaded into the model, then you can easily 'remake' the glued SectionCutFace by selecting the same section-plane again and then adding a SectionCutFace choosing another listed color/material [and also whatever other settings you wish to have***]. Each section-plane can only have ONE SectionCutFace, so this new SectionCutFace supersedes the previous one, and so it will now keep its new material etc as specified...
                          ***This resetting also applies to all its properties, like hidden edges etc...
                          • TIGT Online
                            Here's v3.9 http://sketchucation.com/resources/pluginstore?pln=SectionCutFace
                            The removal of 'inner hole' faces has been improved again ๐Ÿ˜„
                              ArCAD-UK
                              ๐Ÿ˜ ๐ŸŽ‰ ๐Ÿ˜„ THANK YOU! The master weaves his magic again...
                              • TIGT Online
                                Here's v4.0 http://sketchucation.com/resources/pluginstore?pln=SectionCutFace
                                Further improvements in inner hole face removal algorithms. ๐Ÿ˜„
                                • TIGT Online
                                  Here's v4.1 http://sketchucation.com/resources/pluginstore?pln=SectionCutFace
                                  Convoluted transformations of nested objects no longer affects algorithms.
                                  ๐Ÿ˜„
                                  • TIGT Online
                                    Here's v4.2 http%3A%2F%2Fsketchucation.com%2Fresources%2Fpluginstore%3Fpln%3DSectionCutFace
                                    Remaining convoluted mirrored transformations trapped.
                                    ๐Ÿค“
                                    • V Offline
                                      vame9
                                      there is a problem when using that plugin it makes a delay in a navegational function but not in clean new files - in crowded file (note that when i remove that plugin Only things go back normal)
                                      what happens is when i click the roller to switch to Orbit it takes like a second or so to switch
                                      • TIGT Online
                                        That is why it is recommended NOT to use SectionCutFaces that 'Glue' while you model [unless it's a very simple model].
                                        At every change to the model [or section-plane] the 'Glued' section-planes are updated, taking time to reprocess.
                                        So it's much better to use the 'On-Demand' format and recreate a SectionCutFace after making geometry changes.
                                        If you SectionCutFace is a standard type [not Glued or update-able] then these delays are avoided and you simply delete then recreate the section's face once you have made changes...
                                        I am considering making this more obvious in the tool - watch for developments...
                                        • JQLJ Offline
                                          JQL
                                          TIG.
                                          A minor suggestion: would you consider renaming "Glued" to "Auto-Update"? I know you mean it stays glued to the section plane, but I find it more intuitive for new users and probably makes them think better before using. Maybe a simple thing could be written like "Auto-Update (slows model)"
                                          www.casca.pt
                                          Visit us on facebook!
                                          • TIGT Online
                                            I'll consider the implications ๐Ÿ˜•
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 28
                                            • 29
                                            • 15 / 29
