    [Plugin] SectionCutFace
    567 Posts 171 Posters 440.2k Views 170 Watching
      On large models gluing a section-cut to a section-plane can slow things down noticeably, because at each change to the model it has to decide if the section-cut is modified by that...
      Therefore using the alternative glue-on-demand mode is recommend, or even no-gluing_remake if the section-plane or model being cut by it changes...
      • atelierpaarA Offline
        atelierpaar
        Hello Tig,
        thanks for this great plugin. Its a tremendous advantage to glue the section plane. I noticed so, that its not possible to change colors or textures once they are applied. ThatΒ΄s to bad, since I usually differentiate my sections. Is there a workaround ?
        anyway`s, congratulation one more time
        Uli
          You don't need a work around. You need to change Lock from Yes to No before you make the face.
          Or unlock the locked group so you can open it for editing.
          • cottyC Offline
            cotty
            If it is glued, you cannot change the color, even if it's not locked.
            my SketchUp gallery
                If a SectionCutFace is not 'glued', then you can manually edit its properties, provide you 'unlock' it first.
                If a SectionCutFace is set to be 'glued' [or 'glue-on-demand'] you specify its fixed properties when it is created, including its color/material [chosen from a list of basic colors and any existing materials at that time] then later on, whenever it changes it will regenerate and reuse the color/material that was initially assigned to it [all of its settings are remembered as special 'attributes']. So you can't change its material manually by painting the faces in an edit - the act of painting and/or the exit from the edit is regarded as a valid change and it is regenerated using its stored attributes - including its saved color/material. BUT provided that a material is loaded into the model, then you can easily 'remake' the glued SectionCutFace by selecting the same section-plane again and then adding a SectionCutFace choosing another listed color/material [and also whatever other settings you wish to have***]. Each section-plane can only have ONE SectionCutFace, so this new SectionCutFace supersedes the previous one, and so it will now keep its new material etc as specified...
                ***This resetting also applies to all its properties, like hidden edges etc...
                  Here's v3.9 http://sketchucation.com/resources/pluginstore?pln=SectionCutFace
                  The removal of 'inner hole' faces has been improved again πŸ˜„
                    ArCAD-UK
                    😍 πŸŽ‰ πŸ˜„ THANK YOU! The master weaves his magic again...
                      Here's v4.0 http://sketchucation.com/resources/pluginstore?pln=SectionCutFace
                      Further improvements in inner hole face removal algorithms. πŸ˜„
                        Here's v4.1 http://sketchucation.com/resources/pluginstore?pln=SectionCutFace
                        Convoluted transformations of nested objects no longer affects algorithms.
                        πŸ˜„
                          Here's v4.2 http%3A%2F%2Fsketchucation.com%2Fresources%2Fpluginstore%3Fpln%3DSectionCutFace
                          Remaining convoluted mirrored transformations trapped.
                          πŸ€“
                          • V Offline
                            vame9
                            there is a problem when using that plugin it makes a delay in a navegational function but not in clean new files - in crowded file (note that when i remove that plugin Only things go back normal)
                            what happens is when i click the roller to switch to Orbit it takes like a second or so to switch
                              That is why it is recommended NOT to use SectionCutFaces that 'Glue' while you model [unless it's a very simple model].
                              At every change to the model [or section-plane] the 'Glued' section-planes are updated, taking time to reprocess.
                              So it's much better to use the 'On-Demand' format and recreate a SectionCutFace after making geometry changes.
                              If you SectionCutFace is a standard type [not Glued or update-able] then these delays are avoided and you simply delete then recreate the section's face once you have made changes...
                              I am considering making this more obvious in the tool - watch for developments...
                              • JQLJ Offline
                                JQL
                                TIG.
                                A minor suggestion: would you consider renaming "Glued" to "Auto-Update"? I know you mean it stays glued to the section plane, but I find it more intuitive for new users and probably makes them think better before using. Maybe a simple thing could be written like "Auto-Update (slows model)"
                                www.casca.pt
                                Visit us on facebook!
                                  I'll consider the implications πŸ˜•
                                    srknytgn
                                    thanks for this great plugin. but i had some trouble after upgrade to Skethup Make. When I try to pan or edit groups the model was getting slow and unresponsive. I tried to find which plugin was problem, by deleting SectionCutFace it was resolved.
                                    http://sketchucation.com/forums/viewtopic.php?f=15%26amp;t=52754#wrap
                                      Don't 'Glue' SectionCutFaces in your more complex models.
                                      This has already been discussed at length πŸ˜’
                                      Choose 'On-Demand' and update the SectionCutFace when desired...
                                      Otherwise at every change to the model it will try to update the SectionCutFace...
                                      πŸ˜’
                                        srknytgn
                                        it is not about using the plugin. the installation of it is enough to make it slow.
                                          That is odd...
                                          It has an observer that looks for tool changes.
                                          I am looking at ways of minimizing its impact - perhaps that's it when you have zillions of objects to consider... I'll see if I can get its activities minimized πŸ˜•
                                            srknytgn
                                            well, we upgraded our sketchups from 8 to Make and the plugin set was the same in all of our 40 pcs. tested that by deleting plugins one by one, close&open SU and found this result. by the way thank you for developing these plugins so responsively.
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 28
                                            • 29
                                            • 15 / 29
