    [Plugin] RichSection V0.5.8 UPDATED march 2015
    395 Posts 85 Posters 182.1k Views 85 Watching
      ArCAD-UK
      @jolran said:
      You do know that you can do this in Hatchfaces ? If you want real edges as hatches from section slice that is.
      I will have a look at that thanks! I'm not a fan of raster hatching...
      • jolranJ Offline
        jolran
        Check out the help files, if that does not work for you, you can PM me and fire the questions. Or if you rather post a question in Hatchafaces topic thats fine too.
          pgarmyn
          @arcad-uk said:
          Last night my first section entry [XL01] was replaced with [XL0001] today everything seems ok ๐Ÿ˜• I may have used "undo" and messed things up.
          There is a lot going on when creating an RS, can I do a complete undo with 1 click?
          I was thinking in LO I might want to explode the scene and apply a different line style but I now see that RichSections don't display in vector mode. (
          Undo : I can't undo scenes and styles loaded (from file). The SU API for Ruby has no functions to create them from scratch. I have to load them from a file. No way, at my knowledge, to include this in the undo DB (within start and commit_operation).
          Controle vector output (with color and line style) to Layout : I can only dream of it. ๐Ÿ˜‰
            pgarmyn
            Hi TIG, micione and others...
            As I said before (see 'TO BE CONTINUED'), I loaded the free version (Windowizer3, W3) and did some testing.
            As the Bugsplat takes place after a commit_operation in the RichSection plugin (without 'other' errors), I tried to find the conflict in the W3 code.
            I didn't find anything directly in common with the RichSection plugin, but I found these anomalies:
            • def getMaterials is a root method declared twice : once in windowizer,rb, once in getMaterials.rb; Even if the 'require getMaterials,rb' is comment out; the file is automatically loaded because it is directly in the Sketchup/plugins
            • The following classes are extended : Array, Sketchup::Face, Sketchup::Entity; Sketchup::ArcCurve; Sketchup::Curve
            • many Global variables
            • the global variable $wName is once a string [=Wdw.new.to_s.slice(6..14)] and later an empty class object [=Wdw.new]โ€ฆ..
              I tried to clean up the code for testing, but I can't see the end of it.
            As there is nothing specificly in common with RS (I mean : in common with RS but not with other plugins), I cleaned up the plugin directory and installed only Windowizer3 + Fredo's RoundCorner
            It works fine for a (very) small model.
            But for more a more complex models (50 identical component-instances: in total (nested) about 9500 edges, 3300 faces), I had directly a Bug-splat when creating round corners around one face within the component.
            I uninstalled Windowizer3 (the files) and did the same manipulation : Eventing worked fine.
            I think that the plugins of Fredo are a reference for the Sketchup community.
            CONCLUSION : Windowizer 3 is not a stable plugin. I didn't spent my money to test the payed version โ€ฆ.
            Windowizer is not distributed on Sketchucation, but maybee it is important to tell people that it causes Bugsplats in other plugins.
            • ladcweiL Offline
              ladcwei
              I am waiting for this plugin for five years,then I could handle whole design with Su &layout completely today!Thanks a lot!
              It's another plugin for sections:
              http://www.sublog.net/?s=realsection
              it could assign diffferent materials to different grounps,maybe it could give some useful ideas...
              I am chinese,you can download this plugin on http://www.sublog.net for free,needn't to pay,this site show all the resourse here,it's a good guide! ๐Ÿ˜„
                pgarmyn
                @ladcwei said:
                ....http://www.sublog.net/?s=realsection
                Hallo ladcwei
                You can also assign different materials in the RichSection plugin: by layer, by nature (color) or a combination.
                It's much faster than assigning materials to individual elements, but you will have to organize your model and use different layers to assign different section-materials.
                I know realSection (GWD), there is also SectionCutface (TIG), and other good plugins.
                Each plugin is different. I wanted to offer projection.
                [highlight=#ffff40:y89ppu1f]So what were you waiting for during 5 years ? โ“ โ“[/highlight:y89ppu1f]
                Thanks for the interest.
                  pgarmyn
                  I added two new videos.
                  In the last video, I produced a plan with [highlight=#ffff00:3n6bzrcv]SKETCHUP + RichSection + LAYOUT[/highlight:3n6bzrcv]:
                  See video and attached PDF file (RichSection-demo-04.PDF) in the first post.
                    Absolutly astonishing! ๐Ÿ˜Ž
                    (tested in V8)
                    Another plugin who makes bugsplatsh :wxSU.rb !!!
                    Does it posible to delete these dotted lines in the free space ?
                    ( i have not yet explore the plugin! ๐Ÿ˜ณ
                    Ps Why you don't say on the first post that the UI of Rich Section is working automatically also in French? โ˜€
                    rich4.skp
                      pgarmyn
                      (tested in V8)
                      [attachment=1:3822h56j]<!-- ia1 -->rich2.jpg<!-- ia1 -->[/attachment:3822h56j]
                      %(#0000FF)[Bonjour Pilou. Quel honneur โ—
                      Pour enlever ces lignes, il suffit d'รฉteindre 'PROJECTION'. (La section calculera aussi beaucoup plus vite).
                      Dans les dessins technique (architecture), la projection reprรฉsente les รฉlรฉments au-dessus du plan de projection.
                      On peut aussi limiter la projection (par distance, calques). Une dรฉmonstration (distance de projection limitรฉe) est faite dans video #03.
                      Je vais ajouter : Si la version de SU est franรงaise, elle chargera RichSection en franรงais..]
                      For the rest of the world:
                      To take away those pointed lines, just switch off 'PROJECT'. (The section will also calculate faster).
                      In technical drawings (architecture), 'projection' represents the elements above the section-plane.
                      You can also controle wich elements are projected (by distance, layers). This is demonstrated (with projection limited by distance) in video #03.
                      For people with a french SU, the program will load a french RichSection dictionary.
                      For the rest of the world: are there traductors on this forum?
                        pgarmyn
                        For more important (big, complex) drawings. It is worth to use SU 2013. MUCH MUCH faster โ— โ— โ—
                          Excellent! ๐Ÿ˜Ž ๐Ÿ‘ โ˜€
                            pgarmyn
                            deleted double message
                              pgarmyn
                              If someone want's to pay for my RichSection [Demo] plugin :
                              [highlight=#ffff00:2ljx047o]They sell (correction) USE it already in China:[/highlight:2ljx047o] ๐Ÿคฃ ๐Ÿคฃ
                              (www.sublog.net)
                              I can't explain much in chinese, so i added an other video (above). ๐Ÿ˜†
                              • emerald15E Offline
                                emerald15
                                Thank you. I've just completed a more than usually complex drawing that required cross sections. I use RichSection to great effect. I really like all the additional optional colours, line types & infills.
                                  pgarmyn
                                  May we see the result โ“ ๐Ÿ˜Ž
                                  • I Offline
                                    ivreich
                                    YES ๐Ÿ˜„ the 2nd video is showing that ๐Ÿ˜„
                                    Use RichSection materials 'by layer' or 'by nature' or a combination.
                                    Every RichSection can also have different section materials, by using a different 'prefix'
                                    ๐Ÿ˜„
                                    Hey there..
                                    I've managed to figure out how to create different hatch patterns for objects on different layers, but I can't seem to create different hatch patterns for objects with different materials. It always goes back to the default pattern?
                                    Also, I don't quite understand the options for the richsection material - what is the difference between "prefix+layername, prefix+materialname, default" and "prefix+materialname, prefix+layername, default"?
                                    As I mentioned, I just can't seem to get material names to work in defining different hatch patterns...please help!
                                    Thanks...
                                    Joel
                                    • ladcweiL Offline
                                      ladcwei
                                      I think it could make good effect more safely ๐Ÿ˜‰
                                        pgarmyn
                                        @ivreich said:
                                        ..... I don't quite understand the options for the richsection material - what is the difference between "prefix+layername, prefix+materialname, default" and "prefix+materialname, prefix+layername, default"?
                                        ...please help!
                                        Thanks...
                                        Joel
                                        Hi Joel
                                        Supposing
                                        • Model : you used layers L1 and L2
                                        • Model : you applied the following materials to groups and components : N1 and N2
                                          First possibility :
                                        • Model : existing materials in library 'in model' : #L1.... / NOT existing materials : #L2
                                        • RS-options : prefix = #
                                        • RS-options : default material = #default
                                        • RS-options : section material = prefix+layername, default
                                        • RS section materials for a group or component in layer L1 : #L1
                                        • RS section materials for a group or component in layer L2 : #default (because #L2 doesn't exist)
                                          2nd possibility :
                                        • Model : existing materials in library 'in model' : #N1.... / NOT existing materials : #N2
                                        • RS-options : section material = prefix+materialname, default
                                        • RS section materials for a group or component with material N1 assignd: #N1
                                        • RS section materials for a group or component with material N2 assignd: #default (because #N2 doesn't exist)
                                        Got it โ“ ๐Ÿ˜„
                                          pgarmyn
                                          ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                                          It seems to be a very complex model โ— โ— โ—
                                          What kind of building is it ? With a giant bell at the center ?
                                          Maybee the bell needs some thickness. You can do this with the Joint PushPull plugin from Fredo.
                                          Thanks for sharing your experiance.
                                            sexypox69
                                            Cant get it to work like in the videos....it just works as sketchup native section cut, also sketchup crashed a few times (bugsplat)....but i love the intention. It would save me the time to go put in hatches in my layout documents
                                            • 19
                                            • 20
                                            • 3 / 20
