    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 791.3k Views 175 Watching
      Try this: Enable the toolbar in View>Toolbars. Pull all of the toolbars off the top rows. Does the Extrude Tool toolbar show up in the upper left corner? If so, you have now found it and can place it where you need but you really ought to install the current version of SU2013. there was a bug in the first release that caused new toolbars to appear under the existing ones. It was fixed though.
      Dave earlier mentioned this...
      To me it looks like this is related to the bug Dave flagged.
      What happens when you check for update under the Help menu?
      • ArisA Offline
        Aris
        Sometimes giving up helps!
        I reverted to the old plugins folder, relaunched SU and every toolbar appeared undocked, including ET!!!
        I relaunched it a couple of times and now it seems stable.
        finally to enjoy it (it's a great plugin).
        Not a native speaker, point out my spelling (or other) mistakes, I won't be offended!!!
        • ArisA Offline
          Aris
          Doesn't installing it from plugin store guarantee that it's the latest version?
          • BoxB Offline
            He means the newest version of Sketchup itself, your problem suggests you have an old version.
            • ArisA Offline
              Aris
              sorry, my bad. I thought you were referring to the plugin version all this time, I'm downloading latest sketchup right now. Thanks for bearing with me.
                Easy to miss out.
                Glad it works
                  Yes. I wrote "...install the current version of SU2013." because I meant the current version of SketchUp.
                    thegoodguy
                    HI,
                    Great set of tools. Thanks.
                    A two-part question:
                    About the "edges by face" and "edges by faces" tools. Is it possible to specify which point on the face(s) the edge endpoint aligns with? E.g. can you start the extrusion from the one of the pointed tips of a star-shape instead of the centre of the centre of the face?
                    About the "edges by faces" tool. Is it possible to specify which endpoints on the starting face align/match-up with which endpoints on the ending face?
                    I hope these questions make sense. I've attached an image to show what I mean. Shape (A) was produced using the tool. Shape (B) I did manually by choosing which endpoints are matched and then using a curve-stitching tool.
                    Thanks again.
                      jefecito
                      The toolbar not load, is it normal in SU 2013?
                        The toolbar displays just fine in SU2013 unless you installed the plugin incorrectly or perhaps don't have sufficient privileges set for the Plugins folder. What operating system? (please update your profile), how did you install the plugin? Do you have sufficient privileges?
                          pgarmyn
                          I use your excellent Extrude-tool in another thread πŸ‘ πŸ‘
                          (http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=55072)) )
                          I'm afraid that I have to report a small bug.
                          With the Extrude-by-rails (I didn't test the others).
                          I have almost always an unexpected result if the [highlight=#ffff00:367zdzqn]profile turns exactly 180Β°[/highlight:367zdzqn] around Z (didn' test for the other axes). It could be a 'division by (almost) zero' (tangent).
                          I also used Jim's drawhelix14 plugin πŸ‘
                          helix-extrude-bug.skp
                            If you pick the obvious profiles and rails you get your result.
                            However, if you pick a 'sweeping rail' as the first profile, then the two 'end' curves as the rails, and the other 'sweeping rail' as the melding profile, then it works... The 'direction' of the form might twist unexpectedly.
                            Another solution is to rotate the 4 curves [temporarily] by say 1 degree, then it works as I think you had hoped - no 'twisting' etc...
                            See the screen-grab...
                            It's not so much trigonometry, more having to decide in which direction the mesh goes, obviously if it's a 50:50 chance with axial alignments it can guess wrong... πŸ˜•
                              pgarmyn
                              Yes, the result is also logic, but not the one i wanted.
                              I can live with it. πŸ˜„
                              Thanks for the 'research' and the explanation. πŸ‘
                                Here's a new future-proofed update.
                                http://sketchucation.com/forums/viewtopic.php?p=217663#p217663
                                • Y Offline
                                  yhchen
                                  I have a problem. I tried to use the extrude edges by rails by face function. But the was one one component form on the profile section. I don't understand why.
                                  Below there is 2 attached jpg files, it is the print screen of the process and the outcome.
                                  Please help me!!!! Thank you
                                  Yhchen
                                  how I do it
                                  the result
                                    @yhchen
                                    If you run it with the Ruby Console open are there any error messages ?
                                    Is the geometry very small ?
                                    Try it with the profile face reversed - it should work either way but who knows ?
                                    Can you attach a SKP containing the 4 curves and the face so we can look at it...
                                    • Y Offline
                                      yhchen
                                      Dear TIG,
                                      Thank you for ur quick response.
                                      I have tried to run it with Ruby Console, n I found lots of error occur, which I do not understand why.
                                      Regards,
                                      Yhchen
                                      Ruby Console (EE Error)
                                      sketchup file
                                        @ynchen
                                        I have tested the SKP and get good results.
                                        See the attached image.
                                        The up/down orientation of the face does not affect the result.
                                        The over all size of the geometry is within sensible limits.
                                        You errors...
                                        EE Error 3:
                                        means that it is failing to add a curve from the cpoints it has got from the melding-profile...
                                        EE Error 4:
                                        is a similar error relating to the profile...
                                        I can't reproduce any errors... πŸ˜•
                                        Your image shows one corrected located profile and one set on cpoints following a reversed curve, NOT the profile/melding-profiles lines... before the early failure πŸ˜•
                                        Here are my thoughts...
                                        Do you have Guides switched on?
                                        The toolset uses cpoints etc...
                                        Your SKP is v6 - I don't have that version readily available to test so it might be a limitation - from available methods for your set up; although the API methods used are for >=v6 ?
                                        Why not upgrade to a newer 'free' version of SketchUp - it is much improved... v2013 'Make' ?
                                        Different versions can co-exists on the same PC.
                                        Are you using the latest version of this Extrude toolset [v2.2] ?
                                        If not then please get the latest RBZ from the PluginStore pages...
                                        http://sketchucation.com/pluginstore?pln=ExtrudeTools
                                        If you have v8M2 or newer you can AutoInstall from the SketchUcation PluginStore dialog within SketchUp or use the Preferences > Extensions > Install... button to do it automatically for you...
                                        In SketchUp versions <8.M2 you'll need to rename the RBZ as a .ZIP file, and then extract its contents and manually move them into the Plugins folder***
                                        [if you are not an Admin, make yourself an Admin using the Users Control-Panel: then make sure the Plugins folder has FULL read/write permissions set for every user/group listed under Properties > Security > Edit...]
                                        ***Always leave helper files within the same subfolder[s] that are inside the ZIP.
                                        After an update restart SketchUp twice: as it'll need to remove older versions is you have a very out of date installation etc...
                                        Lastly, what other plugins do you have loading?
                                        Are any of those quarantined or rogues, as explained in other posts ?
                                        • Y Offline
                                          yhchen
                                          Hello,
                                          Thank you for your help, I have upgrade my sketchup to 2013 version. now it works perfectly.
                                          Thank you again for your awesome plugins. All the best ^^
                                          Regards,
                                          Yh chen
                                            bob777
                                            Very useful...this one and the others. Just made a donation.
                                            • 31
                                            • 32
                                            • 6 / 32
