    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 991.5k Views 175 Watching
      That's is plain weird.
      Do you have v8 installed? If so is this reproducible on that?
      Can you post a screenie of your Plugins folder?
      • ArisA Offline
        Aris
        yes I have it installed and there's no problem there
        Not a native speaker, point out my spelling (or other) mistakes, I won't be offended!!!
        • ArisA Offline
          Aris
          here's the new plugins folder (I also gave it full rights)
            And you are running the very latest release of 2013?
            What's inside the ExtrudeTools folder?
            You've the extension enabled under preferences?
            You have it enabled in the SketchUcation Tools Managers?
            • ArisA Offline
              Aris
              That's weird!
              after I checked and unchecked it from the toolbars dialogue and moving around the other toolbars, it finaly appeared but without a frame, so I cannot move it!
              • ArisA Offline
                Aris
                yes, I told you, it is checked/visible everywhere
                plugins manager, plugins menu, preferences/extensions, toolbars dialogue
                it's only absent in the toolbar right click menu.
                • BoxB Offline
                  Double click on it now you can see it and it will come loose.
                    Try this: Enable the toolbar in View>Toolbars. Pull all of the toolbars off the top rows. Does the Extrude Tool toolbar show up in the upper left corner? If so, you have now found it and can place it where you need but you really ought to install the current version of SU2013. there was a bug in the first release that caused new toolbars to appear under the existing ones. It was fixed though.
                    Dave earlier mentioned this...
                    To me it looks like this is related to the bug Dave flagged.
                    What happens when you check for update under the Help menu?
                    • ArisA Offline
                      Aris
                      Sometimes giving up helps!
                      I reverted to the old plugins folder, relaunched SU and every toolbar appeared undocked, including ET!!!
                      I relaunched it a couple of times and now it seems stable.
                      finally to enjoy it (it's a great plugin).
                      • ArisA Offline
                        Aris
                        Doesn't installing it from plugin store guarantee that it's the latest version?
                        • BoxB Offline
                          He means the newest version of Sketchup itself, your problem suggests you have an old version.
                          • ArisA Offline
                            Aris
                            sorry, my bad. I thought you were referring to the plugin version all this time, I'm downloading latest sketchup right now. Thanks for bearing with me.
                              Easy to miss out.
                              Glad it works
                                Yes. I wrote "...install the current version of SU2013." because I meant the current version of SketchUp.
                                  thegoodguy
                                  HI,
                                  Great set of tools. Thanks.
                                  A two-part question:
                                  About the "edges by face" and "edges by faces" tools. Is it possible to specify which point on the face(s) the edge endpoint aligns with? E.g. can you start the extrusion from the one of the pointed tips of a star-shape instead of the centre of the centre of the face?
                                  About the "edges by faces" tool. Is it possible to specify which endpoints on the starting face align/match-up with which endpoints on the ending face?
                                  I hope these questions make sense. I've attached an image to show what I mean. Shape (A) was produced using the tool. Shape (B) I did manually by choosing which endpoints are matched and then using a curve-stitching tool.
                                  Thanks again.
                                    jefecito
                                    The toolbar not load, is it normal in SU 2013?
                                      The toolbar displays just fine in SU2013 unless you installed the plugin incorrectly or perhaps don't have sufficient privileges set for the Plugins folder. What operating system? (please update your profile), how did you install the plugin? Do you have sufficient privileges?
                                        pgarmyn
                                        I use your excellent Extrude-tool in another thread πŸ‘ πŸ‘
                                        (http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=55072)) )
                                        I'm afraid that I have to report a small bug.
                                        With the Extrude-by-rails (I didn't test the others).
                                        I have almost always an unexpected result if the [highlight=#ffff00:367zdzqn]profile turns exactly 180Β°[/highlight:367zdzqn] around Z (didn' test for the other axes). It could be a 'division by (almost) zero' (tangent).
                                        I also used Jim's drawhelix14 plugin πŸ‘
                                        helix-extrude-bug.skp
                                          If you pick the obvious profiles and rails you get your result.
                                          However, if you pick a 'sweeping rail' as the first profile, then the two 'end' curves as the rails, and the other 'sweeping rail' as the melding profile, then it works... The 'direction' of the form might twist unexpectedly.
                                          Another solution is to rotate the 4 curves [temporarily] by say 1 degree, then it works as I think you had hoped - no 'twisting' etc...
                                          See the screen-grab...
                                          It's not so much trigonometry, more having to decide in which direction the mesh goes, obviously if it's a 50:50 chance with axial alignments it can guess wrong... πŸ˜•
                                            pgarmyn
                                            Yes, the result is also logic, but not the one i wanted.
                                            I can live with it. πŸ˜„
                                            Thanks for the 'research' and the explanation. πŸ‘
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 31
                                            • 32
                                            • 23 / 32
