    Sketchup and Blender
    extensions
    170 Posts 26 Posters 46.2k Views 26 Watching
      I have that tool. Not really gonna work completely.
      • soloS Offline
        Rich, I pm'd a model for you to test.
        I was reluctant to send before as I assumed you may be a little busy and knackered after the arrival of the boys.
          Won't get at this short term. But will defo take a look and pass on whatever info I can.
          • arail1A Offline
            arail1
            @solo said:
            I may have a solution to my mesh problem
            http://cgcookie.com/downloads/contours-retopology-tool/
            Retopology tools have a different function than I think you're looking for. Create a high detail (high poly) character, texture it, light it, etc. Then bake all the maps down. Then 're-topologize' the high detail model with the retopology tool to make a low detail, low poly version and then apply the baked map to it. The result is a character with the visual look of the high detail model but having a small fraction of the poly count of the original.
            • soloS Offline
              What I was trying to do is get some of my SU created cartoon characters which are very heavy in SU into Blender cleaned up, rigged, posed and then 3D printed.
                Lobster
                You might be better off not trying to clean your mesh but just build a retopology on top of it even if you are not planning to bake maps. There are a few options, looks like you have found one of them, another is a shrinkwrap or bsurfaces but the failsafe way is just to use the snapping tools. I have done this a few times with MOI and sketchup models to build a proper deforming mesh for animation and doing the retopology allows you to concentrate on edge flow e.t.c.
                Slow at first but done enough times it speeds up, just like anything, especially with the looptools and F2 addons.
                Hope this helps.
                Regards
                Sam
                • arail1A Offline
                  arail1
                  Oh. My misunderstanding. I thought the comment was about architecture, which would be a lot of work for a retopology tool.
                  • arail1A Offline
                    arail1
                    Hmm ... but if your end point is 3D printing I would think you're going to lose a lot of detail with a retopology tool.
                    But, aside from the issue of SketchUp to Blender, if you're talking about cartoon characters, you're going to love sub d modeling once you get the hang of it.
                      Lobster
                      If detail is what you are after you can use a multires modifier and shrinkwrap on the retopology. shrinkwrap setting project positive and negative.
                      Regards.
                      • soloS Offline
                        Regards.
                        I have just learned about retopology and when to use it, interesting stuff that. So much to learn....
                        So here I am thinking Z-Brush is the king at sculpting, and just discovered Blenders Dynotopo, WoW!!
                        Blender is awesome.
                        • michaliszissiouM Offline
                          michaliszissiou
                          Blender sculpting methods are competitive to zbrush ones.
                          If this statement sounds like fanboyism you have to check it first.
                          http://wiki.blender.org/index.php/Dev:Ref/Release_Notes/2.66/Dynamic_Topology_Sculpting
                          • soloS Offline
                            I have seen a lot of your sculptures on Blender, I'm very interested in the style you use, not sure if you are using some sort of displacement brush or new method, got a link to a tutorial? Those scifi looking things (do not know what to call them as they look like organic space ships)
                              michaliszissiou
                              Oh, those scifi looking things?
                              Well, here is the huge thing LOL
                              http://blenderartists.org/forum/showthread.php?273033-Sculpting-with-UVs-and-displacements
                              How to align UVs on a geometrical texture. This is all about it.
                                Yep this Blender Artist thread is an antology one and a pleasure for the eyes! β˜€
                                Now more than 50 pages! And seems with no lilmit! πŸ’š
                                by Michalis πŸ˜‰
                                https://dl.dropboxusercontent.com/u/24090090/Screen Shot 2013-08-08 at 4.20.44 PM.jpg
                                The one who start this style was Gutalin with Zbrush πŸ˜‰ (who is not the same price than Blendy πŸ˜‰
                                http://www.this-is-cool.co.uk/wp-content/gallery/alex-kozhanov/alex-kozhanov-gutalin-sci-fi-horror-machine-art.jpg
                                • soloS Offline
                                  Okay, I did some leg work and believe I found a work around, I am still exploring how it all works but so far so good.
                                  Say you have an ugly mesh that you need to clean, simplify or turn to quads then use Z Brush or 3D Coat.
                                  Save model as an obj, open in 3D coat and hit autopo. It will fix holes, clean mesh and turn it into quads ready for 3D printing or use in another app like Blender, 3D Max etc as there are applinks.
                                  404 Not Found
                                  (3d-coat.com)
                                  Image shows original ugly SU mesh and new fixed mesh (also reduced) when reimporting to SU it triangulates again but this time it's clean.
                                  This is how the mesh is actually.
                                  Result.
                                  • arail1A Offline
                                    arail1
                                    That's a good looking mesh. A question - was the 'ugly' mesh made in SketchUp / Artisan?
                                    • soloS Offline
                                      Yeah, Artisan is awesome but it leaves a miserable mesh in it's wake.
                                        You have also Qremesher in Zbrush who makes automatic quadrangles!
                                        Maybe the best tool at this day!
                                        • jeff hammondJ Offline
                                          @solo said:
                                          I'm learning Blender arse about face, doing fluids, then particles and fabric.
                                          I want to have fun learning.
                                          i think that's an ok approach.
                                          the only real trick is sticking with it..
                                          you got it this time
                                            michaliszissiou
                                            Recent betas of 3dcoat! The implementation of a new auto-retopology algorithm. Still in beta but looks promising and already useable.
                                            Z remesher is a little better in organic shapes. 3dcoat is more promising on hard surface cases.
                                            Patience though, another auto retopo tool is coming soon. In blender this time. We'll try not to call it lke "b remesher" LOL
                                            Auto retopology is a dream that is coming true.
                                            Still, serious issues there. Auto retopo tools tend to create endless spiral loops around the mesh, in certain cases.
                                            This is rather impossible to manually edit it.
                                            Blender is great on manual retopology. It provides some excellent new tools. It suffers from ugly visualization issues. I got used to it but if you give a try you will understand what i'm talking about.
                                            1. contours tool and 2. grid bridge in blender re topology are wonderful and result to very fast and really clean results.
                                            @Pete
                                            Artisan is a nice tool for those who are afraid to get involved in other apps, especially blender.
                                            Because, artisan is basically a box modeling tool.
                                            Blender is superb on box modeling - subd by any aspect. You don't have to retopo anything as a good topology means loops, auto retopology is basically a box modeling. (from a certain point of view)
                                            @Pilou
                                            thanks,
                                            Gutalin is a great concept artist, an inspiration and a good Z friend.
                                            However "my" approach is reverse engineering somehow. My goal was to easily export all these as low poly objects to any external renderer or a game engine engine.
                                            Gutalin's approach is very difficult to be exported. (without lose of details and quality)
                                            BTW my artwork you posed above is box modeling - subd result and does not use displacements-UV workarounds.
                                            Here an example of how a low poly (<30-40k faces) looks like. Using Tangent normal maps in cycles. Such scenes take less than 30 sec to render. Ideal as background assets.
                                            https://dl.dropboxusercontent.com/u/24090090/normTestTube.jpg
                                            And, allow me, my favorite recent experiment.
                                            https://dl.dropboxusercontent.com/u/24090090/ab5.jpg
                                            • 6 / 9
