    • Anmelden
    Sketchup and Blender
    Geplant Angeheftet Gesperrt Verschoben Extensions & Applications Discussions
    extensions
    170 Beiträge 26 Kommentatoren 30.6k Aufrufe 26 Watching
    Lade mehr Beiträge
    • Älteste zuerst
    • Neuste zuerst
    • Meiste Stimmen
    Antworten
    • In einem neuen Thema antworten
    Anmelden zum Antworten
    Dieses Thema wurde gelöscht. Nur Nutzer mit entsprechenden Rechten können es sehen.
    • andybotA Offline
      andybot
      zuletzt editiert von
      @solo said:
      @rich o brien said:
      You want quad exports from SU into Blender?
      Ideally I'd like to model in SU as I have always done and export to Blender so that I can use the mesh from SU. I have tried converting models in SU to quads but that does not work great and I have tried converting tri's to quads in Blender which also does not work great.
      Having exported many SU models to Blender over the past year or so, I've found that if the mesh doesn't convert to quads well in SU (I use TT's Quad Tools) it's not going to convert well in Blender. The same errors that you find in the SU model will show up in the Blender conversion. You do need a very clean and logically constructed model to make use of quads in Blender.
      1 Antwort Letzte Antwort Antworten Zitieren 0
      • PixeroP Offline
        Pixero
        This video by Peter Guthrie shows his workflow from SketchUp to Max to have quads.
        I guess it's similar to Blender.
        This also led me to this idea for a SketchUp plugin: http://sketchucation.com/forums/viewtopic.php?f=323&t=54677#p495930
        • andybotA Offline
          andybot
          Nice work on the plugin 👍 I've been doing that manually for a long time, nice to have this automated. It matters a great deal if you are doing displacement or want to modify the mesh in any way (soften corners, etc.)
          However - n-gons are perfectly fine for architectural work. Those planes will render as planes regardless of the orientation or subdivisions of the mesh. For building models, I just import the whole mess into Blender and never have to bother with quads. (the only exception is that I still do tris to quads to simplify the mesh, and always remove duplicate vertices.) For windows it does matter because you need proper geometry to get refraction correctly.
          Another thing to note - mirrored components from SU will end up with reversed normals a lot of times (wrecks havoc on windows and refraction 😞 ). I'm wondering if it is worse with nested components though, may need to test that further.
            dedmin
            BlenderGuru announces Architecture Academy Competition winners.
            Blender Guru
            Blender Guru (www.blenderguru.com)
            • soloS Offline
              I may have a solution to my mesh problem
              Just a moment...
              (cgcookie.com)
              • Rich O BrienR Online
                I have that tool. Not really gonna work completely.
                • soloS Offline
                  Rich, I pm'd a model for you to test.
                  I was reluctant to send before as I assumed you may be a little busy and knackered after the arrival of the boys.
                    Won't get at this short term. But will defo take a look and pass on whatever info I can.
                    • arail1A Offline
                      arail1
                      Just a moment...
                      (cgcookie.com)
                      Retopology tools have a different function than I think you're looking for. Create a high detail (high poly) character, texture it, light it, etc. Then bake all the maps down. Then 're-topologize' the high detail model with the retopology tool to make a low detail, low poly version and then apply the baked map to it. The result is a character with the visual look of the high detail model but having a small fraction of the poly count of the original.
                      • soloS Offline
                        @arail1 said:
                        Just a moment...
                        (cgcookie.com)
                        What I was trying to do is get some of my SU created cartoon characters which are very heavy in SU into Blender cleaned up, rigged, posed and then 3D printed.
                          Lobster
                          You might be better off not trying to clean your mesh but just build a retopology on top of it even if you are not planning to bake maps. There are a few options, looks like you have found one of them, another is a shrinkwrap or bsurfaces but the failsafe way is just to use the snapping tools. I have done this a few times with MOI and sketchup models to build a proper deforming mesh for animation and doing the retopology allows you to concentrate on edge flow e.t.c.
                          Slow at first but done enough times it speeds up, just like anything, especially with the looptools and F2 addons.
                          Hope this helps.
                          Regards
                          Sam
                          • arail1A Offline
                            arail1
                            @solo said:
                            @arail1 said:
                            Just a moment...
                            (cgcookie.com)
                            Oh. My misunderstanding. I thought the comment was about architecture, which would be a lot of work for a retopology tool.
                            • arail1A Offline
                              arail1
                              Hmm ... but if your end point is 3D printing I would think you're going to lose a lot of detail with a retopology tool.
                              But, aside from the issue of SketchUp to Blender, if you're talking about cartoon characters, you're going to love sub d modeling once you get the hang of it.
                                Lobster
                                If detail is what you are after you can use a multires modifier and shrinkwrap on the retopology. shrinkwrap setting project positive and negative.
                                Regards.
                                • soloS Offline
                                  Regards.
                                  I have just learned about retopology and when to use it, interesting stuff that. So much to learn....
                                  So here I am thinking Z-Brush is the king at sculpting, and just discovered Blenders Dynotopo, WoW!!
                                  Blender is awesome.
                                  • michaliszissiouM Offline
                                    michaliszissiou
                                    Blender sculpting methods are competitive to zbrush ones.
                                    If this statement sounds like fanboyism you have to check it first.
                                    http://wiki.blender.org/index.php/Dev:Ref/Release_Notes/2.66/Dynamic_Topology_Sculpting
                                    • soloS Offline
                                      I have seen a lot of your sculptures on Blender, I'm very interested in the style you use, not sure if you are using some sort of displacement brush or new method, got a link to a tutorial? Those scifi looking things (do not know what to call them as they look like organic space ships)
                                        michaliszissiou
                                        Oh, those scifi looking things?
                                        Well, here is the huge thing LOL
                                        http://blenderartists.org/forum/showthread.php?273033-Sculpting-with-UVs-and-displacements
                                        How to align UVs on a geometrical texture. This is all about it.
                                          Yep this Blender Artist thread is an antology one and a pleasure for the eyes! ☀
                                          Now more than 50 pages! And seems with no lilmit! 💚
                                          by Michalis 😉
                                          https://dl.dropboxusercontent.com/u/24090090/Screen Shot 2013-08-08 at 4.20.44 PM.jpg
                                          The one who start this style was Gutalin with Zbrush 😉 (who is not the same price than Blendy 😉
                                          http://www.this-is-cool.co.uk/wp-content/gallery/alex-kozhanov/alex-kozhanov-gutalin-sci-fi-horror-machine-art.jpg
                                          • soloS Offline
                                            Okay, I did some leg work and believe I found a work around, I am still exploring how it all works but so far so good.
                                            Say you have an ugly mesh that you need to clean, simplify or turn to quads then use Z Brush or 3D Coat.
                                            Save model as an obj, open in 3D coat and hit autopo. It will fix holes, clean mesh and turn it into quads ready for 3D printing or use in another app like Blender, 3D Max etc as there are applinks.
                                            http://3d-coat.com/applinks/
                                            Image shows original ugly SU mesh and new fixed mesh (also reduced) when reimporting to SU it triangulates again but this time it's clean.
                                            This is how the mesh is actually.
                                            Result.
                                            • 4 / 9
                                            • Erster Beitrag
                                              Letzter Beitrag
