    [Plugin] Helix along curve
    100 Posts 58 Posters 176.9k Views 58 Watching
      Yes! Look Minute 5.04 ! ๐Ÿ˜‰
      • gillesG
        gilles
        @james_mcl said:
        Can this plugin be used for screw threads?
        Any help would be appreciated.
        Have a look there:
        http://sketchucation.com/forums/viewtopic.php?p=240238#p122571
        • G
          glasstronomic
          Hi 3dalbertsoft,
          Thank you very much for this great plugin!
          On a related issue, I am desperately trying to find a way to model, in SU, a conical helix where the helix maintains a constant and specific pitch angle to the conical surface. It is also known as a conical log spiral. Can anyone help me?
          The helix I am describing would have the coils get closer together as they approach the apex of the cone. Here is an example:
          http://www.satimo.com/sites/www.satimo.com/files/imagecache/product_view/Conical spiral_0.jpg
            james_mcl
            Thanks Pilou and Gilles for the information posted. it was very helpful.
              3dalbertsoft
              glasstronomic these options will be added in upcoming updates, for now the closest it say Pilou the min 5
              • C
                Cerboney
                Hi all,
                Please could somebody tell me how to install that plugin step by step ? Because it doesn't work for me. I install it but there is an error message when I open Sketchup. I use Google Sketchup 8 in French on Windows 8.
                Thank you guys
                Cerboney
                  What's the error message? ๐Ÿ˜’
                    How have you 'installed it' ? ๐Ÿ˜•
                    What are the errors?
                    I suspect they relate to missing files ??
                    This plugin's archive [ZIP file] looks like the attached image.
                    Copy those two items into the Plugins folder, keeping the contents in the same relationship.
                    That is one .rb file and the plugins's subfolder [containing other code files, images etc].
                    You need FULL read/write security permissions to the main Plugins folder...
                    ['Compatibility Files' issues and the 'VirtualStore' beckon otherwise ๐Ÿ˜’ ]
                    Also set SketchUp.exe to 'Always Runs as Administrator'...
                    There are may posts covering these aspects in great detail...
                    • C
                      Cerboney
                      Hi thank you TIG for your help, it works thanks to your explanations. I think I copied only the .rb file in the folder "Plugins" of Sketchup.
                      Bye
                        dacastror
                        playing
                          dacastror
                          the helix is closed properly!
                          • F
                            fcohen
                            Thank you for this plug-in. Very useful! I am looking to hire a contractor to take my hand-drawn sketches of a mens watch project (details at http://www.votsh.com) and create SketchUp files. Please email me fcohen at votsh.com for details on the contract. Thanks! -Frank
                              3dalbertsoft
                              I have verified that helix along curve works in sketchup 2014, you can install and use without problems
                              ๐Ÿ˜‰
                              • H
                                Harry K
                                I don't seem to be able to get it to install properly. Running OSX 10.8.5. Am placing files in Library/Application Support/Sketchup 2014/Sketchup/Plugins.
                                Any ideas?
                                  What does this mean specifically? Did you just drop the downloaded ZIP file into the Plugins folder? If so, that won't work indeed because you didn't actually install the plugin.
                                  If you did that, move the zip file back out of the Plugins folder to somewhere else. Maybe Downloads. Then right click on the zip file and choose Get Info. There change the extension from .zip to .rbz. In SketchUp click on the SketchUp menu and choose Preference>Extensions. Click on Install Extension. Navigate to the file and click Open. Click Yes and OK as they show. The plugin should now be installed correctly.
                                  If you did anything else, go to the Plugins folder and delete any and all related files before making the .rbz file and installing it.
                                  Most plugins are available through the Sketchucation Plugin Store--link at the top of the page or the Extension Warehouse. You don't have to do all these gymnastics to install plugins with them but you should at least install the SCF Plugin Store.
                                  • H
                                    Harry K
                                    Mac OSX automatically unzips, but the extension was wrong (tbs, rb), so I added the "z" AND the system also hides the library so you can't navigate to it via preferences > extensions.... But I found a way to "unhide" the Library. I was then able to choose the extension...only to be greeted with "unable to open..."
                                    Is there a Plan B?
                                      You don't need a plan B. You need to follow plan A.
                                      AGAIN:
                                      -Remove the files you inserted into the Plugins folder because you've done it wrong.
                                      -Make sure you have permissions set to Read and Write for the Plugins folder.
                                      -Find the ZIP file and rename it from .zip to .rbz. DO NOT OPEN THE ZIP FILE. DO NOT TOUCH ANYTHING INSIDE IT.
                                      -Open SketchUp.
                                      -Go to the SketchUp menu--left of File and click on Preferences.
                                      -Select Extensions from the list in the Preferences window.
                                      -Click on Install Extension.
                                      -Navigate to where you downloaded and saved the zip file (which is now a .rbz file).
                                      -Select it.
                                      -Click Open
                                      -Click Yes and OK as they present themselves.
                                      -Close the Preferences box.
                                      The plugin should now be installed.
                                      • H
                                        Harry K
                                        Ahhh. My browser was auto-unzipping the download. Changed that and it worked like a charm.
                                        Many thanks for your patience.
                                        • H
                                          hgdn
                                          Oh, what a fun/amazing plugin ever, works and so much creative outcomes with quick changes, thanks so much to 3dalbertsoft!!!!
                                          • G
                                            GregorS
                                            My suggestions for the English text describing the plugin options:
                                            These are the Helix along curve plugin options:
                                            You can set a value for the radius of the helix start and another for the end (these values can be positive or negative)
                                            You can set the number of turns of the helix (this value can be a positive integer or a positive decimal)
                                            Specify the number of line segments that make up each turn of the helix (this value can be a positive integer decimal)
                                            Modify the start angle of the helix (the angle value should be given in degrees as an integer or decimal)
                                            Set the level of "noise" (the value entered must be between 0 and 1), this will add a different random value to each turn radius of the helix. This random noise will be greater when the input value is closer to 1
                                            You can choose from five different options for a parameter called "adherence to the curve", which defines whether the helical curve will strictly or smoothly. (smooth is recommended for best results).
                                            The "Calculation mode" simply summarizes multiple internal parameters that would not be easily understood by users. Sometimes very steep curves can cause unwanted results, in these cases smoother curves or slightly different tests can be performed by varying the "calculation method" to find out which will give the best results for that particular curve. If you are not having problems, it is advisable to leave this value in recommended mode (C)
                                            You can set the direction of rotation of the helix, i.e. rotation in the clockwise or counterclockwise direction
                                            Helicoid will create with a curve or a circular tube.
                                            If you choose to create a tube, you can set your ratio (the value entered must be a positive integer or a positive decimal).
                                            You can specify the number of sides of the tube (which can be a minimum of 3 sides, this value must be a positive integer).
                                            Now I will try to design a lamp with the plugin! If I can install it! there were no installation instructions so I do not know where to put the files extracted from the .zip...
                                            • 4 / 5
