    Sketchup and Blender
    extensions
    170 Posts 26 Posters 30.5k Views 26 Watching
      Yes modeled in SU to a point just to figure out vert placement and form. Then into Blender for tweaking and some edge loops, creases and sub-d
        BTW, a better way to figure what key does what...
        waldobronchart.be
        (waldobronchart.be)
        • soloS Offline
          Now I'm goofing around with fluid flow.
          I'm learning Blender arse about face, doing fluids, then particles and fabric.
          I want to have fun learning.
          Some crazy DOF and HDRI lighting with a few emitters.
            Is that with Thea plugin?
            • soloS Offline
              Yes.
                I must invest in it.
                • soloS Offline
                  Looks like it's free.
                  (www.thearender.com)
                  Oh, do follow the installation guide as I messed up initially, there are a couple of steps that are important.
                    Awesome...
                      Next up is to try out some Cell Fracture...enable under preferences > addons
                      • soloS Offline
                        [attachment=0:120nuup0]<!-- ia0 -->thea-cracked.gif<!-- ia0 -->[/attachment:120nuup0]
                        So where does one get a tutorial or instructions on how to use these plugins?
                          Most I just muddle into...
                          I see a technique used for something different and tend to adapt it.
                          Here I realised that the Cell Fracture tool and some keyframing on scaling might look nice.
                          Not quite but something to file away....
                          There's an extensive tutorial on Cell Fracture on how to shoot a coffee cup with a bullet.
                          • soloS Offline
                            Found it: http://www.youtube.com/watch?v=DEo_9AopfoQ
                              That's the one. Pretty involved but covers some killers parts of blender. Expect 4 days to complete that.
                              You really should pick an object or topic and run with it.
                              I remember nearly 3yrs ago starting off on v2.5 and doing the same tutorial nearly 10 times until I didn't need to reference the video.
                              That helped loads. Boring but worth it.
                              Another good one is Kent Tramell's human male head modelling series. Nearly 12hrs but mesmerising stuff.
                              • soloS Offline
                                That was fun, here is a very low resolution gif of my first try.
                                Click on image to animate.
                                  Great stuff.
                                  Next is to see what the Build modifier can do. You like that I think.
                                  • michaliszissiouM Offline
                                    michaliszissiou
                                    Hey guysโ€ฆ
                                    You really need a lot of help.
                                    We could try a meeting
                                    google hangout.
                                    Sharing screens etc
                                    I do it all the time.
                                    for instance, you won't find a good UV tutorial around
                                    neither a good tutorial on cycles.
                                    Oh my,
                                    You could join the blender sculpting club instead.
                                    TIP OF THE DAY
                                    [0] num pad for camera view.
                                    Select your object or something in the center of the scene
                                    On [N] panel, check LockCameraToView.
                                    Navigate now, zoom etc.
                                    Uncheck LockCamera, zoom so the camera window fill your view port, check LockCamera again, navigate
                                    More friendly to SUpUsers?
                                      DOD3R
                                      Hi solo,
                                      Can you share story about your journey from SU to blender. I know you mentioned some Cinema4d somewhere.
                                      I think it must be interesting.
                                      I am myself was lurking around blender for a long time. It supposed to be a solution for uv mapping absence in SU, but i so far had no time to invest my time into it.
                                      D.
                                        archigrafix
                                        Hi Solo and everyone I think I will join youonthis Blender trip...
                                        I myself many times tried to jump from SU to Blender or SU to Modo, but always switched back to SU. Why? Mostly because I work on architectures and I feel so well an easy for that in Sketchup. Anyway if I want to go further on architectural renderings: HighPoly,UVs, integrated renderer etc... Blender feels a good choice
                                        I recently booked to Andrew Price Architectural academy and I feel it very nice and exciting, if only I get more time to spend on it of course ๐Ÿ˜ณ
                                        Agir comme un homme de pensรฉe, et penser comme un homme d'action...
                                        • soloS Offline
                                          @dod3r said:
                                          Hi solo,
                                          D.
                                          DOD3R, I really have no story, I did try Cinema4D and thought it was great but it was pricey and not as comprehensive as Blender that has everything one could possibly need and free. The thing is when I initially tried to learn Blender in 2005 it was one big mess, the UI was all over the place and short cuts and keys did not match between modeling tools, now with the whole new UI it's a hell of a lot better but still not as polished as say Maya, but certainly getting there fast. The best resource for Blender is Google as I can Google any question and I get a solution or even a YouTube tutorial.
                                          That being said I am also very lazy, and learning new software is like scraping nails across a blackboard, I usually only learn things I need to know relevant to a project. However I decided to find fun stuff to do in Blender and follow tutorials in order to create them, doing so I will learn all the other stuff around them and hopefully by the end of a few cool tutorials I will have the knowledge to try something on my own.
                                          • cottyC Offline
                                            cotty
                                            Is that the new basecamp hat in your avatar? ๐Ÿ˜‰
                                            my SketchUp gallery
                                            • 4 / 9
