    [Plugin] FredoTools - v4.5c - 24 Jun 24
    463 Posts 123 Posters 709.9k Views 121 Watching
    • fredo6F Offline
      @chon said:
      Fredo,
      I've got an issue using FredoTools with AdditionalPluginFolders.
      The problem is related here with shortcuts for illustration.
      Many thanks to look at that ! πŸ‘
      It seems the issue is in LibFredo6 actually (error in the logging of errors!!). I don't know why you have FredoTools in error. Possibly you may open the Windows > LibFredo6 Settings > View Trace Files... dialog box and check if there is more info (in red).
      Anyway, I would suggest the following
      • Upgrade to AdditionalPluginFolders 4.2a
      • Upgrade to LibFredo6 5.3g (just published).
      Then, if you still get the error, could try to drop and replace the attached file Fredo6_!LibFredo6.rb in the directory where you installed my scripts.
      • chonC Offline
        chon
        Thanks for help Fredo ! πŸ‘
        Here is the "View trace files" :
        As you can see, my Fredo6 tools are up to date... πŸ˜‰
        Another question : Fredo6 has created a default parameters folder on the first level of C:/ (visible on the 4th line of the "View trace files").
        Is it possible to locate this folder at another place ?
        • chonC Offline
          chon
          Fredo,
          update of Libfredo6 solved part of the problem but not all :
          Here is the message error :
          Here is the trace log (only error items) :
          >>>> 1383119187.795;Lib6Core.rb;649;  in `load_full_rubies'
          ?FredoTools 1.2a; ERROR in Loading ruby file FredoTools__ThruPaint.rb
          undefined method `register_plug' for FredoTools;Module -  //X/SketchUp/Plugins_Communs/FREDOTOOLS_Dir_12/FredoTools__ThruPaint.rb;34
          >>>> 1383119187.824;Lib6Core.rb;649;  in `load_full_rubies'
          ?FredoTools 1.2a; ERROR in Loading ruby file FredoTools__RemoveLonelyVertices.rb
          undefined method `register_plug' for FredoTools;Module -  //X/SketchUp/Plugins_Communs/FREDOTOOLS_Dir_12/FredoTools__RemoveLonelyVertices.rb;36
          >>>> 1383119187.853;Lib6Core.rb;649;  in `load_full_rubies'
          ?FredoTools 1.2a; ERROR in Loading ruby file FredoTools__MarkVertices.rb
          undefined method `register_plug' for FredoTools;Module -  //X/SketchUp/Plugins_Communs/FREDOTOOLS_Dir_12/FredoTools__MarkVertices.rb;36
          >>>> 1383119187.877;Lib6Core.rb;649;  in `load_full_rubies'
          ?FredoTools 1.2a; ERROR in Loading ruby file FredoTools__CountFacesBySides.rb
          undefined method `register_plug' for FredoTools;Module -  //X/SketchUp/Plugins_Communs/FREDOTOOLS_Dir_12/FredoTools__CountFacesBySides.rb;34
          >>>> 1383119187.892;Lib6Core.rb;649;  in `load_full_rubies'
          ?FredoTools 1.2a; ERROR in Loading ruby file FredoTools__ReverseOrientFaces.rb
          undefined method `register_plug' for FredoTools;Module -  //X/SketchUp/Plugins_Communs/FREDOTOOLS_Dir_12/FredoTools__ReverseOrientFaces.rb;34
          >>>> 1383119187.942;Lib6Core.rb;649;  in `load_full_rubies'
          ?FredoTools 1.2a; ERROR in Loading ruby file FredoTools__ReportLabelArea.rb
          undefined method `register_plug' for FredoTools;Module -  //X/SketchUp/Plugins_Communs/FREDOTOOLS_Dir_12/FredoTools__ReportLabelArea.rb;34
          ConstructFaceNormal, CurviShear and RevertCurve seem to work fine ! πŸ‘
          • fredo6F Offline
            Very very strange.
            I would expect that none works or all work.
            I'll have a closer look
            Could you show me the content of the subfolder FREDOTOOLS_Dir_12 (files and dates)
            • chonC Offline
              chon
              • LAGRARI2012L Offline
                LAGRARI2012
                very good contribution πŸ‘ πŸ‘ πŸ‘
                • fredo6F Offline
                  NEW RELEASE: FredoTools v1.4a - 30 Oct 13
                  This update implements new naming conventions, fixes a few bugs for future compatibility.
                  See main post of this thread for download of FredoTools.
                    parsleybrain
                    Some of my Fredo plugins need an update now. I've never done this before, so my question is how to update those plugins? Do I uninstall the older versions first and download the newer ones or just download the new version and the plugins are updated automatically in this way? Thanks for any help.
                    • fredo6F Offline
                      There is no 'uninstallation' of my plugins (as these are just files in folders). So You can safely install the new versions
                      1. I would suggest that you first install the SCF Plugin Store plugin, if not already done. This is the safest and easiest way to install plugins.
                      2. Install LibFredo6 first, then the other plugins
                      3. Once you have installed, you can go to Windows > LibFredo6 Settings... > Purge Obsolete files and delete the files and folders related to the previous versions
                        parsleybrain
                        Thank you very much, I got it. Also thanks for all your great tools and plugins. I just start to learn and appreciate your tools since I'm beginner but nevertheless I can see the greatness. πŸ˜„
                        • ArisA Offline
                          Aris
                          Hello everybody!
                          I'm trying to make a bent stair, so I created the stair's "profile" and intended to bend it using radial bending and then joint push pull in order to give it width.
                          in order to do that, I made the steps as simple as possible and turned slicing off (so that the shape would be bent only at the vertical edges.
                          unfortunatelly, bending screwed up the normals and when I tried to use the JPP faces were extruded weirdly.
                          Is there something I can do about it?
                          I know that a solution would be to extrude first and bend later, but because of reasons of repetition and workflow It would serve me better to do it this way
                          Not a native speaker, point out my spelling (or other) mistakes, I won't be offended!!!
                          • N Offline
                            Nph92
                            When i install this plugin it tells me, you need the version 5.2 libfredo and so on, and i have that, or even a later one, so after ive installed it nothing happens? the same thing happened to fredoScale but for some reason that got installed, and im using it without a problem? any quick solution ?
                              Instead of using soften/smooth on the vertical almost-coplanar edges try making them just 'hidden' ??
                              • fredo6F Offline
                                NEW RELEASE: FredoTools v1.5a - 27 Nov 13
                                FredoTools 1.5a is a release for future Sketchup compatibility. It is advised to upgrade even if there are no functional changes.
                                • fredo6F Offline
                                  NEW RELEASE: FredoTools v1.6g - 24 Jan 14
                                  FredoTools 1.6g is a release for EdgeInspector v1.0.
                                    Ben Ritter
                                    Fredo, thank you, again. You are generous, and talented.
                                    • OxerO Offline
                                      Oxer
                                      Thanks Fredo for this new useful tool !! πŸ‘
                                      I have updated the Spanish Language (Spain) to include EdgeInspector.
                                      Spanish Language (Spain) v1.6g
                                      • fredo6F Offline
                                        Oxer,
                                        Thanks for that. This is a piece of work.
                                        Will go into the next release, so very soon.
                                        • O Offline
                                          Orthogon
                                          I now get this error:
                                          FredoTools 1.6g: Error starting up plugin (creating menus and icons)
                                          undefined method 'values' for nil:NilClass [in FredoTools.rb -
                                          #'startup(): line 210]
                                          ...Lib6Core.rb:580in 'effective_load_part2'
                                          Then an error message with a Trace Log...
                                          Am using LibFredo v5.5g.
                                          • fredo6F Offline
                                            NEW RELEASE: FredoTools v1.7a - 15 Feb 14
                                            FredoTools 1.7a is a release for EdgeInspector 1.1a, which introduces the detection and fixing of 2 new defects: lost junctions and needle-eyes.
                                            See main post of this thread for Download of FredoTools.
                                            • 23
                                            • 24
                                            • 8 / 24
