    [Plugin] FredoTools - v4.6a - 21 Oct 26
    465 Posts 124 Posters 916.7k Views 122 Watching
    • fredo6F
      NEW RELEASE: FredoTools v1.4a - 30 Oct 13
      This update implements new naming conventions, fixes a few bugs for future compatibility.
      See main post of this thread for download of FredoTools.
      • P
        parsleybrain
        Some of my Fredo plugins need an update now. I've never done this before, so my question is how to update those plugins? Do I uninstall the older versions first and download the newer ones or just download the new version and the plugins are updated automatically in this way? Thanks for any help.
        • fredo6F
          There is no 'uninstallation' of my plugins (as these are just files in folders). So You can safely install the new versions
          1. I would suggest that you first install the SCF Plugin Store plugin, if not already done. This is the safest and easiest way to install plugins.
          2. Install LibFredo6 first, then the other plugins
          3. Once you have installed, you can go to Windows > LibFredo6 Settings... > Purge Obsolete files and delete the files and folders related to the previous versions
          • P
            parsleybrain
            Thank you very much, I got it. Also thanks for all your great tools and plugins. I just start to learn and appreciate your tools since I'm beginner but nevertheless I can see the greatness. ๐Ÿ˜„
            • ArisA
              Aris
              Hello everybody!
              I'm trying to make a bent stair, so I created the stair's "profile" and intended to bend it using radial bending and then joint push pull in order to give it width.
              in order to do that, I made the steps as simple as possible and turned slicing off (so that the shape would be bent only at the vertical edges.
              unfortunatelly, bending screwed up the normals and when I tried to use the JPP faces were extruded weirdly.
              Is there something I can do about it?
              I know that a solution would be to extrude first and bend later, but because of reasons of repetition and workflow It would serve me better to do it this way
              Not a native speaker, point out my spelling (or other) mistakes, I won't be offended!!!
              • N
                Nph92
                When i install this plugin it tells me, you need the version 5.2 libfredo and so on, and i have that, or even a later one, so after ive installed it nothing happens? the same thing happened to fredoScale but for some reason that got installed, and im using it without a problem? any quick solution ?
                  Instead of using soften/smooth on the vertical almost-coplanar edges try making them just 'hidden' ??
                  • fredo6F
                    NEW RELEASE: FredoTools v1.5a - 27 Nov 13
                    FredoTools 1.5a is a release for future Sketchup compatibility. It is advised to upgrade even if there are no functional changes.
                    • fredo6F
                      NEW RELEASE: FredoTools v1.6g - 24 Jan 14
                      FredoTools 1.6g is a release for EdgeInspector v1.0.
                      • B
                        Ben Ritter
                        Fredo, thank you, again. You are generous, and talented.
                        • OxerO
                          Oxer
                          Thanks Fredo for this new useful tool !! ๐Ÿ‘
                          I have updated the Spanish Language (Spain) to include EdgeInspector.
                          Spanish Language (Spain) v1.6g
                          • fredo6F
                            Oxer,
                            Thanks for that. This is a piece of work.
                            Will go into the next release, so very soon.
                            • O
                              Orthogon
                              I now get this error:
                              FredoTools 1.6g: Error starting up plugin (creating menus and icons)
                              undefined method 'values' for nil:NilClass [in FredoTools.rb -
                              #'startup(): line 210]
                              ...Lib6Core.rb:580in 'effective_load_part2'
                              Then an error message with a Trace Log...
                              Am using LibFredo v5.5g.
                              • fredo6F
                                NEW RELEASE: FredoTools v1.7a - 15 Feb 14
                                FredoTools 1.7a is a release for EdgeInspector 1.1a, which introduces the detection and fixing of 2 new defects: lost junctions and needle-eyes.
                                See main post of this thread for Download of FredoTools.
                                • cottyC
                                  cotty
                                  Thank you for this great update!
                                  my SketchUp gallery
                                    dedmin
                                    Su 2013 Pro, Win 7 64 bit
                                    Video_2014-02-16_140138.wmv
                                      rv1974
                                      dedmin, how do you grab into .wmv?
                                        dedmin
                                        (www.faststone.org)
                                        • fredo6F
                                          @dedmin
                                          Thanks for signaling. This is actually a bug concerning Curvizard, not FredoTools.
                                          I fixed it and republished as Curvizard 1.7b.
                                          • guanjinG
                                            guanjin
                                            @fredo6 said:
                                            @dedmin
                                            The latest version, the pop-up dialog box displays a blankใ€‚
                                            Be sure to activate the other tools, and then activate it to appear.
                                            Earlier versions without problems
