    [Plugin] FredoTools - v4.6a - 21 Oct 26
    465 Posts 124 Posters 916.7k Views 122 Watching
    • chonC
      chon
      Fredo,
      update of Libfredo6 solved part of the problem but not all :
      Here is the message error :
      Here is the trace log (only error items) :
      >>>> 1383119187.795;Lib6Core.rb;649;  in `load_full_rubies'
      ?FredoTools 1.2a; ERROR in Loading ruby file FredoTools__ThruPaint.rb
      undefined method `register_plug' for FredoTools;Module -  //X/SketchUp/Plugins_Communs/FREDOTOOLS_Dir_12/FredoTools__ThruPaint.rb;34
      >>>> 1383119187.824;Lib6Core.rb;649;  in `load_full_rubies'
      ?FredoTools 1.2a; ERROR in Loading ruby file FredoTools__RemoveLonelyVertices.rb
      undefined method `register_plug' for FredoTools;Module -  //X/SketchUp/Plugins_Communs/FREDOTOOLS_Dir_12/FredoTools__RemoveLonelyVertices.rb;36
      >>>> 1383119187.853;Lib6Core.rb;649;  in `load_full_rubies'
      ?FredoTools 1.2a; ERROR in Loading ruby file FredoTools__MarkVertices.rb
      undefined method `register_plug' for FredoTools;Module -  //X/SketchUp/Plugins_Communs/FREDOTOOLS_Dir_12/FredoTools__MarkVertices.rb;36
      >>>> 1383119187.877;Lib6Core.rb;649;  in `load_full_rubies'
      ?FredoTools 1.2a; ERROR in Loading ruby file FredoTools__CountFacesBySides.rb
      undefined method `register_plug' for FredoTools;Module -  //X/SketchUp/Plugins_Communs/FREDOTOOLS_Dir_12/FredoTools__CountFacesBySides.rb;34
      >>>> 1383119187.892;Lib6Core.rb;649;  in `load_full_rubies'
      ?FredoTools 1.2a; ERROR in Loading ruby file FredoTools__ReverseOrientFaces.rb
      undefined method `register_plug' for FredoTools;Module -  //X/SketchUp/Plugins_Communs/FREDOTOOLS_Dir_12/FredoTools__ReverseOrientFaces.rb;34
      >>>> 1383119187.942;Lib6Core.rb;649;  in `load_full_rubies'
      ?FredoTools 1.2a; ERROR in Loading ruby file FredoTools__ReportLabelArea.rb
      undefined method `register_plug' for FredoTools;Module -  //X/SketchUp/Plugins_Communs/FREDOTOOLS_Dir_12/FredoTools__ReportLabelArea.rb;34
      ConstructFaceNormal, CurviShear and RevertCurve seem to work fine ! πŸ‘
      SU2019 pro 19.3.253 + VRay 4.00.02 (Next) on Win11-64Bits
      • fredo6F
        Very very strange.
        I would expect that none works or all work.
        I'll have a closer look
        Could you show me the content of the subfolder FREDOTOOLS_Dir_12 (files and dates)
        • chonC
          chon
          • LAGRARI2012L
            LAGRARI2012
            very good contribution πŸ‘ πŸ‘ πŸ‘
            • fredo6F
              NEW RELEASE: FredoTools v1.4a - 30 Oct 13
              This update implements new naming conventions, fixes a few bugs for future compatibility.
              See main post of this thread for download of FredoTools.
              • P
                parsleybrain
                Some of my Fredo plugins need an update now. I've never done this before, so my question is how to update those plugins? Do I uninstall the older versions first and download the newer ones or just download the new version and the plugins are updated automatically in this way? Thanks for any help.
                • fredo6F
                  There is no 'uninstallation' of my plugins (as these are just files in folders). So You can safely install the new versions
                  1. I would suggest that you first install the SCF Plugin Store plugin, if not already done. This is the safest and easiest way to install plugins.
                  2. Install LibFredo6 first, then the other plugins
                  3. Once you have installed, you can go to Windows > LibFredo6 Settings... > Purge Obsolete files and delete the files and folders related to the previous versions
                  • P
                    parsleybrain
                    Thank you very much, I got it. Also thanks for all your great tools and plugins. I just start to learn and appreciate your tools since I'm beginner but nevertheless I can see the greatness. πŸ˜„
                    • ArisA
                      Aris
                      Hello everybody!
                      I'm trying to make a bent stair, so I created the stair's "profile" and intended to bend it using radial bending and then joint push pull in order to give it width.
                      in order to do that, I made the steps as simple as possible and turned slicing off (so that the shape would be bent only at the vertical edges.
                      unfortunatelly, bending screwed up the normals and when I tried to use the JPP faces were extruded weirdly.
                      Is there something I can do about it?
                      I know that a solution would be to extrude first and bend later, but because of reasons of repetition and workflow It would serve me better to do it this way
                      Not a native speaker, point out my spelling (or other) mistakes, I won't be offended!!!
                      • N
                        Nph92
                        When i install this plugin it tells me, you need the version 5.2 libfredo and so on, and i have that, or even a later one, so after ive installed it nothing happens? the same thing happened to fredoScale but for some reason that got installed, and im using it without a problem? any quick solution ?
                          Instead of using soften/smooth on the vertical almost-coplanar edges try making them just 'hidden' ??
                          • fredo6F
                            NEW RELEASE: FredoTools v1.5a - 27 Nov 13
                            FredoTools 1.5a is a release for future Sketchup compatibility. It is advised to upgrade even if there are no functional changes.
                            • fredo6F
                              NEW RELEASE: FredoTools v1.6g - 24 Jan 14
                              FredoTools 1.6g is a release for EdgeInspector v1.0.
                              • B
                                Ben Ritter
                                Fredo, thank you, again. You are generous, and talented.
                                • OxerO
                                  Oxer
                                  Thanks Fredo for this new useful tool !! πŸ‘
                                  I have updated the Spanish Language (Spain) to include EdgeInspector.
                                  Spanish Language (Spain) v1.6g
                                  • fredo6F
                                    Oxer,
                                    Thanks for that. This is a piece of work.
                                    Will go into the next release, so very soon.
                                    • O
                                      Orthogon
                                      I now get this error:
                                      FredoTools 1.6g: Error starting up plugin (creating menus and icons)
                                      undefined method 'values' for nil:NilClass [in FredoTools.rb -
                                      #'startup(): line 210]
                                      ...Lib6Core.rb:580in 'effective_load_part2'
                                      Then an error message with a Trace Log...
                                      Am using LibFredo v5.5g.
                                      • fredo6F
                                        NEW RELEASE: FredoTools v1.7a - 15 Feb 14
                                        FredoTools 1.7a is a release for EdgeInspector 1.1a, which introduces the detection and fixing of 2 new defects: lost junctions and needle-eyes.
                                        See main post of this thread for Download of FredoTools.
                                        • cottyC
                                          cotty
                                          Thank you for this great update!
                                          my SketchUp gallery
                                            dedmin
                                            Su 2013 Pro, Win 7 64 bit
                                            Video_2014-02-16_140138.wmv
                                            • 23
                                            • 24
                                            • 7 / 24
