    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 791.2k Views 175 Watching
      @aris said:
      I did what you said with the top left toolbars still nothing...
      Did you move all of the toolbars as I said?
      • ArisA Offline
        Aris
        Same story! I tried what you said, even relaunched SU and still it appears everywhere except
        the toolbars...
        Not a native speaker, point out my spelling (or other) mistakes, I won't be offended!!!
        • ArisA Offline
          Aris
          yes, I did move all the toolbars (before) and now that I removed everything, it still isn't there. (which I suppose is apparent since it doesn't appear as a choice in the right click menu...)
            That's is plain weird.
            Do you have v8 installed? If so is this reproducible on that?
            Can you post a screenie of your Plugins folder?
            • ArisA Offline
              Aris
              yes I have it installed and there's no problem there
              • ArisA Offline
                Aris
                here's the new plugins folder (I also gave it full rights)
                  And you are running the very latest release of 2013?
                  What's inside the ExtrudeTools folder?
                  You've the extension enabled under preferences?
                  You have it enabled in the SketchUcation Tools Managers?
                  • ArisA Offline
                    Aris
                    That's weird!
                    after I checked and unchecked it from the toolbars dialogue and moving around the other toolbars, it finaly appeared but without a frame, so I cannot move it!
                    • ArisA Offline
                      Aris
                      yes, I told you, it is checked/visible everywhere
                      plugins manager, plugins menu, preferences/extensions, toolbars dialogue
                      it's only absent in the toolbar right click menu.
                      • BoxB Offline
                        Double click on it now you can see it and it will come loose.
                          Try this: Enable the toolbar in View>Toolbars. Pull all of the toolbars off the top rows. Does the Extrude Tool toolbar show up in the upper left corner? If so, you have now found it and can place it where you need but you really ought to install the current version of SU2013. there was a bug in the first release that caused new toolbars to appear under the existing ones. It was fixed though.
                          Dave earlier mentioned this...
                          To me it looks like this is related to the bug Dave flagged.
                          What happens when you check for update under the Help menu?
                          • ArisA Offline
                            Aris
                            Sometimes giving up helps!
                            I reverted to the old plugins folder, relaunched SU and every toolbar appeared undocked, including ET!!!
                            I relaunched it a couple of times and now it seems stable.
                            finally to enjoy it (it's a great plugin).
                            • ArisA Offline
                              Aris
                              Doesn't installing it from plugin store guarantee that it's the latest version?
                              • BoxB Offline
                                He means the newest version of Sketchup itself, your problem suggests you have an old version.
                                • ArisA Offline
                                  Aris
                                  sorry, my bad. I thought you were referring to the plugin version all this time, I'm downloading latest sketchup right now. Thanks for bearing with me.
                                    Easy to miss out.
                                    Glad it works
                                      Yes. I wrote "...install the current version of SU2013." because I meant the current version of SketchUp.
                                        thegoodguy
                                        HI,
                                        Great set of tools. Thanks.
                                        A two-part question:
                                        About the "edges by face" and "edges by faces" tools. Is it possible to specify which point on the face(s) the edge endpoint aligns with? E.g. can you start the extrusion from the one of the pointed tips of a star-shape instead of the centre of the centre of the face?
                                        About the "edges by faces" tool. Is it possible to specify which endpoints on the starting face align/match-up with which endpoints on the ending face?
                                        I hope these questions make sense. I've attached an image to show what I mean. Shape (A) was produced using the tool. Shape (B) I did manually by choosing which endpoints are matched and then using a curve-stitching tool.
                                        Thanks again.
                                          jefecito
                                          The toolbar not load, is it normal in SU 2013?
                                            The toolbar displays just fine in SU2013 unless you installed the plugin incorrectly or perhaps don't have sufficient privileges set for the Plugins folder. What operating system? (please update your profile), how did you install the plugin? Do you have sufficient privileges?
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 31
                                            • 32
                                            • 21 / 32
