    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 1.0m Views 175 Watching
    • ArisA
      Aris
      I still have a problem!
      I made sure I'm an administrator, I gave full rights to the plugins folder, I set sketchup to "run as administrator" I reinstalled it 3 or four times and every time The contents of TIGtools file keep on disappearing upon starting sketchup! (the plugins are working, it's just that the toolbar is nowhere to be seen)
      Not a native speaker, point out my spelling (or other) mistakes, I won't be offended!!!
        Try this: Enable the toolbar in View>Toolbars. Pull all of the toolbars off the top rows. Does the Extrude Tool toolbar show up in the upper left corner? If so, you have now found it and can place it where you need but you really ought to install the current version of SU2013. there was a bug in the first release that caused new toolbars to appear under the existing ones. It was fixed though.
        • ArisA
          Aris
          ok, I've installed it from plugin store
          TIG: Extrude Tools v2.1
          IMPORTANT UPDATE - A varied toolset for Extruding Edges into meshes etc... Now future-proofed...
          Downloads: 6267 [ Version Updated: 2013/05/30 ]
          -the plugin appears checked in preferences/extensions/Extrude tools
          -It appears checked in view/toolbars.
          -It does not even appear as a choice when I left-click the toolbars void space...
          I did what you said with the top left toolbars still nothing...
          could there be some conflict with files from older versions left in plugins folder or some other plugin?
            You need to right click
            • ArisA
              Aris
              sorry, I meant right click...
                Put everything in your plugins into a folder named #plugins
                now install the Extrude .rbz file again an see if it appears
                You need to first rule out if there is a clash
                  Did you move all of the toolbars as I said?
                  • ArisA
                    Aris
                    Same story! I tried what you said, even relaunched SU and still it appears everywhere except
                    the toolbars...
                    • ArisA
                      Aris
                      yes, I did move all the toolbars (before) and now that I removed everything, it still isn't there. (which I suppose is apparent since it doesn't appear as a choice in the right click menu...)
                        That's is plain weird.
                        Do you have v8 installed? If so is this reproducible on that?
                        Can you post a screenie of your Plugins folder?
                        • ArisA
                          Aris
                          yes I have it installed and there's no problem there
                          • ArisA
                            Aris
                            here's the new plugins folder (I also gave it full rights)
                              And you are running the very latest release of 2013?
                              What's inside the ExtrudeTools folder?
                              You've the extension enabled under preferences?
                              You have it enabled in the SketchUcation Tools Managers?
                              • ArisA
                                Aris
                                That's weird!
                                after I checked and unchecked it from the toolbars dialogue and moving around the other toolbars, it finaly appeared but without a frame, so I cannot move it!
                                • ArisA
                                  Aris
                                  yes, I told you, it is checked/visible everywhere
                                  plugins manager, plugins menu, preferences/extensions, toolbars dialogue
                                  it's only absent in the toolbar right click menu.
                                  • BoxB
                                    Double click on it now you can see it and it will come loose.
                                      Dave earlier mentioned this...
                                      To me it looks like this is related to the bug Dave flagged.
                                      What happens when you check for update under the Help menu?
                                      • ArisA
                                        Aris
                                        Sometimes giving up helps!
                                        I reverted to the old plugins folder, relaunched SU and every toolbar appeared undocked, including ET!!!
                                        I relaunched it a couple of times and now it seems stable.
                                        finally to enjoy it (it's a great plugin).
                                        • ArisA
                                          Aris
                                          Doesn't installing it from plugin store guarantee that it's the latest version?
                                          • BoxB
                                            He means the newest version of Sketchup itself, your problem suggests you have an old version.
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 31
                                            • 32
                                            • 23 / 32
