    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 769.2k Views 175 Watching
      @Lorom
      The newer versions of the 'Extrusion Toolset' loads as an Extension.
      This might need to be activated [once].
      Check Preferences > Extensions list and/or the SketchUcation PluginStore Extension and Plugins Managers.
      If it's not being shown in those then it's not loading at all.
      If it is loading then its submenu item should appear under Plugins.
      Its toolbar might need activating from View > Toolbars [or right-click context-menu over a toolbar docking are in v2013].
      If its toolbar is shown as being active BUT it is not visible, then it suggests that you do not have the latest version of v2013... its early version had a well reported glitch that left some newly installed tools' toolbars active BUT docked behind already docked toolbars - usually in the top area. This can be resolved by dragging the toolbars off until you see the underlaid one[s] and dragging all of them off. You can now relocate these toolbars as desired. From now on these toolbars should behave as expected - BUT having the latest version for v2013 is highly recommended as it stops the issue altogether !
      If it's NOT even loading... then do you have FULL security permissions to your main Plugins folder ?
      If not, then you might have a 'Compatibility Files...' link/button in one of the top bars of your Plugins folder's Windows Explorer window?
      The files will have not been properly installed due to limitations on your permissions.
      To set these permissions correctly...
      As an admin [if you are not one give yourself that power in the Users Control Panel]
      Select the Plugins folder's icon
      Right-click
      Context-menu
      Properties
      Security
      Edit...
      Set all of the users/groups listed to FULL [read/write]
      Apply/OK
      Reinstall the toolset[s] and see if it's working now...
        lorom
        Ok, done!!!!
        The problem was a limitation on my permission!!!
        Thanks a lot TIG for your help and for your great plugin πŸ˜„
          Glad it's fixed πŸ˜„
          Another tip...
          Find the SketchUp.exe file in the ../Program Files/../SketchUp folder.
          Right-click
          Context-menu
          Compatibility
          Tick the check-box near the bottom saying 'Always run this application as an administrator' - this will also help to minimize future issues
            Tean
            I go into your website, but I cannot download your file .rb. I just get the file .lingvo. Even though I have the file .lingvo, i cannot use extrude tool. why??? πŸ˜’
              How did you get the toolset?
              If you have tried to install this manually you may have files in the wrong places, remove them and do it properly...
              Download it from the SketchUcation PluginStore as RBZ, then install the archive's contents using v8's Preferences > Extensions > Install... button.
              If you don't have that button then upgrade to the latest version of v8, early versions are missing the auto-installer feature.
              Everything should now be auto-installed correctly, using the correct subfolders etc.
              Restart SketchUp to ensure everything loads OK.
              Now activate the tool's Extension if needed and also its Toolbar...
              Look for its menu entry too...
              If it's still not working perhaps you have limited permission to add files to your Plugins folder and that is messing things up...
              To fix this...
              As an administrator [if you are not one already give yourself this capability in the Users Control Panel]
              In Windows Explorer find the Plugins folder.
              Select its icon.
              Right-click > Context-menu.
              Properties.
              Security.
              Edit...
              Give every user & group listed FULL read/write permissions.
              Apply/OK to complete changes...
              Also, in the folder that contains the Plugins folder, find the SketchUp.exe file.
              Properties.
              Compatibility.
              Tick the check-box near the bottom of the dialog 'Always Run as Administrator...'
              Apply/OK
              Restart SketchUp and reinstall the toolset, now retry as n the initial paragraphs above...
              • ArisA Offline
                Aris
                hello everyone!
                I have the strangest problem.
                I install Extrusion tools manualy, everything works perfectly, but the next time I open the program, it's gone! (some of the rb's are missing from the plugins folder.
                I checked the antiviruse's log and didn't find anything so it's not that.
                Does anyone have any idea what it could be?
                (SU pro 13)
                Not a native speaker, point out my spelling (or other) mistakes, I won't be offended!!!
                  Check that you have FULL security permissions to the Plugins folder.
                  If you have a custom-icon for the Plugins folder revert to the default because that can affect things oddly...
                  Next set permissions correctly...
                  As an Admin [if you are not one, then give yourself this power under the Control Panels > Users dialog]
                  Select the Plugins folder's icon...
                  Right-click > context-menu >
                  Properties > Security > Edit...
                  Ensure every user/group listed has FULL read/write permissions.
                  Apply/OK
                  If you had limited permission Windows can make it look like you have successfully installed files in the 'Programs Files' tree, but in fact you have not. It has put them in a VirtualStore, where SketchUp can't load from !
                  Having a button/link in the top bars of the Plugins folder's Windows Explorer window saying 'Compatibility Files...' is a sure sign of this...
                  Also set SketchUp to always run as admin...
                  Select the SketchUp.exe icon...
                  Properties > Compatibility
                  Tick the check-box near the bottom 'Always run as administrator'
                  Since you have v2013 and an RBZ archive... why not use SketchUp's Preferences > Extensions > Install... button OR the 'SketchUcation Plugin Store' toolset 'Archive Installer', OR in SketchUp use the 'SketchUcation Plugin Store' AutoInstall feature, which also checks folder permissions for you and tells you if you need to fix them - unlike a manual install when Windows uses the VirtualStore without expressly telling you !
                  • ArisA Offline
                    Aris
                    I still have a problem!
                    I made sure I'm an administrator, I gave full rights to the plugins folder, I set sketchup to "run as administrator" I reinstalled it 3 or four times and every time The contents of TIGtools file keep on disappearing upon starting sketchup! (the plugins are working, it's just that the toolbar is nowhere to be seen)
                      Try this: Enable the toolbar in View>Toolbars. Pull all of the toolbars off the top rows. Does the Extrude Tool toolbar show up in the upper left corner? If so, you have now found it and can place it where you need but you really ought to install the current version of SU2013. there was a bug in the first release that caused new toolbars to appear under the existing ones. It was fixed though.
                      • ArisA Offline
                        Aris
                        ok, I've installed it from plugin store
                        TIG: Extrude Tools v2.1
                        IMPORTANT UPDATE - A varied toolset for Extruding Edges into meshes etc... Now future-proofed...
                        Downloads: 6267 [ Version Updated: 2013/05/30 ]
                        -the plugin appears checked in preferences/extensions/Extrude tools
                        -It appears checked in view/toolbars.
                        -It does not even appear as a choice when I left-click the toolbars void space...
                        I did what you said with the top left toolbars still nothing...
                        could there be some conflict with files from older versions left in plugins folder or some other plugin?
                          You need to right click
                          • ArisA Offline
                            Aris
                            sorry, I meant right click...
                              Put everything in your plugins into a folder named #plugins
                              now install the Extrude .rbz file again an see if it appears
                              You need to first rule out if there is a clash
                                Did you move all of the toolbars as I said?
                                • ArisA Offline
                                  Aris
                                  Same story! I tried what you said, even relaunched SU and still it appears everywhere except
                                  the toolbars...
                                  • ArisA Offline
                                    Aris
                                    yes, I did move all the toolbars (before) and now that I removed everything, it still isn't there. (which I suppose is apparent since it doesn't appear as a choice in the right click menu...)
                                      That's is plain weird.
                                      Do you have v8 installed? If so is this reproducible on that?
                                      Can you post a screenie of your Plugins folder?
                                      • ArisA Offline
                                        Aris
                                        yes I have it installed and there's no problem there
                                        • ArisA Offline
                                          Aris
                                          here's the new plugins folder (I also gave it full rights)
                                            And you are running the very latest release of 2013?
                                            What's inside the ExtrudeTools folder?
                                            You've the extension enabled under preferences?
                                            You have it enabled in the SketchUcation Tools Managers?
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 31
                                            • 32
                                            • 24 / 32
