    [Plugin Library] LibFredo6 - v15.8b - 12 Jan 26
    2.2k Posts 571 Posters 4.1m Views 573 Watching
    • fredo6F Offline
      NEW RELEASE: LibFredo6 v5.2a - 30 Aug 13
      LibFredo6 5.2 is a follow up technical release that implements final naming conventions for files and folders to be compliant with EWH requirements.
      For LibFredo6, the footprint is based on one file and one subfolder:
      For my scripts, new naming conventions are also based on one file and one subfolder. I will progressively re-release the scripts with the new naming conventions. For instance, FredoScale v2.5 footprint is now :
      For convenience, LibFredo6 5.2 is compatible with the old and new naming conventions. So if you have CURVILOFT_Dir_12 folder, it will be loaded normally (until I publish the new version based on Fredo6_Curviloft and Fredo6_Curviloft).
      It is also a good idea to clean up your plugin directory and remove the older versions.
      In the menu Windows > LibFredo6 Settings...> Purge Obsolete Files, you will find a dialog box allowing to remove all or some of these older versions.
      VERY IMPORTANT: if you have installed 000_AdditionalPluginFolders, you MUST upgrade it to its version 4.1 or higher. Otherwise, you will not load LibFredo6 5.2 (but instead the older version of LibFredo6).
      • zooenZ Offline
        zooen
        Bonjour,
        Apparemment on a plu le Français, pour ce super-plugin !! ❓
        • fredo6F Offline
          @zooen said:
          Bonjour,
          French is available and included (all my scripts are available in French).
          • Automatically set to French if your system is French
          • or go to the menu Windows > LibFredo6 settings... > Choose preferred language
          • LanaL Offline
            Lana
            Very good. I have SU8 and ok. Very, very, very tanks!
              songkran77
              thank you vermush
              • E Offline
                ekisticsplanning
                I'm trying to install toposhaper on a Mac and its a no go. I've got my permissions set on the plug ins folder. Have LibFredo 5.1 installed, and have ToolsOnSurfaces working fine. I've copied the TOPOSHAPER_Dir_10 folder to the plug-ins folder and it will NOT show up in Sketchup.
                Anyone have any ideas?? Dying to try this plug in.
                  How have you installed it ?
                  Leaving files inside their RBZ will cause issues...
                  Did you use Preferences > Extensions > Install... on the downloaded RBZ file or the SketchUcation Plugins Store AutoInstaller within SketchUp itself - these methods are 'foolproof'...
                  The correct Plugins folder is found using this in the Ruby Console +<enter>
                  Sketchup.find_support_file('Plugins)
                  In v2013 it is in your own user library folder tree, so you should automatically have the needed FULL read/write permissions ?
                  Have you looked in Preferences > Extensions and activated its Extension ?
                  Have you activated its Toolbar in View > Tool Palettes [MAC, or Toolbars PC] ??
                    thaihung50
                    merci
                      Arpas
                      Fredo: I'm new here... your work is just awesome. Thanks a lot. I put this link in my favorites. Thanks again!
                      Armpa
                        Garry K
                        Fredo,
                        I've been playing around with the settings to see if I can get the rounding of a curved and twisted handrail to work a bit better. I am looking for a 6 facet 1/2" corner round.
                        I'm running 2.5a Round Corner along with 5.2a library - on Sketchup 7 and 8
                        It appears that a very tiny triangle isn't being turned into a face during the round Corner operation ( just a guess )
                        I can pick the three edges and use Utility Make Face and it does turn it into a face.
                        Any suggestions? any settings that I need to change?
                        Curved and twisted handrail
                        Holes in Rail
                        A few edited holes
                        • fredo6F Offline
                          NEW RELEASE: LibFredo6 v5.3g - 28 Oct 13
                          LibFredo6 5.3 is a release for JointPushPull Interactive 3.0, which is just published.
                          • fredo6F Offline
                            NEW RELEASE: LibFredo6 v5.3h - 29 Oct 13
                            Version 5.3h includes some small fixes and adjustments
                            • Support of '=' in translation strings
                            • fix in the logging of errors, in relation with AdditionalPluginFolders
                            • Option for toolbar icons (for SU13 and above), based on a request from Ken
                            • Minor fixes
                              The LibFredo6 Default Parameter dialog boxes includes an option to show bigger or smaller icons for my plugins
                            If you choose Smaller (default), then you will get
                            If you choose Bigger, then you will get
                            Note that it only applies to SU13. In SU8 and previous versions of SU, the icon size is automatically adjusted by Sketchup
                            • OxerO Offline
                              Oxer
                              Thanks for the update!!
                              New Spanish (Spain) Language File:
                              • LAGRARI2012L Offline
                                LAGRARI2012
                                Thanks you very much!!
                                  detcharles
                                  Help,
                                  I installed the plugin and the tools work great, but the menu display looks very strange. The message box at the top left corner is all all scrambled and digitized. Here is a screen shot, take a look at the upper corner. Does anyone know whats going on?
                                  I am running SU8 Pro on a Macbook Pro Retina and just upgraded to Mavrick operating system
                                  • fredo6F Offline
                                    There are know problem about drawing texts on Mac with Retina.
                                    Curiously, many users have the font too small, but you seem to have it too big.
                                    So there must be a parameter to adjust the size of texts drawn (in OpenGL).
                                      detcharles
                                      What Should I do to fix it?
                                        KevB
                                        can somebody tell me where you put the shared library file ie the round corners
                                        Kevin
                                          Kevin
                                          Go to the first post of the thread and read it. It tells you where to put the files. Why don't you install the Sketchucation Plugin Store? Then you can just let it auto install your plugins.
                                            detcharles
                                            Hello,
                                            I am reposting from earlier concerning a problem with the way the text is displayed in joint push pull. I included a photo [see attached].
                                            Fredo mentioned its an issue with Open GL text sizing. Does anyone know how to adjust that?
                                            Thank You
                                            I am running SU8 PRO on a Macbook Pro Retina, OS Maverick
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 108
                                            • 109
                                            • 30 / 109
