    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.3k Posts 587 Posters 10.8m Views 589 Watching
    • fredo6F
      NEW RELEASE: LibFredo6 v5.1c - 22 Aug 13
      LibFredo6 5.1b was wrongly publishing.
      So you should re-install 5.1c if you had installed 5.1a. Sorry again for inconvenience.
      • kenK
        ken
        Fredo6
        Thanks for the quick reply. I just had a feeling it was "fast fingers".
        Ken
        • fredo6F
          Fredo6
          Ken
          On top o that, the keyboard was slippery....
          Hope it works now.
          • kenK
            ken
            @fredo6 said:
            Fredo6
            Ken
            Hope it works now.
            Boy is my imagination running wild now.
            Again thanks
            Also,TIG, thank you. Never hurts to be reminded to double check the obvious. I also suffer from the "fast finger" syndrome.
            • T
              the fox8000
              When i put the files in my folder and open sketchup it says (Error Loading File ZLoader__OnSurface.rb no such file to load -- LibFredo6.rb)
              How do I fix it?
                Go back and read the first post of this thread. And then install LibFredo6 like it says to do.
                • fredo6F
                  NEW RELEASE: LibFredo6 v5.2a - 30 Aug 13
                  LibFredo6 5.2 is a follow up technical release that implements final naming conventions for files and folders to be compliant with EWH requirements.
                  For LibFredo6, the footprint is based on one file and one subfolder:
                  For my scripts, new naming conventions are also based on one file and one subfolder. I will progressively re-release the scripts with the new naming conventions. For instance, FredoScale v2.5 footprint is now :
                  For convenience, LibFredo6 5.2 is compatible with the old and new naming conventions. So if you have CURVILOFT_Dir_12 folder, it will be loaded normally (until I publish the new version based on Fredo6_Curviloft and Fredo6_Curviloft).
                  It is also a good idea to clean up your plugin directory and remove the older versions.
                  In the menu Windows > LibFredo6 Settings...> Purge Obsolete Files, you will find a dialog box allowing to remove all or some of these older versions.
                  VERY IMPORTANT: if you have installed 000_AdditionalPluginFolders, you MUST upgrade it to its version 4.1 or higher. Otherwise, you will not load LibFredo6 5.2 (but instead the older version of LibFredo6).
                  • zooenZ
                    zooen
                    Bonjour,
                    Apparemment on a plu le Français, pour ce super-plugin !! ❓
                    • fredo6F
                      @zooen said:
                      Bonjour,
                      French is available and included (all my scripts are available in French).
                      • Automatically set to French if your system is French
                      • or go to the menu Windows > LibFredo6 settings... > Choose preferred language
                      • LanaL
                        Lana
                        Very good. I have SU8 and ok. Very, very, very tanks!
                          songkran77
                          thank you vermush
                          • E
                            ekisticsplanning
                            I'm trying to install toposhaper on a Mac and its a no go. I've got my permissions set on the plug ins folder. Have LibFredo 5.1 installed, and have ToolsOnSurfaces working fine. I've copied the TOPOSHAPER_Dir_10 folder to the plug-ins folder and it will NOT show up in Sketchup.
                            Anyone have any ideas?? Dying to try this plug in.
                              How have you installed it ?
                              Leaving files inside their RBZ will cause issues...
                              Did you use Preferences > Extensions > Install... on the downloaded RBZ file or the SketchUcation Plugins Store AutoInstaller within SketchUp itself - these methods are 'foolproof'...
                              The correct Plugins folder is found using this in the Ruby Console +<enter>
                              Sketchup.find_support_file('Plugins)
                              In v2013 it is in your own user library folder tree, so you should automatically have the needed FULL read/write permissions ?
                              Have you looked in Preferences > Extensions and activated its Extension ?
                              Have you activated its Toolbar in View > Tool Palettes [MAC, or Toolbars PC] ??
                              • T
                                thaihung50
                                merci
                                  Arpas
                                  Fredo: I'm new here... your work is just awesome. Thanks a lot. I put this link in my favorites. Thanks again!
                                  Armpa
                                  • G
                                    Garry K
                                    Fredo,
                                    I've been playing around with the settings to see if I can get the rounding of a curved and twisted handrail to work a bit better. I am looking for a 6 facet 1/2" corner round.
                                    I'm running 2.5a Round Corner along with 5.2a library - on Sketchup 7 and 8
                                    It appears that a very tiny triangle isn't being turned into a face during the round Corner operation ( just a guess )
                                    I can pick the three edges and use Utility Make Face and it does turn it into a face.
                                    Any suggestions? any settings that I need to change?
                                    Curved and twisted handrail
                                    Holes in Rail
                                    A few edited holes
                                    • fredo6F
                                      NEW RELEASE: LibFredo6 v5.3g - 28 Oct 13
                                      LibFredo6 5.3 is a release for JointPushPull Interactive 3.0, which is just published.
                                      • fredo6F
                                        NEW RELEASE: LibFredo6 v5.3h - 29 Oct 13
                                        Version 5.3h includes some small fixes and adjustments
                                        • Support of '=' in translation strings
                                        • fix in the logging of errors, in relation with AdditionalPluginFolders
                                        • Option for toolbar icons (for SU13 and above), based on a request from Ken
                                        • Minor fixes
                                          The LibFredo6 Default Parameter dialog boxes includes an option to show bigger or smaller icons for my plugins
                                        If you choose Smaller (default), then you will get
                                        If you choose Bigger, then you will get
                                        Note that it only applies to SU13. In SU8 and previous versions of SU, the icon size is automatically adjusted by Sketchup
                                        • OxerO
                                          Oxer
                                          Thanks for the update!!
                                          New Spanish (Spain) Language File:
                                          • LAGRARI2012L
                                            LAGRARI2012
                                            Thanks you very much!!
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 36
                                            • 113
                                            • 114
                                            • 34 / 114
