    [Plugin] OBJexporter v3.0 20130131
    304 Posts 96 Posters 658.0k Views 96 Watching
    • McGyverM
      McGyver
      Hi! I'd like to thank TIG once again for this truly awesome plugin as well as all the subsequent updates.
      I frequently recommend this plugin for people who are new to SketchUp, showing them that their modeling efforts can be used in other programs besides SketchUp.
      A lot of people tend to believe that SketchUp is very limited, has no export options for the free version and are not aware of all the amazing plugins that extend SU's capabilities and give it greater power.
      I was just writing a short "How to" for people who wish to use their models in Poser/DAZ studio, but it occurred to me that while I giving instructions on how to install a ruby script such as "OBJexporter" I was not sure if there were any other plugins that needed to be installed for OBJexporter to work properly... I have quite a few and the thought came to me when I was describing the progress bar and "Model exported in X# of seconds" features... so I figured I'd ask-
      Does OBJexporter require any other plugins such as Progressbar.rb to function properly?
      Thats probably a pretty stupid question, but before I tell someone how something works, I figured I should probably include any relevant additional information.
      Thanks in advance for any information any of you can provide!
      Visit My ShareCG Freebie Gallery
        My OBJexporter code is 'self-contained'.
        It only 'requires' sketchup.rb, and that is installed by SketchUp itself in the Tools folder...
        The progress reporting etc is built-in to my code and needs no 3rd party helpers...
        • McGyverM
          McGyver
          Thank you once again!
          • T
            the_bored_gamer
            Hi, I press the OBJexporter button... then it ask to "convert all to png?".
            Wether I press Yes or No, I get nothing, it just close. Please help!
              Run with the Ruby Console open: this will report progress etc...
              Tell us any error messages.
              If you are working with a Selection it must contain Faces...
              Are no files [OBJ/MTL] or textures' folder made at all ?
              Do you have permissions to make files in the destination folder etc??
              • F
                FantasyZone
                OMG TIG!!!!!!!
                I searched for a month a obj exporter for SketchUp and now I found your Obj Exporter an made an extra account on sketchucation just to download it and at last it worked!!!!!!!!!!!!! I am so happy now thank you for this FREE(!) ObjExporter
                FantasyZone 😍
                PS. TAHNK YOU!
                  anar
                  Thanks TIG for this plugin.
                  It seems that groups are not exported with their SKP names.
                  For example if my group is named "Cylinder" the exported group name is "test-GRP-Cylinder-566-Color_A01" which is a bit annoying because I have to rename all my groups after exporting.
                  Also if I make a group with name "Level1" that contains 2 groups with names "Level2_A" and "Level2_B" without any other geometry, the group "Level1" won't export in the OBJ file.
                  Therefore ther is only one level of hierarchy exported...
                  Can it be a limitation of the OBJ format by itself ?
                  Cheers !
                    Anar
                    The 'grouping' in the OBJexporter file format is effectively 'by material'.
                    Each facet has a assigned a group based on:
                    ModelName-ContainerType-Name-ID-MaterialName
                    As Group names are no unique and Components can have multiple instances the ID is needed.
                    So for your:
                    Working right to left the geometry is thus...
                    MaterialName = Color_A01 [the Material's name, adjusted so its characters are OBJ compliant]
                    ID = 566 [assigned by SketchUp for the container's definition, during that session]
                    Name = Cylinder [the Container's name, adjusted so its characters are OBJ compliant]
                    ContainerType = GRP [Group]
                    ModelName = test [the Model's name, adjusted so its characters are OBJ compliant]
                    Note that if you had say 'Black' end facets then they would grouped separately as:
                    test-GRP-Cylinder-566-**Black**
                      anar
                      Thanks TIG for such a complete explanation !
                      But I still think it would be very useful if the groups could be exported with just their names as we can see them in the Outliner.
                      Then if the name isn't unique the exporter could automatically add a "_1", "_2", "_3", etc. at the end of it (for example).
                      I don't know if you see the need for it but when I export a scene with a lot of groups it takes me a lot of time to rename them back manually with the name I originally gave them in SU.
                      Maybe it could be an export option ?
                      I understand it would be more work on your side as the exporter doesn't have any "export option" window...
                      Still it's a good plugin that I use all the time ! Thanks !
                      Anar
                      http://www.reppersdelight.spacymen.com
                        rangel96
                        I have the same problem 😢
                        Everything is ok and i gave a normal name to may new file. I even ended it with .obj ...
                        And I have administrator rights...
                        that´s what loks like in the Ruby console:
                        OBJExporter:
                        C:/Users/André/Desktop/Untitled.obj
                        Error: #<Errno::ENOENT: No such file or directory - C:\Users\André\Desktop/Untitled.obj>
                        C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/OBJexporter.rb:266:in initialize' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/OBJexporter.rb:266:in new'
                        C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/OBJexporter.rb:266:in export_start' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/OBJexporter.rb:245:in export'
                        C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/OBJexporter.rb:223:in initialize' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/OBJexporter.rb:1093:in new'
                          anar
                          May be you should avoid the "é" in your path.
                          I suggest you use only UTF8 characters.
                            Precisely!
                            Précisément! 😒
                              rangel96
                              Thanks! I will try do save in other place!
                              • I
                                Ibo
                                Hello,
                                I downloaded the plugin. Installed it in the plugin folder of sketchup8 but when I start the program I can't find it.
                                Does anyone know what to do ?
                                thanks
                                Ibo
                                  Under the File menu - like many other Exporters ?
                                  and like it says in the instructions...
                                  Usage: menu File > 'OBJexporter...'
                                  • N
                                    nightwasp
                                    Help.
                                    I put the RB file in the SU 2013 (free) Plug-Ins folder. I restarted but still only have the option to export as DAE or Google Earth. Please advise.
                                    Thanks so much for your help!
                                    -Keith
                                    • BoxB
                                      Look at the post above yours and look at this image.
                                      • N
                                        nightwasp
                                        Thanks for the quick reply! On the Mac, I only have this for that menu, and Export 3D Untitled-1.jpghas just the two free options.
                                        Best. K
                                        • BoxB
                                          If it isn't there it suggests it hasn't installed properly, it might be the security permissions or the folder location.
                                          Have a look here and see if that helps.
                                          http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=56005
                                          Installing the Sketchucation Plugin lets you find, install and manage plugin easily, so you might be better off getting that installed instead.
                                            The OBJexporter is NOT in the File > Exporters list.
                                            It not defined as an 'exporter' [a special class of plugins].
                                            It appears as a separate entry under the File menu itself...
                                            So since it is not there... you haven't installed it properly... 😕
                                            Read the linked explanation... 😒
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 13 / 16
