    [Plugin] SectionCutFace
    565 Posts 170 Posters 361.4k Views 169 Watching
      gigi500
      Superellipsoid Plugin
      Version: Superellipsoid 1.0
      Release Date: July 1, 2010
      Requirements: SketchUp 6.0+
      I have it as a tool under "draw". The form comes in as a component. When I try to use a section cutface, it crashes the Sketch up. Tried to use sectioncutface with other solid forms and it's fine. It's really not that crucial:)))
      Thank you for all your plugins.
        I have just been testing SectionCutFace on a Superellipsoid - it worked fine - no splats at all, faces formed properly etc.
        I used the default parameters...
        What setting do you have that might cause issues ?
        Is the 'cut' located outside or inside this component?? [makes no difference in my testing!]
        As I said before very tiny facets could cause failure when forming the face - but a splat is unlikely πŸ˜•
        Have you tried making a simple box component and cutting that ?
        If it crashes too you have something watching component-instances and instigating a crash
        What other plugins do you have loading? - some rogues are known to cause splats [actually it is they that splats, when a legit tool does an action that they interfere with or react to wrongly, via one of their observer etc, or they interfere with native classes/methods...] πŸ˜’
        The Vray-beta, various half-baked BIM tools, current SketchyPhysics... and a few others are on this "danger-list"...
          SabiaSingh
          Dear Mr Tig
          re your kind reply to me on Mon Jul 29, 2013 5:27 pm. i would like to say sincerely thank you
          for all your hard works and also for taking time to being reply to my question. I am doing as you say and it is sectioning perfectly. Many Many thanks and god bless. SS
          • sfto1S Offline
            sfto1
            I just installed the latest version of Section Cut Face and the Glue option is not working. I selected yes in the glue option yet when I move the section plane the cut face disappears and it looks like an ordinary section plane view.
            What am I doing wrong?
            P.S.
            SU 8pro
            This is on my laptop with limited graphics.
            Installed thru plugin store.
              @sfto1
              Can you post a simple SKP where it isn't working with three section-planes, one glued, one glued-on-demand and the other not glued at all [there are three options].
              We can then test it...
              • sfto1S Offline
                sfto1
                This is the file I was practicing on. It is nothing special.
                Thanks in advance for your interest in helping.
                SFTO1
                test skip.skp
                  Are you sure you have version 3.8 installed ?
                  Its Extension's description will show it...
                  Assuming you have it... then it should work.
                  I ran you test SKP - it worked fine.
                  There was no section-plane to test, but I added a new one on the end where you have left an 'orphaned' sectioncutface-group [which I deleted].
                  Because you had deleted the original plane I can't check its attributes etc πŸ˜’
                  I tested the SKP in v8 AND v2013 and it worked fine every time with both Glue and Glue-on-demand.
                  When you change a model - say by moving the section-plane or some geometry - then the Glued sectioncutface-group is auto-regenerated to suit the new circumstances, but only when you go on to the next tool, so using 'move' on the plane leaves the cut-group behind momentarily until your 'move' tool becomes something else - say 'select'. To recreate the group 'dynamically' for every tool you might use is too much of an overhead on the processing. Also remember that if your cut moves out of the geometry then no cut will be visible, as it's not made...
                  • sfto1S Offline
                    sfto1
                    I do have v3.8 and with your helpful explanation, I now realize that the cut face does not dynamically follow the section cut. It does in fact create the "glued" face when I switch to a different tool. I was not switching to a different tool.
                    Thanks for such a creative and useful tool.
                    • Z Offline
                      z3325206
                      Hi Tig,
                      I have successfully load the section cut face .rzb plugin into my sku8 via changed the file extension from .rzb to .zip then unzip it, it works fine with my sku8 pro.
                      Come to the sketch up vray render stage, i have create a section plane as image 1 shows,
                      but every time I render it, it still render it as a whole model as image 2 shows. The section cut face disappeared.
                      http://i1305.photobucket.com/albums/s541/frankyzhou/1_zpsae9f08fb.jpg?t=1381736127
                      http://i1305.photobucket.com/albums/s541/frankyzhou/2_zpsf867190d.jpg
                      how can I fix this problem?
                      Thank you for ur patience to answer my question.
                      Best regard,
                      Frank
                      • cottyC Offline
                        cotty
                        I think the renderer must support section cuts and it isn't a problem of the plugin. If so, you can save a copy of your model and use the "Slice Model at Section" option from Zorro2 (?) to delete the rest of the model for the render.
                        my SketchUp gallery
                          Unless your renderer supports section-cuts [unlikely for many of them] you must, as Cotty says, work on a copy of your model and slice it at the section-plane using Zorro2, then any section-cut-face you have added will show at that cut. Now it will render as expected.
                          I believe that the newest version of SUPodium has a tool to do something very much like this for you, automatically saving the model as a copy and then running zorro-like and section-cut-face-like operations on the selected section-plane in the copy...
                          • cottyC Offline
                            cotty
                            Indigo Renderer supports section cuts directly (see here).
                            my SketchUp gallery
                            • Z Offline
                              z3325206
                              Thank you Cotty and Tig, It works fine with zorro2 in sku8.
                                JAD JM
                                Hi TIG, Does this plugin work for Mac?
                                  It works just fine on Mac.
                                  • danchoD Offline
                                    dancho
                                    Hi Tig,
                                    thanks for a recent help. Now I have one interesting problem.
                                    After reinstalling a sketchup 2013, put on several plugins only.
                                    SketchuUV ; AdditionalPluginFolder ; Sketchucation loader and your plugin SectionCut Face.
                                    Using this plugin in small scene cca 30Mb interior I have strange delay when I need to
                                    orbit a scene. My sketchup slow down on a strange way. After that I was trying with other files 20-120Mb sizes but the same.
                                    After removing a plugin everything is fine.
                                    Do you know some solution for this?
                                    Sketchup 2013, Windows 7 Home P. x64,
                                    Daniel
                                      On large models gluing a section-cut to a section-plane can slow things down noticeably, because at each change to the model it has to decide if the section-cut is modified by that...
                                      Therefore using the alternative glue-on-demand mode is recommend, or even no-gluing_remake if the section-plane or model being cut by it changes...
                                      • atelierpaarA Offline
                                        atelierpaar
                                        Hello Tig,
                                        thanks for this great plugin. Its a tremendous advantage to glue the section plane. I noticed so, that its not possible to change colors or textures once they are applied. ThatΒ΄s to bad, since I usually differentiate my sections. Is there a workaround ?
                                        anyway`s, congratulation one more time
                                        Uli
                                          You don't need a work around. You need to change Lock from Yes to No before you make the face.
                                          Or unlock the locked group so you can open it for editing.
                                          • cottyC Offline
                                            cotty
                                            If it is glued, you cannot change the color, even if it's not locked.
                                            my SketchUp gallery
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 28
                                            • 29
                                            • 21 / 29
