    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 322.0k Views 110 Watching
      kct3937
      Too bad it doesn't work in OSX. Looks like a good plugin. Now if it worked on a real operating system….just imagine.
      Dave Richards might quit looking in a mirror.
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        Please don't come here to troll...
        The reason why it doesn't work on your "real" OS is because Safari handles javascript requests higgledy-piggledy. JS sends a bunch of informations to ruby, and safari says "oh well, let's just put all of this into the trash and keep only the last one".
        So much for a real OS.
        Even though I'm happy to take request, I primarily develop this plugin for myself. And I don't really like MacOS (The OS itself, Apple's politic, etc...), so I'm not really motivated to develop Layers Panel for it. Guess what? People coming here smugly, telling me that their OS is superior, and should be the one and only, don't really motivate me much more!
          jiminy-billy-bob
          @mike whitton said:
          This is a marvelous idea - SketchUp has needed this sought of control of layers for a long time. BUT .....It makes my version of SketchUp (2013) very unstable to the point of being unusable. I have had to uninstall the plugin.
          Am I doing something wrong?
          What are you experiencing, exactly ?
            dtrarch
            Hi JBB
            FYI:
            Layers not showing up.? 👎
            Same problem here but====== 👍
            If I click on a scene tab the layers are then listed. 👍
            SU 2013 Pro
            dtr
              kct3937
              Well I have been chastized before and probably will be again, but I must apologize for offending you about OS versus Windoze. If my comments are considered Trollish, that is because I am unaware of what a Troll in this context is.
              I am an architect and have programmed on Microsoft based equipment since before Windows…when we could only use DOS. I have used SU from the early versions (2 or 3) and have seen and used many good plugins and yours caught my eye as being one that would be of much use to me.
              I realize that most addins/extensions are created out of the need of an individual to simplify their work or to emulate a desirable feature of another program and applaud your creation of this plugin. I was really hoping to be able to use it in my workflow…hence my disappointment; maybe even a dosappointment.
              About 6 years ago, I switched to OSX and have not experienced the Blues Screen of Death since. Being familiar with many languages that are platform independent, I did not look to see that your extension was Windows specific…my first bad.
              I regularly use javascripts and rubies to create programs and have not run into issues with Safari that are insurmountable, but I respect your opinion of Apple and trust that you respect mine regarding Windows. As I have not delved into the SU API myself, I do not know where the problem with OSX lies but I hope that you can overcome it, either yourself or with help from an OSX user on this forum.
              Again, my apologies for my comment regarding OSX as I meant no disrespect toward you or your work. I look forward to the day that I can post some glowing report of my experience with this plugin/extension.
              From reading the other posts, it would appear that your program is being well received.
              Regards,
              kct3937
                jiminy-billy-bob
                It's ok... I'm just sick of this PC/Mac war.
                In the meantime, you can always try the plugin. I know for a fact that some people on OSX use it everyday.
                  jiminy-billy-bob
                  New version 0.5.2 beta !
                  Changelog :
                  • Fix bug where "old layers" (created before Layers Panel was installed) were not listed
                  • Fix bug where groups couldn't be renamed after being nested in another one.
                  Download in the plugin store !
                  • unclebimU Offline
                    unclebim
                    @jiminy-billy-bob said:
                    @unclebim said:
                    1. In SU 8 it displayed the outdated IE version message and did not allow the scroll. Since ver. 0.5 it does not display this message but only shows render engines in the window and no layers or layer groups at all. In SU 2013 this problem does not exist.
                    What's your IE version ?
                    @unclebim said:
                    1. Not sure whether since ver. 0.4 or 0.5 but in both SU 8 and SU 2013 Edit->Paste and Ctrl+V do not work, Edit->Paste in place works though. Removing the plugin files from SU Plugins folder resolved the problem in both SU 8 and SU 2013. Also renaming layers in the native SU Layers window sometimes caused bugsplat with the plugin installed in SU 2013.
                    Weird. Does it work when Layers Panel is installed but closed ?
                    1. It is ver. 10 and no updates available. After installing ver. 0.5.2. it displays the outdated IE version message again. Operating with the Layers panel is possible but with some delay of about 2-3 sec.
                    Attached is a screenshot from whatmyua.com and another from chips-architecture.com/layers/test.html.
                    1. Well it does happen no matter whether Layers Panel is open or closed. What happens is that you can see the pasted object shortly on the screen and then it disappears and the move tool cursor reverts back to the formally active tool. I tried this with groups and components and with ungrouped geometry. The problem occurs when the pasted object requires the creation of a new layer that does not exist in the file already. If I make a layer with the same name that the pasted object is on then it can be pasted. Although I have a problem pasting a nesting group in Layer 0 and I have no problem pasting the nested groups together (also on Layer 0). Moving the same nesting group on a newly created (after Layers Panel installation) layer does not help. Making the group a component also.
                    Another issue I have experienced with the latest version is that turning layers and layers group visibility one after another sometimes causes SU (both 8 Pro and 2013) to close.
                    I hope this can be helpful. I appreciate the effort you put into this plugin and it is indeed one of the most useful ones out there.
                    httpchips-architecture.comlayerstest.html - Windows Internet Explorer_2013-10-10_00-13-43.jpg
                    • H Offline
                      huckrorick
                      This is really weird. Can you open this link with Internet Explorer and tell me what the popup says ? (If you don't have a popup, this may be because of an ActiveX warning at the bottom or top of the IE window)
                      I'm having a bit of a hard time following our conversation because it is intermixed with other questions, issues, comments, replies. I don't know if I missed any other response from you.
                      Here's what I get at the link you provided (see attachment)
                        jiminy-billy-bob
                        Thanks for the feedback guys, very much helpfull 😉
                        I'll work on it.
                          jiminy-billy-bob
                          Changelog :
                          Looks like I uploaded 0.5.1 again, instead of 0.5.2...
                          I'll upload the proper version at noon.
                            shumphreys
                            Fantastic layering tool, I applaud your hard work.
                            If you're up for more work I have some suggestions...
                            1. Highlight layers for currently selected entity, this would save having to consult the entity info window. Could also include colour coding for sub layers used within the entity.
                            2. Entity count on layer list. This would help to identify incorrectly assigned layers.
                            3. Select all entities by layer. Could be a context menu item.
                            4. Option to remove render feature.
                            Thanks again
                              jiminy-billy-bob
                              @shumphreys said:
                              1. Option to remove render feature.
                              Already did 😉 Look in "options" in the menu.
                              Noted the other propositions.
                              • O Offline
                                optimaforever
                                Hello,
                                The idea of this script is excellent, something I kept asking AtLAst developpers for a long time (in the famous wishlist), and the material list manager as well (by giving users the ability to group materials by components, for example).
                                The thing is, the layer panel worked once, and the next time I launched SU8, it returned blank of layers, with the IE version is outdated message. I work with SU8, panel 0.5.2 on Vista 64 and IE9 (don't use IE anyway, but 9 is the last supported version by Vista).
                                Any clue?
                                  jiminy-billy-bob
                                  Can you try with Sketchup Make 2013 ?
                                  • O Offline
                                    optimaforever
                                    Hello,
                                    I will, once I get out of my stressing schedule. 😎
                                    • Bob JamesB Offline
                                      Bob James
                                      It still says:
                                      Layers Panel
                                      Version beta 0.5.1
                                        jiminy-billy-bob
                                        Uploaded the proper update 0.5.3 beta ! (Which is what should have been 0.5.2)
                                        Changelog :
                                          DRDS-11
                                          How about an OS X version!!!!! Otherwise its a waste of time!!!!
                                            tomot
                                            Question?
                                            Whats the significance of having IE installed? I use win7 64, I have never installed I.E. and don't intend to do so. I use Mozilla FireFox only. And I hate being reminded by a dialog box from the plugin if I want to switch. Can you make the use of I.E. optional?
                                            Otherwise I like the plugin, very! very! much. 🎉
                                            my plugins
                                            tomot
                                            • 11
                                            • 12
                                            • 33
                                            • 34
                                            • 10 / 34
