    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.6m Views 202 Watching
    • E Offline
      elisaha
      Hi everyone,
      I'm a SU-newbie with SU 8 on a Mac with OS X 10.7.5, however I have troubles installing ToolsOnSurface 1.8a. I do have the ZLoarder, LibFredo and the Tutorial Offset on Surface in the correct plugin folder. It even shows up in my extensions, but there is no line-up. What can I do?
      I do have a general problem with installing plug-ins.. I don't know what I would be doing wrong, please help!
      Thanks alot,
      Elisa
      • mitcorbM Offline
        mitcorb
        Hi:
        On the very first page of this thread under Installation, for Mac is this:
        [On Mac the SU plugin directory should be:
        Macintosh HD/Library/Application Support/Google SketchUp 7/SketchUp/plugins]
        In your case, it will be Sketchup 8 but the rest of the path should be correct.
        Alternatively, go to the top of this page, mouse over Resources, and select Plugin Store Download. This automates the process. Watch the video, read the information.
          giltora
          tools on surface not responding.. help please!!!!
            More info is needed.
            HOW isn't it 'responding' ?
            Do you get the extension/toolbar ?
            Are there error messages?
            [Try it with the Ruby Console window open...]
            Did you get the latest versions of this tool AND the required LibFredo...
            Both are available in the SCF PluginStore...
              popfunky
              Thank but i can't install 😢
                Please explain your problem better, so we can help you properly.
                How are you trying to install this ?
                Do you have the required support 'Lib' installed as explained in the download details ?
                  archdeacon
                  Fredo thank you for these great tools. i am having a hard time installing this one though. I am on sketchup 8 pro - Windows 7. any ideas...? i have observed the footprint and everything. I do not appear to have the LibFredo6.rb that you are mentioning (i have the newer library). Is this because you have updated the lbrary to the new version? can you instruct me on how to cure this problem.
                  thanks for your help.
                  • fredo6F Offline
                    Since you have Sketchup 8, you should
                    • first, install the Sketchucation Plugin Store tool
                    • Then Auto-install my scripts with this tool. You'll have zero problem and it's much easier and faster than with the ZIP file. You will also get the latest versions available
                    You may need to do a clean up of your SU Plugins directory before if you had a wrong installation
                      archdeacon
                      oops...
                      i just restarted sketchup (i had done it before as well and it did not work)
                      BUT IT WORKS FINE NOW!
                      thank you very much! 😍
                        Karen, can you post a screen shot that shows the problem?
                          kdrr1607
                          Hi! I have a question. The construction lines are not showing every time I click on the surface after picking the initial point, so I cant pick an end point. Uhm, how can I solve this? Thanks.
                            kdrr1607
                            Here is the screen shot. I pressed print screen then pasted it on paint, but the mouse was did not appear on paint, so i took another photo that shows it on close-up. The construction line isnt showing as i move my pointer away from the initial point. I tried specifying a diameter/distance, but nothing happened.
                            Here is another photo showing the toolsonsurface as a mouse pointer.
                              Do you get guidelines if you use the yellow Tape measure tool? I'm wondering if this is an OpenGL setting issue.
                                kdrr1607
                                Yes, everything works fine but my tools on surface plugin.
                                  Is it possible the construction lines are inside your cylinder? What do you see if you switch to X-ray face style?
                                    kdrr1607
                                    Yes, Ive done that, still no lines showing.
                                      Weird.
                                      I'm on my Mac right now but it is playing fine for me. I'll check on my PC when I get home. Have you installed the most recent version?
                                        kdrr1607
                                        Ive installed the ToolsOnSurface16c found on Ruby library depot. Ive tried installing the one uploaded in this website, but it doesn't start. All it says on the command line is "Loading all Ruby files for plugin Tools on Surface", tried waiting to load, but still nothing.
                                          kdrr1607
                                          Oh, what I meant by it doesnt start is Tools on surface appears, but when I click it, it doesnt do anything, all it shows in the command line is "Loading all Ruby files for plugin Tools on Surface"
                                            That makes me think you have either a plugin installation problem or perhaps incorrectly set permissions for the Plugins folder. Perhaps you could make a screen shot of Windows Explorer showing the Plugins folder and its contents as well as a screen shot of the Security tab under Properties for the Plugins folder.
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 31
                                            • 32
                                            • 23 / 32
