    [Plugin] s4u_toComponents
    89 Posts 26 Posters 108.6k Views 26 Watching
    • F
      feodos
      Thank you ! I'll wait ...
      • hdpvH
        hdpv
        ready for download ...welcome test my plugin.
        Suforyou
        http://www.sketchupforyou.com
          rv1974
          those are very promising scripts, thank you!
          could you take a look at the 3rd command- it seems the distorting is not always right.
          aaaa.skp
          • hdpvH
            hdpv
            hi,
            if face is trapezoid,don't select component before,
            it's only fix when face is rectangle or parallelogram
            Suforyou
            • Z
              zuiwoxuan
              I don't know why it can't be used,can you tell me how to install this plugin?Is it about the TT lib version?
              • N
                naginarch
                Thanks alot Huynh Duong Vi
                • hdpvH
                  hdpv
                  hi zuiwoxuan,
                  how do you install,can you capture screen?
                  Suforyou
                  • hdpvH
                    hdpv
                    hi rv1974!
                    the problem was solved...
                    Suforyou
                    • H
                      hebeijianke
                      In sketchup Extension Warehouse
                      version is still 2.0.1
                      • F
                        feodos
                        can lay here version 3.0.0?
                        • F
                          feodos
                          It is very good! Thank you very much!
                            Added to PluginStore
                            You are also dded to the Plugin Authors group so....
                            404 Not Found
                            (sketchucation.com)
                            ...allows you to edit, share etc...
                            You can also visit here for a full PluginStore Guide...
                            404 Not Found
                            (sketchucation.com)
                            Thanks for shaing. Let me know if you need help getting the Donate button in place
                            • hdpvH
                              hdpv
                              Thanks Rich!
                              Suforyou
                                slave
                                Thanks for sharing, it's a good plugin.
                                I want to try to use this plugin for panelization .(like Rhino paneling tool)
                                Can you tell me on which method/principle component is align, scale, rotated...
                                on attached face.
                                Is there some possibility for controls, how component will be attached?
                                Because what ever you change, component axes, or revers face direction(front/back)....
                                you will get different results.
                                Regards
                                Slave
                                • hdpvH
                                  hdpv
                                  hi Slave!
                                  I will control direction's component in version v3.0.1
                                  waiting for update,:)
                                  in v3.0.0,you can try : "S4U::S4u_toComponents.facestocoms(1)" in Ruby Console
                                  Suforyou
                                    slave
                                    Huynh, thank you for information.
                                    • I
                                      ivreich
                                      Hi Huynh
                                      First up....AWESOME PLUGIN!
                                      I would like to second slave's comment...I've downloaded v3.0.1, and i see that you've added an option that orients the plugins consistently. The user can't select which direction to orient them too however, will there be an option for user control of component orientation later on?
                                      It would be soooo awesome if this turns into a proper panelisation plugin. Get it working nicely with thomthom's quads...maybe allow control for thickness as well!
                                      Congrats on this great work...
                                      Joel
                                      • jolranJ
                                        jolran
                                        Panelization Plugin..
                                        You mean like this :
                                        404 Not Found
                                        (sketchucation.com)
                                        (scroll bottom)
                                        BTW, the time it took to render was due to the fact that Components adapted scale to nonuniformal(Square) faces.
                                        • hdpvH
                                          hdpv
                                          Hi Joe!
                                          I also like better user-interface, but it's a difficult request.
                                          I will try ...:
                                          Suforyou
                                          • jolranJ
                                            jolran
                                            I'm guessing you are a more experienced programmer than me(cant see your code cause it's scrambled), but I believe that.
                                            Since we have been working on similar things. I mean, if you want any snippets of code, ideas, thoughts or discoveries found out during tests during development of Hatchfaces. Let me know. PM me.
                                            If you wanna do your own thing, that's fine too. I understand.
                                            Better interface. Hm, If it can be avoided, it's easier.
                                            But have a look at Thomthom's new widgets.
                                            They might make webdialog business much easier.
                                            • 2 / 5
