    [Plugin] s4u_toComponents
    89 Posts 26 Posters 107.0k Views 26 Watching
    • hdpvH Offline
      hdpv
      Delete_instance will delete all instances which is overlaped its position.
      less used but when i "copy" then "paste in place" 2-3 times ,it's my old plugin. ๐Ÿ˜„
      this new update s4u_DeleteInstances_v1.0.1
      http://sketchucation.com/forums/viewtopic.php?f=323&t=53337&p=484301#p484301
      Suforyou
      http://www.sketchupforyou.com
      • X Offline
        xyz11811
        it's super! big THX!
        • hdpvH Offline
          hdpv
          Hi Pilou
          I can't delete after unused edges because it will affect the other ,but I update delete selected face and delete egdes no common_face.
          Suforyou
          • F Offline
            faust07
            Thank You! It's really a very useful and handy plugin. Just that I was looking for in the moment. ๐Ÿ‘
            • Nguyen Ngoc PhucN Offline
              Nguyen Ngoc Phuc
              nice plugin. Thank sir.
              • F Offline
                feodos
                SUPER!!!!! THANKS HDPV! This is version: 2.0.1 ?
                • hdpvH Offline
                  hdpv
                  sorry! Feodos,version 2.0.1 not yet ready for public
                  if you want it please mail to me ...๐Ÿ˜„
                  Suforyou
                  • F Offline
                    feodos
                    Thank you ! I'll wait ...
                    • hdpvH Offline
                      hdpv
                      ready for download ...welcome test my plugin.
                      Suforyou
                        rv1974
                        those are very promising scripts, thank you!
                        could you take a look at the 3rd command- it seems the distorting is not always right.
                        aaaa.skp
                        • hdpvH Offline
                          hdpv
                          hi,
                          if face is trapezoid,don't select component before,
                          it's only fix when face is rectangle or parallelogram
                          Suforyou
                          • Z Offline
                            zuiwoxuan
                            I don't know why it can't be used,can you tell me how to install this plugin๏ผŸIs it about the TT lib version๏ผŸ
                            • N Offline
                              naginarch
                              Thanks alot Huynh Duong Vi
                              • hdpvH Offline
                                hdpv
                                hi zuiwoxuan,
                                how do you install,can you capture screen?
                                Suforyou
                                • hdpvH Offline
                                  hdpv
                                  hi rv1974!
                                  the problem was solved...
                                  Suforyou
                                  • H Offline
                                    hebeijianke
                                    In sketchup Extension Warehouse
                                    version is still 2.0.1
                                    • F Offline
                                      feodos
                                      can lay here version 3.0.0?
                                      • F Offline
                                        feodos
                                        It is very good! Thank you very much!
                                          Added to PluginStore
                                          You are also dded to the Plugin Authors group so....
                                          404 Not Found
                                          (sketchucation.com)
                                          ...allows you to edit, share etc...
                                          You can also visit here for a full PluginStore Guide...
                                          404 Not Found
                                          (sketchucation.com)
                                          Thanks for shaing. Let me know if you need help getting the Donate button in place
                                          • hdpvH Offline
                                            hdpv
                                            Thanks Rich!
                                            Suforyou
                                            • 1 / 5
