    [Plugin] s4u_toComponents
    89 Posts 26 Posters 104.2k Views 26 Watching
    • hdpvH Offline
      hdpv
      hi zuiwoxuan,
      how do you install,can you capture screen?
      Suforyou
      http://www.sketchupforyou.com
      • hdpvH Offline
        hdpv
        hi rv1974!
        the problem was solved...
        Suforyou
        • H Offline
          hebeijianke
          In sketchup Extension Warehouse
          version is still 2.0.1
          • F Offline
            feodos
            can lay here version 3.0.0?
            • F Offline
              feodos
              It is very good! Thank you very much!
                Added to PluginStore
                You are also dded to the Plugin Authors group so....
                (sketchucation.com)
                ...allows you to edit, share etc...
                You can also visit here for a full PluginStore Guide...
                http://sketchucation.com/forums/viewtopic.php?f=382&t=52516
                Thanks for shaing. Let me know if you need help getting the Donate button in place
                • hdpvH Offline
                  hdpv
                  Thanks Rich!
                  Suforyou
                    slave
                    Thanks for sharing, it's a good plugin.
                    I want to try to use this plugin for panelization .(like Rhino paneling tool)
                    Can you tell me on which method/principle component is align, scale, rotated...
                    on attached face.
                    Is there some possibility for controls, how component will be attached?
                    Because what ever you change, component axes, or revers face direction(front/back)....
                    you will get different results.
                    Regards
                    Slave
                    • hdpvH Offline
                      hdpv
                      hi Slave!
                      I will control direction's component in version v3.0.1
                      waiting for update,:)
                      in v3.0.0,you can try : "S4U::S4u_toComponents.facestocoms(1)" in Ruby Console
                      Suforyou
                        slave
                        Huynh, thank you for information.
                        • I Offline
                          ivreich
                          Hi Huynh
                          First up....AWESOME PLUGIN!
                          I would like to second slave's comment...I've downloaded v3.0.1, and i see that you've added an option that orients the plugins consistently. The user can't select which direction to orient them too however, will there be an option for user control of component orientation later on?
                          It would be soooo awesome if this turns into a proper panelisation plugin. Get it working nicely with thomthom's quads...maybe allow control for thickness as well!
                          Congrats on this great work...
                          Joel
                          • jolranJ Offline
                            jolran
                            Panelization Plugin..
                            You mean like this :
                            http://sketchucation.com/forums/viewtopic.php?f=323&t=38637&start=300
                            (scroll bottom)
                            BTW, the time it took to render was due to the fact that Components adapted scale to nonuniformal(Square) faces.
                            • hdpvH Offline
                              hdpv
                              Hi Joe!
                              I also like better user-interface, but it's a difficult request.
                              I will try ...:
                              Suforyou
                              • jolranJ Offline
                                jolran
                                πŸ‘
                                I'm guessing you are a more experienced programmer than me(cant see your code cause it's scrambled), but I believe that.
                                Since we have been working on similar things. I mean, if you want any snippets of code, ideas, thoughts or discoveries found out during tests during development of Hatchfaces. Let me know. PM me.
                                If you wanna do your own thing, that's fine too. I understand.
                                Better interface. Hm, If it can be avoided, it's easier.
                                But have a look at Thomthom's new widgets.
                                They might make webdialog business much easier.
                                • hdpvH Offline
                                  hdpv
                                  Thanks Jolran,good idea!
                                  I like your plugin,i will study it,
                                  This plugin hasn't been optimized yet.
                                  So i didn't post code.
                                  But i have post the others already.
                                  Suforyou
                                  • jolranJ Offline
                                    jolran
                                    Thanks, but current release is only linehatches orginating from TIG's mentoring.
                                    It probably won't help you.
                                    I havent released tiling for Components onto surface yet since I thought it was to slow when scaling non-uniformally.
                                    Aligning a Component to the center of a Square face and scaling it to fit is relatively easy. But not when face is tapered. Mostly common in spheric objects and bulges.
                                    As you most certainly have discovered there is no API-method for tapering.
                                    So that means when a face is not paralleogram(?) one has to go in and alter each tiled Component individually == make Component uniq.
                                    Maybe you have found some nice solution for this, I don't know.
                                    In my case I came up with a linesweep algoritm that scanned the face vertices and scaled the Component to be tapered. As mentioned going in doing this sweep and translating Components vertices X n.times is gonna be slow nomatterwhat.
                                    If this could be taken externally in C perhaps would help, but still won't be faster than API methods. I reckon.. Kind of a Catch 22.
                                    If looking on the positive side of things, since I'm starting to sound a bit negative.
                                    It's better to sit and wait a couple of minutes than putting the Components there manually πŸ˜„ As long as Sketchup doesent freezes πŸ‘Š
                                    Anyway, will be interesting to see what you come up with. πŸŽ‰
                                    • I Offline
                                      ivreich
                                      Any chance this plugin can be designed to work with thomthom's Quads definition, so we can finally get a proper panelisation tool?
                                      Currently only works with planar surfaces. It would be awesome if it would work with non-planar quads and perhaps allow thickness to be defined.
                                      Joel
                                      • hdpvH Offline
                                        hdpv
                                        Jolran!
                                        paralleogram face,I use API "entities.transform_by_vectors sub_entities, vector_array" move vertices in component.Length vector is ratio x,y of vertex.
                                        Joel!
                                        I would like that works with non-planar surfaces ,take time to work πŸ˜„
                                        Suforyou
                                        • pep75P Offline
                                          pep75
                                          I THINK THIS IS ONE OF THE MOST REVOLUTIONARY PLUGIN IN YEARS!!!!
                                          I'm your biggest fan! πŸ˜„)!
                                          • pep75P Offline
                                            pep75
                                            I just have sent you a donation!
                                            • 2 / 5
