    [Plugin] s4u_toComponents
    89 Posts 26 Posters 104.2k Views 26 Watching
    • Z Offline
      zuiwoxuan
      I don't know why it can't be used,can you tell me how to install this plugin?Is it about the TT lib version?
      • N Offline
        naginarch
        Thanks alot Huynh Duong Vi
        • hdpvH Offline
          hdpv
          hi zuiwoxuan,
          how do you install,can you capture screen?
          Suforyou
          http://www.sketchupforyou.com
          • hdpvH Offline
            hdpv
            hi rv1974!
            the problem was solved...
            Suforyou
            • H Offline
              hebeijianke
              In sketchup Extension Warehouse
              version is still 2.0.1
              • F Offline
                feodos
                can lay here version 3.0.0?
                • F Offline
                  feodos
                  It is very good! Thank you very much!
                    Added to PluginStore
                    You are also dded to the Plugin Authors group so....
                    (sketchucation.com)
                    ...allows you to edit, share etc...
                    You can also visit here for a full PluginStore Guide...
                    http://sketchucation.com/forums/viewtopic.php?f=382&t=52516
                    Thanks for shaing. Let me know if you need help getting the Donate button in place
                    • hdpvH Offline
                      hdpv
                      Thanks Rich!
                      Suforyou
                        slave
                        Thanks for sharing, it's a good plugin.
                        I want to try to use this plugin for panelization .(like Rhino paneling tool)
                        Can you tell me on which method/principle component is align, scale, rotated...
                        on attached face.
                        Is there some possibility for controls, how component will be attached?
                        Because what ever you change, component axes, or revers face direction(front/back)....
                        you will get different results.
                        Regards
                        Slave
                        • hdpvH Offline
                          hdpv
                          hi Slave!
                          I will control direction's component in version v3.0.1
                          waiting for update,:)
                          in v3.0.0,you can try : "S4U::S4u_toComponents.facestocoms(1)" in Ruby Console
                          Suforyou
                            slave
                            Huynh, thank you for information.
                            • I Offline
                              ivreich
                              Hi Huynh
                              First up....AWESOME PLUGIN!
                              I would like to second slave's comment...I've downloaded v3.0.1, and i see that you've added an option that orients the plugins consistently. The user can't select which direction to orient them too however, will there be an option for user control of component orientation later on?
                              It would be soooo awesome if this turns into a proper panelisation plugin. Get it working nicely with thomthom's quads...maybe allow control for thickness as well!
                              Congrats on this great work...
                              Joel
                              • jolranJ Offline
                                jolran
                                Panelization Plugin..
                                You mean like this :
                                http://sketchucation.com/forums/viewtopic.php?f=323&t=38637&start=300
                                (scroll bottom)
                                BTW, the time it took to render was due to the fact that Components adapted scale to nonuniformal(Square) faces.
                                • hdpvH Offline
                                  hdpv
                                  Hi Joe!
                                  I also like better user-interface, but it's a difficult request.
                                  I will try ...:
                                  Suforyou
                                  • jolranJ Offline
                                    jolran
                                    I'm guessing you are a more experienced programmer than me(cant see your code cause it's scrambled), but I believe that.
                                    Since we have been working on similar things. I mean, if you want any snippets of code, ideas, thoughts or discoveries found out during tests during development of Hatchfaces. Let me know. PM me.
                                    If you wanna do your own thing, that's fine too. I understand.
                                    Better interface. Hm, If it can be avoided, it's easier.
                                    But have a look at Thomthom's new widgets.
                                    They might make webdialog business much easier.
                                    • hdpvH Offline
                                      hdpv
                                      Thanks Jolran,good idea!
                                      I like your plugin,i will study it,
                                      This plugin hasn't been optimized yet.
                                      So i didn't post code.
                                      But i have post the others already.
                                      Suforyou
                                      • jolranJ Offline
                                        jolran
                                        Thanks, but current release is only linehatches orginating from TIG's mentoring.
                                        It probably won't help you.
                                        I havent released tiling for Components onto surface yet since I thought it was to slow when scaling non-uniformally.
                                        Aligning a Component to the center of a Square face and scaling it to fit is relatively easy. But not when face is tapered. Mostly common in spheric objects and bulges.
                                        As you most certainly have discovered there is no API-method for tapering.
                                        So that means when a face is not paralleogram(?) one has to go in and alter each tiled Component individually == make Component uniq.
                                        Maybe you have found some nice solution for this, I don't know.
                                        In my case I came up with a linesweep algoritm that scanned the face vertices and scaled the Component to be tapered. As mentioned going in doing this sweep and translating Components vertices X n.times is gonna be slow nomatterwhat.
                                        If this could be taken externally in C perhaps would help, but still won't be faster than API methods. I reckon.. Kind of a Catch 22.
                                        If looking on the positive side of things, since I'm starting to sound a bit negative.
                                        It's better to sit and wait a couple of minutes than putting the Components there manually 😄 As long as Sketchup doesent freezes 👊
                                        Anyway, will be interesting to see what you come up with. 🎉
                                        • I Offline
                                          ivreich
                                          Any chance this plugin can be designed to work with thomthom's Quads definition, so we can finally get a proper panelisation tool?
                                          Currently only works with planar surfaces. It would be awesome if it would work with non-planar quads and perhaps allow thickness to be defined.
                                          Joel
                                          • hdpvH Offline
                                            hdpv
                                            Jolran!
                                            paralleogram face,I use API "entities.transform_by_vectors sub_entities, vector_array" move vertices in component.Length vector is ratio x,y of vertex.
                                            Joel!
                                            I would like that works with non-planar surfaces ,take time to work 😄
                                            Suforyou
                                            • 2 / 5
