    Rolleiflex Automat [Model Progression Thread]
    90 Posts 15 Posters 17.0k Views 15 Watching
    • Bryan KB
      @box said:
      I don't understand the 3 axis rotate.
      When you "place" the text it should glue to the face of one of your facets so the only rotation you need would be roughly 90deg to have it reading the right way.
      And doing it this way allows you to use joint push pull to stamp them or raise them.
      This is exactly what I'm trying to do. Hmm, yet mine won't do this.
      Cool. Thanks for the help, box. Like I said, I'll try this again.
      Not sure why it isn't working.
      Again thanks.
      • Bryan KB
        Update:
        Got one to work, but in the wrong place. πŸ˜†
        I think I can make this work, but it's going to be very tedious.
        Thanks again box. I think that will do it.
        • Bryan KB
          Minor tweaks. Still more details to be added.
          • GarethG
            Gareth
            looking good...!!
            • Bryan KB
              Thanks Gareth!
              Knurling complete on side knobs. Screws and bezel ring on side knobs also complete.
              I think the scale of knurling is a tad smaller than shown in references, but it's the best I can do and I think still pretty darn close.
              • Bryan KB
                More lens detail.
                • Bryan KB
                  More lens front detail.
                  Arrgghh! I just noticed the lens locking ring is a little more complex than I thought. So what you see right now is not correct.
                  Also, the font used for the lettering is not the official font. I don't have that font and I doubt anybody but Rollieflex does, so I tried to use something I thought was appropriate from the era.
                    The font is close enough the standard of modeling is exceptional and the detail level high. Thanks for showing this step by step, very inspirational and a fantastic production.
                    • Bryan KB
                      Thanks Mike.
                      There is still quite a bit of detail left to be done. I may have this done by this weekend.
                      BTW, can anyone point me to a tutorial on how to create material texture and import it in SU? The body textured material I'm using at the moment is not exactly right. The pattern needs to be a lot smaller and the one I'm using has reached its scale down limit.
                      • soloS
                        Leave that until very end, use a basic material as you have while modeling then when ready to render you can play with materials. What render engine do you plan on using?
                        • Bryan KB
                          I'll be using Kerky. I have a 3 light, stage cyc, model I built a few years ago I'll use for the final render.
                          • Bryan KB
                            Shutter release guard added. Feet rounded. Starting on tripod mount detail.
                            • Bryan KB
                              Tripod mount assembly complete. There will be no threading for the screw hole. It will never be seen.
                              • BoxB
                                I don't know about that Bryan, every time I look at it now I'll be worried it will fall off the tripod! πŸ˜‰
                                • Bryan KB
                                  No problem. I just won't model a tripod. πŸ˜†
                                  • Bryan KB
                                    Almost there. Probably 8 more hours of work left to do.
                                    • GarethG
                                      Gareth
                                      only 8 hours..??
                                      ....you mean your are not modelling the internal mechanisms...?!! πŸ˜†
                                      • Bryan KB
                                        @gareth said:
                                        only 8 hours..??
                                        The what what? πŸ˜†
                                        Sick this weekend. Still feeling low today. No updates until maybe tomorrow.
                                        • Bryan KB
                                          Couldn't let it go. πŸ˜†
                                          Rebuilt the nameplate face for the 5th time. I think I've got it this time. πŸ˜’
                                          Extended the tripod flange handle. (you can't see it in this pic) Added the exposure chart. Nameplate join to pop-up viewfinder was wrong.
                                          At this point it looks like only 2 3 more things to be done: numbers on focus knob and finger flanges on lens locking rings and logo. (see, I knew I could have this done this weekend, dang it, but I'll bet I find more details are wrong) πŸ‘Š
                                          • Bryan KB
                                            Reworked top of view finder.
                                            Still only 2 more things to do. Just 2 more things. πŸ˜†
                                            • 3 / 5
