    Rolleiflex Automat [Model Progression Thread]
    90 Posts 15 Posters 13.6k Views 15 Watching
    • Bryan KB Offline
      Minor tweaks. Still more details to be added.
      • GarethG Offline
        Gareth
        looking good...!!
        • Bryan KB Offline
          Thanks Gareth!
          Knurling complete on side knobs. Screws and bezel ring on side knobs also complete.
          I think the scale of knurling is a tad smaller than shown in references, but it's the best I can do and I think still pretty darn close.
          • Bryan KB Offline
            More lens detail.
            • Bryan KB Offline
              More lens front detail.
              Arrgghh! I just noticed the lens locking ring is a little more complex than I thought. So what you see right now is not correct.
              Also, the font used for the lettering is not the official font. I don't have that font and I doubt anybody but Rollieflex does, so I tried to use something I thought was appropriate from the era.
                The font is close enough the standard of modeling is exceptional and the detail level high. Thanks for showing this step by step, very inspirational and a fantastic production.
                • Bryan KB Offline
                  Thanks Mike.
                  There is still quite a bit of detail left to be done. I may have this done by this weekend.
                  BTW, can anyone point me to a tutorial on how to create material texture and import it in SU? The body textured material I'm using at the moment is not exactly right. The pattern needs to be a lot smaller and the one I'm using has reached its scale down limit.
                  • soloS Offline
                    Leave that until very end, use a basic material as you have while modeling then when ready to render you can play with materials. What render engine do you plan on using?
                    • Bryan KB Offline
                      I'll be using Kerky. I have a 3 light, stage cyc, model I built a few years ago I'll use for the final render.
                      • Bryan KB Offline
                        Shutter release guard added. Feet rounded. Starting on tripod mount detail.
                        • Bryan KB Offline
                          Tripod mount assembly complete. There will be no threading for the screw hole. It will never be seen.
                          • BoxB Offline
                            I don't know about that Bryan, every time I look at it now I'll be worried it will fall off the tripod! πŸ˜‰
                            • Bryan KB Offline
                              No problem. I just won't model a tripod. πŸ˜†
                              • Bryan KB Offline
                                Almost there. Probably 8 more hours of work left to do.
                                • GarethG Offline
                                  Gareth
                                  only 8 hours..??
                                  ....you mean your are not modelling the internal mechanisms...?!! πŸ˜†
                                  • Bryan KB Offline
                                    @gareth said:
                                    only 8 hours..??
                                    The what what? πŸ˜†
                                    Sick this weekend. Still feeling low today. No updates until maybe tomorrow.
                                    • Bryan KB Offline
                                      Couldn't let it go. πŸ˜†
                                      Rebuilt the nameplate face for the 5th time. I think I've got it this time. πŸ˜’
                                      Extended the tripod flange handle. (you can't see it in this pic) Added the exposure chart. Nameplate join to pop-up viewfinder was wrong.
                                      At this point it looks like only 2 3 more things to be done: numbers on focus knob and finger flanges on lens locking rings and logo. (see, I knew I could have this done this weekend, dang it, but I'll bet I find more details are wrong) πŸ‘Š
                                      • Bryan KB Offline
                                        Reworked top of view finder.
                                        Still only 2 more things to do. Just 2 more things. πŸ˜†
                                        • ely862meE Offline
                                          ely862me
                                          What a great machine you've got there !
                                          Btw, it is not that tedious to make those numbers if you want to do it like this :
                                          [web 100%,396:1pvof88h]http://www.screenr.com/embed/lLcH[/web:1pvof88h]
                                          Elisei (sketchupper)
                                          Come and See EliseiDesign
                                          • BoxB Offline
                                            You are over thinking it.
                                            You only need to position one number accurately, easily done using the glue to feature of the components, then array the numbers and replace the components as necessary. You can then explode and intersect or solid tools or component intersect etc to get the stamp effect.
                                            It's only a few minutes work.
                                            Here is a quick rough unfinished version of what I mean.
                                            [screenr:1oc6z3fl]1ucH[/screenr:1oc6z3fl]
                                            • 3 / 5
