    My IES light is not work
    renderpluginsextensions
    20 Posts 8 Posters 21.0k Views 8 Watching
      @jamalito said:
      what did do you even you got to shine ?
      A layer of glossy reflection.
      • jamalitoJ Offline
        jamalito
        glossy reflection how is that ?
        where is it ?
        Albert Einstein:
        ((I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.))
          A glossy reflection is a blurred reflection. Look for the Glossiness sections in the Reflection layer.
          • jamalitoJ Offline
            jamalito
            I've not used IES files much myself - but reports from the ASGVis forum says that it vary greatly frmo IES to IES.
            Also - some people have tried to use IES files for tiny LEDs as if they where large lightbulbs - which of course doesn't work well.
            that is right I used some IES file from Philips web site as you say it is not work
            in ture this files are need to be studied Scientific and Applied of intensive
            @thomthom said:
            92... that would explain things.
            To put things in perspective:
            http://en.wikipedia.org/wiki/Lumen_%28unit%29
            if a candle emits light with a luminous intensity of about 1 candela, the total light emitted is about 12.6 lumens.
            The difference between the units lumen and lux is that the lux takes into account the area over which the luminous flux is spread. A flux of 1000 lumens, concentrated into an area of one square metre, lights up that square metre with an illuminance of 1000 lux. The same 1000 lumens, spread out over ten square metres, produces a dimmer illuminance of only 100 lux. Mathematically, 1 lx = 1 lm/m2.
            A single fluorescent light fixture that produces a luminous flux of 12000 lumens might light a residential kitchen with an illuminance of 500 lux. Lighting a larger area to the same illuminance requires a proportionately greater number of lumens.
            A 23 watt compact fluorescent lamp emits about 1500–1600 lm.
            thank you This information
            I want ask you in this Below
            IES shine in power 5,000,000
            5,000,000 is watt or candela ?
            iF power is Candlea does it mean there problem in Settings?
            Albert Einstein:
            • jamalitoJ Offline
              jamalito
              thank you to your information
              Andy and thomthom
              Albert Einstein:
              • andybotA Offline
                andybot
                You are welcome Jamal!
                I think the material you used already had reflection, but with the higher light levels, it showed up more strongly. (when the camera is turned on, you are better able to control light levels than with just GI)
                I found some more information about photometry units.
                from http://www.olino.org/us/articles/2009/10/29/background-measurement-data-lamp-measurement-articles
                The unit is Cd/klm (klm = kilo lumen). This enables comparisons; say a 120 cm long tube light has a value of 100 Cd/klm in the 0° direction. This means that when a number of these tubes, physically close to an other, would give in total 1000 lm, than then the intensity right underneath them would be 100 Cd.
                When taking the 150 cm variant of the same tube, it will most likley have 1.5/1.2 x more intensity (Cd) in the same direction, and will give 1.5/1.2 x more luminous flux in total. Result is that the parameter expressed in Cd/klm remains the same; less tubes are needed to get to 1000 lm and hence the intensity will remain the same.
                A different type tube light ca have 200 Cd/klm in the same 0º direction. Placing that many tubes such that their sum equals 1000 lm, then the intensity will be 200 Cd.
                This way the lamps can be compared.
                As for how vray interprets "power" it states that the values are in lumens. If you have a specific light value on a surface, you may be able to do some math with candelas and lumens and distance, but that's more than I can stand to think about too long 😄
                  tmok
                  hi, i found something....
                  the unit setting on sketchup model is relate with ies light
                  if you draw in Meters, your ies will be set power above 5,000,000 to see some light
                  but if you draw in centimeters, your ies will works find at power defult value (i don't know why)
                  just simply switch drawing unit in sketchup to Centimeters
                    ccs1987
                    i have got this problem. Luckily i searched for the forum before i repost a new thread on a old problem. Thanks guys
                    Sketchup 8 pro
                    Vray
                    Intel Xeon W3520 2.67Ghz
                    12Gb Ram
                    Nvdia Quadro FX 1800
                      jef_cab
                      I got the same problem but fixed with this solution.
                      I just changed the Unit setting from meters to millimeters.
                      Problem solved.
                      Thanks Dude!
                      • V Offline
                        valerostudio
                        Here is a nice resource for some IES files. I have a small set of maybe a dozen that I use that I know work well.
                        VRAY for sketchup IES LIGTH complete collection
                        complete IES light Vray collection frre download
                        (www.sketchuptexture.com)
                        • V Offline
                          valerostudio
                          Nice tutorial here too
                          Setting up IES Lights in V-Ray for SketchUp :: SketchUp 3D Rendering Tutorials by SketchUpArtists
                          In this mini-tutorial, Onel Pabico shows you how to set up your IES lights in V-Ray for SketchUp, includes some simple tips for adjusting the amount
                          (www.sketchupartists.org)
                          • dkendigD Offline
                            dkendig
                            I really don't recommend messing with the power parameter, if you want physically accurate results. The power overrides the IES file's information. It should be left to 0, unless you really know what you're doing. Plugging in random numbers isn't going to result in something accurate, because the IES file already contains the correct information for that particular light. Get a different IES file, and ensure that you are working in the proper units.
                            Devin Kendig
                            Developer
